Results 1 to 4 of 4
Thread: An alternative exhaust gut
    Member scottyx42's Avatar
    Jun 2009
    Glenwood Springs, Co. (world's largest hot spring pool, final resting place of "Doc Holliday"
    81CX500, an 02 VFR800 vtec, and an 88vtr250
    I was helping a friend who wanted a quieter, higher pitched exhaust, instead of the loud low pitched systems. (We're old, and already had our straight pipe BSA Lightnings in the sixties and virtually open megaphones and un-silenced expansion chambers in the seventies)
    I cut the rear shell, and pulled the rear tip with the baffle can attached, and only cut off the far (inner, or forward) end off the baffle can, which exposed the small pipes (that exit at the back) directly to all the exhaust gases. Many wouldn't like it because the exhaust is pitched higher, but it works for us. I'm only passable with mig, so the reweld was "gorilla" welds. (strong and ugly) I liked it and did mine that way too.
    Senior Member Echo3Niner's Avatar
    May 2009
    Fredericksburg, VA
    2007 25th Anniversary Ed. VFR
    448
    I'd love to see what you did.
    Semper Fi
    Proud member: Sixth Gen Militia - 1st VTEC Battalion (#215) - Company Commander 25th MarSOC (RW&B Marine SpecOps Co.)
    "The most interesting man in the world; Dos Echo3Niner"
    2007 RW&B VFR800
    Radio Shack $.99 O2 bypass
    Repsol oil w/K&N oil filter
    Marine Veteran & VP father of Cpl. Doug; (2nd tour: Iraq) AND 2nd Lt. Corielle (Corie); VMI NROTC/Marine Opt. Grad
    “Reveal to us the metal of thy character; suffer the courage of thy convictions.”
    Jun 2009
    It's way too late for pictures, they're both back on the road.
    If you look at the pictures of the other mods, you'll see that all the rest cut at the very tail end, and either completely removed the baffles, or cut the connection of the small pipes exiting the muffler and left the can volume to create a low pitched resonance. Too close to Harley noises for my taste
    I left the small pipes intact, cut the front facing portion off the baffle can, thus disabling the first two silencing switchbacks, and reducing only about half of the silencing.
    They're closest in sound character to Staintunes, a third quieter, and without the low pitched component.
    There was a poster who said he liked the sound when decellerating a stock exhaust from high rpm. It's much like that, and halfway in volume between the other gut jobs and stock. Has some of the character of seventies Porsche silenced two liter Carrera race motors at ten grand. (there was once a class that required silencing) They made the most incredible high pitched raspy bark
    I didn't quite manage that, but came close.
    Jun 2009
    I was talking to an engineer, and explained what I did, and he said that cutting off the inner part of the can and exposing the two smaller pipes rather than making the exhaust flow through the single larger pipe actually provided more cross section for flow than the single pipe, and that the actual flow was probably not significantly different that if I had removed the entire can, and welded the cap alone back on.
    Hmmm..... stumbled onto what I wanted by blind luck.
    One can only be young once, but can be immature forever. So far, my second childhood is going great!
  1. Helibar handlebar alternative
    By CBR600F4i in forum Mechanics Garage
    Last Post: 09-17-2009, 05:17 AM
  2. My alternative exhaust sys
    By carlgustav in forum Mechanics Garage
    Last Post: 01-10-2009, 01:47 PM
  3. helibar alternative?
    By v4pwr in forum Mechanics Garage
    Last Post: 03-23-2008, 11:20 AM
  4. An alternative to a tank bra
    By Action in forum General VFR Discussions
    Last Post: 04-05-2007, 07:03 PM
  5. alternative to plastic fasteners?
    By Bugxprt in forum Mechanics Garage
    Last Post: 08-16-2006, 09:54 AM
