Givi topcase with Honda Side Cases?
Discussion in 'Gear & Accessories' started by rikkstrrrrrr, Jul 1, 2008.
  1. rikkstrrrrrr
    rikkstrrrrrr New Member
    ct
    Anyone seen/tried this set up?
    I have a new '07
    I like the matching honda side cases,
    but i love my givi v46 topcase on my st1300.
    (not thrilled about the honda topcase)
    all the stuff i read, photo's i see here don't mix
    the topcase with the side bags,
    either honda top and honda sides
    or
    givi top with givi sides
    anyone try this?
    I should be able to do this with the motec alu-rack for the top case $150, but can't use passanger cowl
    I think I could probably do it with the honda top case rack $250 since i'm guessing the honda top case is made by givi
    just checking around before I try the alu-rack first
  2. flameface
    flameface New Member
    New England
    hope you're not in any rush to get the side bags; they're backordered out into August.
  3. rikkstrrrrrr
    ct
    i just read the oem side case use the grab bar bolts
    if the side case rack uses the grab bar bolts,
    the top case rack uses the grab bar bolts,
    the grab bar uses the grab bar bolts,
    how long does the bolt need to be????
    sheesh, sounds like my wife will have an arm rest.
  4. trogggy
    trogggy New Member
    A Givi rack won't fit because both points of attachment (grab handles and pillion pegs) are also used by the Honda rack.
    You can fit an sw motech rack, though, to carry a Givi box. That only uses the grab handles so will work fine.
  5. rikkstrrrrrr
    ct
    now i find someone saying;
    "SEBSPEED
    I could be mistaken, but I do believe the top box mount replaces the passenger grab handles, so I would assume that the spacers are no longer necessary.
    Help: Mounting Oem Trunk With Sidebags - VFRD
    so that might resolve the side case with the grab bars with the top case question for the oem top case mount
  6. flameface
    New England
    Once you start installing bags and cases, there's so much tubing back there your wife won't need the grab handles any more. There's plenty of places to grab on if she finds it comforting.
