Last Online: 11-14-2009 08:51 PM
86 vfr 700 extremely hard to start under 70 deg.
Hello,
Basically the title says it all. It's an 86 700, and if the temp drops below 70 it is a pain to start even with full choke It can take ten minutes before I can get it to run. Once I get it running and up to operating temp I have no issues. Any ideas or help would be greatly appreciated. Thanks, Eddie |
Last Online: Yesterday 10:58 PM
My Ride: '86 VFR 700Fs (3)/ '97 VFR 750F/ '88 NT 650 HAWK (3)/
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
Have a look at your sparkplugs, check that gap is about .032"
Consider replacing them, how many miles have they been in use? Your carbs may be partially clogged, and SeaFoam might help....... a well tuned bike like yours should start easily without choke unless temp is below about 50F.
" Goin' to Hell in a bucket, but at least I'm enjoyin' the ride....... " "It's no use, mate, the bottom's fallen out......." |
| The Following User Says Thank You to squirrelman For This Useful Post: | Eddie W (10-17-2009) |
Thanks I will pull it apart tomorrow I have not had a chance to really check it out. I was thinking it may be plugs also but since I am more informed about automobile repair I figured I would get some opinions from people who are more comfortable on the motorcycle repair side. I appreciate your reply and I will keep you updated.
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
Sparkplugs in bikes need much more frequent replacement than in cars....
While you're in there a compression test would be a good idea since low compression makes starting difficult.
Last Online: 11-19-2009 08:50 AM
My Ride: 86 honda interceptor vfr 700f
that helps me a bit to thanks for making this post eddie
Well I changed the plugs today they were actually fairly new but I have seen even new plugs out of the box have bad resistance readings in the past so I changed them anyway, and I also fixed an exhaust leak I did not know about.
Unfortunately it still did not solve the problem. When I pulled the plugs they were a little wet so I'm leaning toward a carb issue as I believe that they are seeping gas into the cylinder as the bike cools down making it that much harder to start with the cold weather. I did not even think of a compression test due to the bike running flawlessly at normal operating temps., but I will check it out next Sunday which is again my only day off this week. I have rebuilt quite a few carbs on automobiles but have never done one on a bike, if anyone else on here is familiar with automobile carbs would these be similar in difficulty to a quadrajet, or would you say maybe an standard edelbrock carb. Just wondering what I'm getting into. Thanks again ![]() |
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
IT'S unlikely that carbs are seeping gas since they have zero fuel pressure when pump isn't running.....
Did the plugs all look the same? How long have you had the bike ?
| The Following User Says Thank You to squirrelman For This Useful Post: | Eddie W (10-19-2009) |
Banned
Last Online: Today 12:40 PM
My Ride: 2007 RWB 1990 RED 1986 750 DRZ 400
link.....hope it helps.
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. Ronald Reagan |
| The Following User Says Thank You to TOE CUTTER For This Useful Post: | Eddie W (10-19-2009) |
I have had the bike for a few months and have put about 900 to 1000 miles on it. The plugs all looked the same except the plug with the exhaust leak at the cylinder head it had a little less carbon buildup probably due to higher cylinder temps from the exhaust leak I'm lucky I did not burn a valve. I was thinking the same thing about the carbs not seeping because of the fact that they do not have pressure after you shut the power off but its the only thing I can think of because there is definitely fuel going in the cylinder some how because the plugs were wet after sitting overnight the first time I pulled them to start checking the problem out. I really appreciate your help, it really does help to have someone to bounce ideas off of for me. I wonder if the carbs may have had a different set of jets installed and its just running rich enough that when I shut it down it does not burn all of the fuel in the cylinders? I'm going to keep digging until I find this problem I really should have looked this bike over better when I bought it I have also found that the previous owner put silicone on the radiator cap the keep it on
, he told me when I bought it the motor was changed to a newer 750, nope looks to be the original 700. but it's my fault for not checking it out. Whoa I am rambling now so I will end this one for the night thanks again all![]() |
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
TRY using LESS choke when starting: you could possibly be flooding the plugs with excess enrichment.
begin with using only about 1/4 choke and gradually increase if it doesn't start, and keep the throttle closed while cranking
almost banned
Last Online: Yesterday 11:37 PM
My Ride: 1986 honda Interceptor 700
1985 Suzuki GS700E(RIP)
i was gonna say ..make sure the choke is connected.....
charter member: Chat Hooers Union, Local 151 http://www.tricountymotorcycles.com/ " the return of the mullet will be the rebirth of our nation" TOECUTTER "stick like shit to a blanket" K1c "I'm the guy that keeps Mr.Dead in his back pocket" Max |
Last Online: Yesterday 08:46 PM
My Ride: 1986 VFR750
Have you confirmed spark at low temps?
what about fuel pressure? |
almost banned
IS the choke cable still connected? I know it sounds retarded to ask , but I had similar problems it would start when it was really warm out but not wehen it was cool.... the PO disconnected the choke cable from the bracket and all it did was slide the housing back and forth...
#14 (permalink) |
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
IF Crusty is correct, the choke lever will be very easy to move and have practically no resistance.
Last Online: 11-15-2009 05:28 PM
My Ride: 1986 Honda VFR700F, 1989 Suzuki GSX750F Katana
lmao, how funny...I have this same problem, and the choke cable IS my cure. I'm not sure if it's disconnected or broken, but either way, the choke lever does nothing when moved. I knew when I got the bike that the cable was bad, but rarely use a choke anyways, but i'll be damned if i don't actually need it on this bike in the cold, so I've already planned to tear it down this weekend and find out where the problem is.
#16 (permalink) | |
almost banned
#17 (permalink) |
No my choke is hooked up, I do not think it would start for me at all if it wasn't I tried the 1/4 choke today it was still a pain even @ a little over 60 deg. but like I said before once it starts and runs for about a minute you would never know that there was a problem at all. Thanks again to everyone who is helping out.
#18 (permalink) |
This may be a dumb question but the casting on the side of the engine that says 699 cm3 means it is a 700 not a 750. I am being told that it is a 750 but that makes no sense to me. sorry for the dumb question I just want to be sure.
#19 (permalink) |
almost banned
its a 700 thats what mine says.....what does your title say?
| The Following User Says Thank You to crustyrider For This Useful Post: | Eddie W (10-21-2009) |
#20 (permalink) |
It says its a 700 on the title, but I was told the engine was swapped for a 750. I later looked at the casting and decided it was in fact a 700 but someone told me today it was a 750 I just wanted to make sure I was not missing something I appreciate the answer. Ok I'm leaning very hard towards the carbs now I took the airfilter housing off and started it and I noticed as you hit the throttle the fuel coming from the needles are more of a broken spray instead of a even mist, does this sound like it could be it? If so I will be pulling them and doing a cleaning following a thread posted earlier in this post. Thanks again everyone.
#21 (permalink) |
almost banned
um have you taken the fuel lines off?
sounds like you have the vacum line and the fuel line swappede?
#22 (permalink) |
Banned
750 vs 700
You will never notice the difference between 700 and 750.
#23 (permalink) |
I have not had the fuel line off but that does not mean that someone else did not mess with them. But would the bike run fine once its at operating temp if the lines were swapped? I'm telling you this bike runs flawlessly after the initial start up.
#24 (permalink) |
Last Online: 11-15-2009 11:08 PM
My Ride: 84 vf750f
if you take your carbs apart, pull your pilot jets out and clean them as well, that and richen your idle mixture a little bit, my 84 750 was doing the same thing and once i enrichened the mixture a little the problem went away
-airgreesemonkey if your not living life on the edge your taking up to much space... |
| The Following User Says Thank You to airgreesemonkey For This Useful Post: | Eddie W (10-27-2009) |
#25 (permalink) |
Banned
Carbs
Have you cleaned them yet? Just askin. If you would like I would gladly go through them for you.If you do them yourself it is not that hard and would be glad to help in any way. I don't charge to work on VFR's......
| The Following User Says Thank You to TOE CUTTER For This Useful Post: | Eddie W (10-27-2009) |
#26 (permalink) |
'86 Yamaha Radian/
'66 Yamaha YL-1/
'88 VTR 250 (2)/
'73 CB 125
Muuther bluuuudy Theresa, ain' it guvna' ??
Make sure he washes his hands aNd cleans his nails and uses hand sanitizer b4 he touches your bike.......,,,,flu, don'tcha know ! PRE-sanitize and disinfect !!!
| The Following User Says Thank You to squirrelman For This Useful Post: | Eddie W (10-27-2009) |
#27 (permalink) |
Last Online: Today 06:49 AM
My Ride: 07 VFR800
93 ST1100
Just read this thread (unless you have it handled already) and the first thing that popped into my head is float level. It's not exactly intuitive on these since the carbs sit at an angle and I frequently find it off spec. If it were a little high, it could tend to 'splash' fuel into the combustion chamber...especially on the kickstand. Try leaving it on the centerstand, and see if it helps.
| The Following User Says Thank You to dizzy For This Useful Post: | Eddie W (10-27-2009) |
#28 (permalink) |
Thanks for the offer Toe but I think I'm a few thousand miles away from you, but that would make a nice road trip lol.
I have not had a chance to pull the carbs off yet but will soon I was reading the manual I had yesterday and it had a different startup procedure than I'm use to it says between 50 and 80 deg. to start with full choke no throttle run for 30 sec. then gradually decrease choke. I'm going to give this a shot and she what it does I will keep you all updated. |
#29 (permalink) |
Banned
Ups
I have another one....ok two more to do in the next month so if you mailed the carbs to me I could test them on a known runner and make sure the are dialed in and send them back....could turn them around in a day or two.
| The Following User Says Thank You to TOE CUTTER For This Useful Post: | Eddie W (10-28-2009) |
#30 (permalink) |
Last Online: Yesterday 01:41 PM
My Ride: 2000, Yellow, 2 Brothers High Mount, Corbin
| 1990 Vfr 750 , Hard Start And No Power. | SHADOWGERARDI | General VFR Discussions | 12 | 08-29-2008 06:11 PM |
| help | adam.roscoe | VF/VFR Mailing List | 3 | 03-25-2007 09:57 AM |
| Re: vfr Digest, Vol 28, Issue 12 | David Thompson | VF/VFR Mailing List | 0 | 07-17-2006 08:00 AM |
| 2003 Clutch Levers | Kyle Allen | VF/VFR Mailing List | 0 | 06-09-2006 10:29 AM |
