Last Online: 09-24-2009 01:30 AM
My Ride: 2000 VFR, STAINTUNE
2006 VFR
o2 resistors
Hi guys,just did the o2 elimination on my 06 model, followed the instructions from the other threads but my FIlight is staying on, what am i doing wrong?
Last Online: 10-24-2009 04:40 PM
My Ride: 2006 CBR1000RR,
2005 ST1300,
2000 VFR800FI (wife's)
I just did this yesterday as well and had no trouble. Used the 330 ohm, 1/2 watt resistors from Radio Shack.
Check the following with your install:
Hope this helps. |
| The Following User Says Thank You to Motocache1 For This Useful Post: | Sutto (06-22-2009) |
2006 VFR
No Luck
Thanks for your help motocache1, did everything by the diagram, even soldered resistors to copper sleeves to get good connection, tried all possible combinations but FI light stays on. Dont know if Australian model is different to US version or ive bought the only vfr this mod wont work on, but its driving me mad.
Last Online: Today 11:37 AM
My Ride: 2007 Honda VFR800 .... 1993 CB750 NightHawk
if you are possitive that the resistors are placed correctly, try reseting the ecu.
disconect the battery, turn the ignition key on. wait a few minutes to be sure all current is drained. connect the battery up again and see if your FI light is still on... as a side note, i have had an FI light triggered on the bike before. it turned out to be that the temperature sensor(IAT) located inside the air box was disconnected. just try going over all things related to the fuel injection... making sure that all sensors are satisfactory.
+ ZG ST, Heli's, Fender Eliminator, Throttlemeisser, Triangle Flip+Preload, BMC Filter. 200*Fan Switch, VTR Fan Blade - Snorkel, Flapper, Velocity Stacks. Pair Valves, and Evap Canister. Rounded off Entries to Throttle Bodies Motad Header and Two Brothers Exhaust Fully heat wrapped and sealed in high temp black Power Commander 3 USB & O2 Eliminators Custom Tune Done By AMR SUPERBIKES
2006 VFR
Thanks CandyRed, tried your suggestion, FI light stays on, if i take the resistors out and plug sensors back in FI light goes out as normal. Back to the drawing board.
Last Online: Today 02:24 AM
My Ride: 2007 VFR tricolour
Maybe you have a bad or wrong value resistor.
Mine is Aust version and its OK
RWB anniversary edition, Leo Vince exhaust, PC3, pair disabled, flapper deactivated, snorkel removed, gutted cat.etc etc |
2005 ST1300,
If you have a digital camera handy, take a picture of your connectors with the resistors installed. That will let us be a second set of eyes and verify everything. We'll be able to see the resistor color codes (they should look like the drawing I did above, orange, orange, brown, and then the 4th band color doesn't really matter). It will also let us see which terminals you've plugged into, etc.
I was going to ask if maybe you had accidentally hit the kill switch on the right handgrip. I've done that accidentally now and again and of course the FI light stays on if that switch is tripped. But you said it works correctly with the O2 sensors plugged in, so that rules that out. Post a pic if you can. Last edited by Motocache1; 06-22-2009 at 11:42 AM. |
Banned
Last Online: Today 11:51 AM
My Ride: 2007 RWB 1990 RED 1986 750 DRZ 400
FI light
Having a problem with my bike throwing FI light on solid when hot.Only does it when in traffic for long periods of time and will go out as soon as it cools off. Assume it is the O2 resistor out of range when heated. Bike runs just fine and I have another brand of resistors I will try this week.Anyone else have this problem?
2006 VFR
Hi guys, finally managed to get hold of 1/4 watt resistors, could only get 1/2 watt before, i'll stick those in tonight and see if that makes any difference. Thanks for your replies.
#10 (permalink) | |
2005 ST1300,
Most of the folks here are using 1/2 watt because that's the size Radio Shack carries in the 330 ohm. In some ways the 1/2 watt are actually better because the "legs" are a larger diameter and make better contact in the connector. You said you soldered copper tabs to the legs of your resistors before. Depending on your finesse with a soldering iron, that could have burnt up one or both resistors. If you have an ohm meter, check the resistance of your 1/2 watt resistors that you put the tabs on (if you still have them). It's possible one of them is "open". Let us know how it goes. Last edited by Motocache1; 06-23-2009 at 07:32 AM. |
#11 (permalink) | |
| The Following User Says Thank You to CandyRedRC46 For This Useful Post: | Sutto (06-24-2009) |
2006 VFR
Hi guys, had work committments for a couple of days, just stuck 1/4 watt resistors in tonight and hey presto, they worked!. Have no idea why 1/2 watt 330 ohm didnt work but i tried them again after 1/4 watt with no result, will run them and see how they hold up. Next project will be staintune pipes, ill let you know how they go. Thanks to everyone for your help and patience.
Last Online: Today 09:08 AM
My Ride: 1998 VFR
Just go into the shop manual and there is a way to reset the computer that should get rid you of your old code. There is a picture that shows a jumper wire that gets placed within a small square wire connector that is located under the seat. I will try to find the page number at lunch time.
#14 (permalink) | |
2005 ST1300,
Last Online: 11-18-2009 06:02 PM
My Ride: 2007 RWB
2003 KLR650
Always looking for more bikes!
I picked up the resistors this weekend...just trying to decide whether to throw them in now or wait for the next oil change...which will be around 1k miles more or roughly 2 weeks for me.
#16 (permalink) |
if you are going to have to take the left fairing of in two weeks to do the oil anyways, i would just wait till then and do them both at the same time to avoid the extra wear and tear on the clips & tabs also the chance that the fairing could be scratched...
500 miles a week...? jeeze whats up with that? 50 mile comute to work everyday?
#17 (permalink) |
My Ride: 2007 RWB
2003 KLR650
if I do 500 miles a week, i will have dropped my mileage from the last two weeks....I got the bike a little over 2 weeks ago and have 1300 miles on it now. The more I read about the resistor mod, the more I question whether I should do it or not. Seems like some people have good results and some do not.
#18 (permalink) |
2005 ST1300,
I think whether or not it is helpful depends on why you're doing it. In the case of my wife's bike (which I did the resistor mod to) her bike had an aftermarket exhaust and muffler and the aftermarket exhaust had no place for the oxygen sensors. Whomever installed the exhaust must not have known about the O2 eliminators or the resistor mod because we found the O2 sensor zip tied up inside the fairing. Since they were constantly reading ambient air oxygen levels I'm guessing they were making the bike run waaaay too rich. Removed the O2 sensors and did the resistor mod and the bike seems much more responsive and stronger in the low revs. Never calculated gas mileage on it before (or after) the mod, but I bet the gas mileage has improved too.
#19 (permalink) |
My Ride: 2007 RWB
2003 KLR650
Im doing it for the common 4.5-5.5 surging that my bike seems to have....its very noticeable in the bottom three gears when trying to hold a steady speed.
#20 (permalink) | |
but for best results a power commander should be used as step # 2...
| o2 resistors | Sutto | Mechanics Garage | 0 | 06-20-2009 11:27 PM |
| o2 resistors | Sutto | Mechanics Garage | 2 | 06-20-2009 07:58 AM |
| VFR VTEC 2008 - Throttle issue! (another one) | dazza139 | Mechanics Garage | 48 | 06-03-2009 12:01 PM |
| Cdi Unit Restoration For A 87' Vfr 700 F2 | CMR | First & Second Generation 1983-1989 | 11 | 05-08-2009 02:04 PM |
