wolfgrw (08-25-2009)
Hi! I had a fall a few months ago. The bike was parked up till now. But i'm noticing a "pulling" of the front wheel when i lean to a curve to the same side of the same curve. It's a strong pull since i have to push the handle to the opposite side to maintain control. I have no "dead center".
Can anyone help?
Best regards!
sounds like alignment
link below.
How to Check Motorcycle Wheel alignment | eHow.com
instead of string you can use 2 pcs of metal as long as they are straight.
more complicated link
Chassis Alignment Basics
ZG dbl bbl, semi gutted stock exhust
" The Chip " power mod, 19mm tail riser
and cool red grips
You should also check the tire for signing of cupping and/or scalloping.
Regards,
Rollin
I've used the method outlined in 02's link and it works well. An easy way to see large alignment problems is have someone sit on the bike and point the front wheel to what they perceive is straight ahead while you sit on your butt in front of the bike. Most of the time, you'll be able to see if something is out of alignment.
Action
2004 VFR: Heil Bars, BMC, 2 Bros, Fender Elim, Heated Grips, +2 rear sprocket, DID gold chain, PCIII, Delkevic Headers. Tires- Pilot Road 2CT's
The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts. - Bertrand Russell
"Sorry Baby, I had to crash that Honda" - Pulp Fiction
go the other way..
Hadn't had the time to try it out, tomorrow i will try it.
Thank you all!!
I had a pull on my bike and head shake issues. Turned out to be bent fork tubes. Replaced the tubes with some good ones and like riding a different bike! Ofcourse try the straightening method first.
Maybe next week...
Thanks once again!
