Old 10-26-2009, 03:36 PM   #1 (permalink)
mickeymike's Avatar
Last Online: 11-18-2009 05:26 PM
1999 VFR Brake question
I have a 1999 VFR. I replaced the stock brake lines with Galfer stainless lines this weekend, and bled them in the correct order with my MityVac. I have a question regarding the rear brake pedal functioning: When I apply brake pressure to the rear brake pedal, it goes down about 1/2 inch. If I immediately let off the rear brake pedal and apply it again, it only goes down about 1/4 inch. I don't remember it being this way before I re-did the brake lines. Is this correct or is there air in the lines somewhere? I bled the rear lines twice already and still have the same issue; not sure if it is OK or not.
mickeymike is offline   Reply With Quote
Old 10-26-2009, 07:31 PM   #2 (permalink)
mickeymike's Avatar
I think I may have solved the problem. While bleeding the rear lines, I had never "pumped" the left fork caliper master cylinder. I think there was some air in there. After bleeding the entire rear again, the foot pedal is very firm all the time. I didn't see anything in the manual about pumping the left caliper master cylinder, but it seems essential, and I should have thought of it earlier.
Old 10-31-2009, 01:51 PM   #3 (permalink)
Last Online: 11-02-2009 05:15 PM
Read your post with interest....Sounds like a bubbble in the rear line or at the proportioning bleeder under the tank.
I have a 1998 and just bled my brakes, Interesting sequence.
Im wondering how an air bubble in the line betweeen the front left brake and proportioning valve would affect your rear pedal.
It would make sense if your Linked braking stopped working that there was an air bubble between the two.
I cant imagine it affecting the rear pedal firmness unless rear pedal pressure back feeds and pressurizes the LBS line.
I dont recall being able to force fluid out of the LBS bleeder at the front Left disc with the rear pedal....Only by raisng the Front left caliper leading me to believe your air bubble is in the rear line.
Does that make sense?
RC30guy is offline   Reply With Quote
Old 11-02-2009, 01:05 PM   #4 (permalink)
mickeymike's Avatar
I only know that once I pumped the master cylinder on the left caliper and bled the brakes again that my problem was gone. I suppose the air could have been anywhere in the lines.
Old 11-02-2009, 05:15 PM   #5 (permalink)
I would never question a good thing.
It worked...Thats all that matters.
93 VFR Brake Question timbersnake Mechanics Garage 8 06-14-2009 02:47 PM
HELP: VFR '98 Linked Brake Schematic Guillaume.tsouo VF/VFR Mailing List 3 03-15-2007 06:58 PM
Question About 1999 Vfr.. warchild Fifth Generation 1998-2001 2 07-22-2006 11:49 AM
Question from a new VFR owner about R/R Ken_Morrison VF/VFR Mailing List 2 06-12-2006 12:47 PM
2003 Clutch Levers Kyle Allen VF/VFR Mailing List 0 06-09-2006 10:29 AM
