Results 1 to 10 of 10
Thread: '06 now with GP Shift
    Senior Member junktionfet's Avatar
    Nov 2007
    Raleigh, NC
    '06 VFR800, '01 RC51
    197
    I've reached a point where I need GP shift (reverse pattern) on my RC51 track bike. In order to get accustomed to it, I need it on my street bike. Trouble is though, no one seems to make a GP Shift kit for the VFR.
    I took a CBR954 rearset, gave it some heat to open up the mounting points slightly. Then I took a stepped bit and made the bolt holes slightly larger. In order for the rearset to clear the swingarm, I stacked two washers per bolt behind the rearset to act as spacers.
    I bolted everything up and adjusted the shifter. It's tight for sure--just touches the bodywork when shifting, and the shift rod itself touches the kickstand spring, but nothing binds.
    Uber Guru CandyRedRC46's Avatar
    Feb 2009
    Key West Florida
    2007 Honda VFR800 .... 1993 CB750 NightHawk
    1,062
    huh... thats cool.
    why do you NEED it on your track bike?
    Nov 2007
    Raleigh, NC
    197
    The fear of feeling the ground tug at my Sidi boot again while preparing for an upshift around a sweeping turn. Harmless or not, I don't like it--it holds me back, messes with my head.
    And as a matter of principle, reverse shift makes a lot more sense. I only downshift when the bike is pretty much vertical, and getting my foot under the shifter while braking is easier than when accelerating.
    Uber Guru 02 VFR Rider's Avatar
    Jan 2009
    MA
    02 RC 46
    1,279
    Blog Entries
    yes It sucks when you get your foot stuck under the shifter in mid corner.
    thanks for the info, has to be cheaper then buy'n a sato rear set.
    ZG dbl bbl, semi gutted stock exhust
    " The Chip " power mod, 19mm tail riser
    and cool red grips
    Feb 2009
    Key West Florida
    1,062
    Quote Originally Posted by junktionfet View Post
    yeah that does make a lot of sense. thanks bro
    Member bat-stang's Avatar
    May 2008
    H-Town Texas
    Gen Five Interceptor
    I would love to do a reverse pattern on my 5th gen... Had one on my old CBR600RR, wished i didn't have to go back...
    ...God grant me good speed... Gen.24:12
    Jan 2009
    MA
    02 RC 46
    1,279
    Blog Entries
    best to put sticker on bike that says GP shift.
    It sucks when you forget and shift the wrong way, it takes a bit to get used to it.
    and cool red grips
    Feb 2009
    Key West Florida
    1,062
    Quote Originally Posted by 02 VFR Rider View Post
    i always thought about it, but always forget to ask? how fucking tall are you?
    im 5'11" and had to drop mine and inch to flat foot, i cant believe you actually raised your's....
  9. #9
    Bubba Zanetti's Avatar
    Jan 2007
    Delaware
    1997 VFR750F
    2,584
    I know a buddy who's going to do this on his street bike for the same reasons.
    Interesting...
    BZ
    "The average man does not get pleasure out of an idea because he thinks it is true; he thinks it is true because he gets pleasure out of it".
    -H.L. Mencken
  10. #10
    Feb 2009
    Key West Florida
    1,062
    i could understand if my bike was a track bike id be all for it. but mines a dayly driver, so backing up and turning around every day in a gravel driveway, not a good idea to be on my tiptoes... plus the added stability doesnt hurt either...
  1. Factory Pro Shift Kit?
    By Seattle in forum General VFR Discussions
    Last Post: 11-06-2008, 02:57 PM
  2. clutchless shift
    By vernk in forum 1st & 2nd Generation 1983-1989
    Last Post: 08-15-2008, 12:13 PM
  3. Shift kit in 90
    By VIFFER90 in forum 3rd & 4th Generation 1990-1997
    Last Post: 07-08-2008, 02:11 PM
  4. Need Help With Shift Linkage
    By bladed101 in forum Anything Goes
    Last Post: 07-08-2008, 04:13 AM
  5. Pro Shift Kits?
    By Seattle in forum Mechanics Garage
    Last Post: 05-10-2008, 04:20 PM
