ChatBox (New messages since your last visit: 1)
Old 10-30-2009, 06:41 AM   #1 (permalink)
KingTito's Avatar
Last Online: 11-18-2009 07:12 PM
My Ride: 1999 VFR800 1982 CB900F 2007 Honda Metropolitan (WTF? It's fun, trust me)
1999 VFR, rear hub assembly, lubrication
Pulled apart the rear hub assembly on my Gen 5 as the eccentric adjuster was seized to the rear brake caliper bracket.
In reassemblying all of of this, I was wondering if I should put any sort of lubricant around the eccentric hub as I fit that into the swingarm holder or anything between the brake bracket and the hub and the 75 mm circlip.
My thought was to use something to prevent it from seizing again and it just made sense to me. However, both the Honda manual and the Clymers manual don't say anything and my experience is when they don't call out to grease something, that's for a reason.
So, I went to my Honda dealer who has great mechanics and they thought I shouldn't as it may attract junk which would cause it to seize up and not move freely again.
They thought I should just clean it up really well using WD40 and that would leave a very slight film and that would be adequate.
Any thoughts on whether I should put something there and what if I should?
Thanks!
KingTito is offline   Reply With Quote
Old 10-31-2009, 05:32 PM   #2 (permalink)
squirrelman's Avatar
Last Online: Today 09:57 PM
My Ride: '86 VFR 700Fs (3)/ '97 VFR 750F/ '88 NT 650 HAWK (3)/ '86 Yamaha Radian/ '66 Yamaha YL-1/ '88 VTR 250 (2)/ '73 CB 125
Send a message via Yahoo to squirrelman
AFTER all that work ?...... i'd put a very thin coating of grease wherever things need to rotate or slide.
Wheelbearing grease or white lithium grease.
squirrelman is offline   Reply With Quote
The Following User Says Thank You to squirrelman For This Useful Post:
KingTito (11-02-2009)
Old 10-31-2009, 05:47 PM   #3 (permalink)
ProGeek Wackjob Anomaly
mello dude's Avatar
Last Online: Yesterday 11:04 PM
Thanks!
I never had mine apart, but I think I would tend to use a Moly paste grease on it that Honda sells. -- It probly seized up in the first place due to lack of lubrication.
MD
Member 5th Gen Brotherhood
The Following User Says Thank You to mello dude For This Useful Post:
Old 11-01-2009, 06:58 PM   #4 (permalink)
MD
+......combined with lack of movement.
I've added periodic hub maintenance-- rotation of the adjustment in both directions--to my regular maintenance routine......
cuz i don't want to deal with removal of parts or with that bigass wrench.
Old 11-04-2009, 03:22 PM   #5 (permalink)
Nitrousva's Avatar
Last Online: 11-18-2009 06:46 PM
My Ride: 1993 VFR 750 1975 CB750/1110cc 1974 CB500
There is a product called 'Never Seize', I use it often, and it works.
Nitrousva is offline   Reply With Quote
Parts Catalog 1999 VFR VFR-Rider Fifth Generation 1998-2001 2 06-24-2009 09:47 PM
VFR800 5th Generation - A Gearhead’s Delinking Brake Saga and the Interceptor SS mello dude Brake & Tire Articles 21 05-28-2009 12:55 PM
Looking for rear wheel '94-97 VFR Tim Dunn VF/VFR Mailing List 0 07-10-2007 09:52 AM
RE: Vfr Digest, Vol 27, Issue 46 Zenon VF/VFR Mailing List 0 06-27-2006 02:30 PM
