Results 1 to 11 of 11
Thread: Hello to all
    Mar 2009
    Canal Winchester, OH
    2002 VFR 800
    144
    Hello to all
    Hello all,
    I'm hoping to purchase a 2005 VFR this weekend, and I had a couple of questions for the masses:
    How bad are the regulators on the 05? Is this something that I need to worrk about changing ASAP if it has not already been done? The bike only has 6K on it, so it is still relatively new.
    Thanks in advance.
    2002 VFR 800 Interceptor, Micron Exhaust, Power Commander III, -1 +3 sprockets...
    Pretty fart smeller....
    derstuka's Avatar
    Jan 2007
    San Diego, CA
    1998 Honda VFR800FI
    4,275
    Hello and welcome Josh. It is hit and miss. In general from what I have seen....the 6th gens do not seem to have as many issues with the R/R (regulator/rectifier) as the previous gens did/do. Maybe that is because of the relocation of the R/R to the front of the bike for better air flow. I would not worry about it really. If you really at uneasy about it, you could go to Wire My Bike to grab the bull by the horns and almost eliminate the possibility of it failing.
    My bike is a 5th gen, and the previous owner had the R/R replaced with the upgraded (larger) one before I got it.
    Good luck with the hunt.
    ~Jason
  3. The Following User Says Thank You to derstuka For This Useful Post:
    joshbea6 (03-11-2009)
  4. #3
    Mar 2009
    2002 VFR 800
    144
    Jason,
    Thanks.
    With the rectifier/ regulator problem, what was it that was causing the overheat problem? Was it just the location of it on the bike, or was it a wiring issue?
    Is there anything else that I need to be wary about with the 6th gen's? So far, the Rectifier was the only "warning" that I was told about regarding the bikes.
    -Josh
  5. #4
    Senior Member Slothrop's Avatar
    Sep 2008
    northern lower Michigan
    '96 VFR750F being ridden '58 BMW R60 getting fixed '70 BSA A65T cafe almost finished
    141
    The biggest problem with these bikes is that once you ride it you won't want to do anything else with your life.
    "Then I woke up one morning, and I stepped out of bed
    Had to get a bike, had to paint it red"
  6. #5
    Mar 2009
    2002 VFR 800
    144
    Quote Originally Posted by Slothrop View Post
    That's not QUITE what I was hoping for... especially with the wife and kids... but who am I to turn down a dead sexy lookin bike...
  7. #6
    Nov 2007
    Susanville, Ca
    2000 VFR 800 fi
    4,413
    That should be the only regularly occurring failure. Honda has always had a reputation for quality and the VFRs are no exception. Good luck, and enjoy.
  8. #7
    derstuka's Avatar
    Jan 2007
    San Diego, CA
    1998 Honda VFR800FI
    4,275
    Quote Originally Posted by joshbea6 View Post
    Jason,
    Thanks.
    -Josh
    Well, part of the problem is that the wiring was/is too small of a gauge, the R/R size/fins were too small, and not in an ideal condition (prior to 6th gens). This would sometimes cause the plug going into the R/R to become overheated and melt in some circumstances. In one extremely rare case (one guy on here on a 5th gen) the bike actually caught on fire from a bad R/R when the connector/wiring got so hot it ignited. That was rare though. Mostly your bike would just die, and/or starting function oddly. The wiremybike harness that the guy has designed basically makes everything bigger nad/or more durable. There are some threads on it that can tell you more on it and in greater detail that I explained. I maybe be a little off on some of my explanations, but that is the jist of it.
    Well, the 6th gens from 2002-2005 (06 and on is ok I believe) all need the Honda wiring harness recall performed. If this has not been done (inquire about it from the owner) it will be done free of charge at any Honda dealer. I believe that you can have a dealer run your VIN to determine if the harness recall was performed.
    VFR's are very reliable bikes for the most part......most all bikes have some issue that affects them. Fixing some of Honda's inadequacies is one of them.
    ~Jason
  9. The Following User Says Thank You to derstuka For This Useful Post:
  10. #8
    gun totin' bastage
    300shooter's Avatar
    Oct 2007
    armpit of ontario (Windsor)
    2003 vfr 2007 RWB
    385
    Gospel on that!!
    " Hey, if I can touch 'em, they're not fake"
    2007 RWB- K&N, Throttlemiester,PAIR Valve mod, Scorpion cans,Pazzo levers,Custom fender elim.,Speedo healer,Sargent seat,F2P,Rod's risers,lowered 3/4",ZG, Minor farkles.
  11. #9
    Mar 2009
    2002 VFR 800
    144
    Thanks for the info guys, and keep it coming. This is my first bike in a LONG time, so I'm a little rusty.
    Is there any timeframe that the Wiring harness must be replaced by, or was it a "mandatory" recall from Honda with no time limit?
    -Josh
  12. #10
    derstuka's Avatar
    Jan 2007
    San Diego, CA
    1998 Honda VFR800FI
    4,275
    -Josh
    Mandatory....not sure of a time limit. Don't think there is one. However, I think they get grumpier the longer that you wait from what I have heard....
    ~Jason
  13. #11
    Mar 2009
    2002 VFR 800
    144
    I may need to put a new chain and sprockets on this bike I'm looking at as the chain looks like it has some rust on it. So what I need to know, is based on these pictures, should I replace the chain/ sprockets, or let it go. The bike only has 6000 miles on it.
