Hello... I just got a new to me VFR800 and would like to know how to adjust the rear brake pedal height? I would like to lower the pedal so that I'm not always pressing it when covering it.
Anthony
Did you ever get this resolved? I have the same question.......
most of all the ones I have seen have a nut on the bottom of the master cylinder. Loosen the nut and remove lower pin that goes through brake pedal. Tread the rod to where you want it, reinstall pin and tighten nut back down. I am not sure on the 6th gen but you can take a look.
If you follow the link and zoom in on #10 you can see the rod Iam talking about. This is for 6th gen so there is some adjustment.
http://fiche.ronayers.com/Index.cfm/...ASTER_CYLINDER
It's easy, just unbolt the footpeg bracket and go to work
