VF 500f Missing dipstick
Discussion in '1st & 2nd Generation 1983-1989' started by Fred12, Aug 29, 2009.
  1. Fred12
    Fred12 New Member
    Victoria BC
    I got a 85 VF500f a couple years ago, and finally got it running and on the road recently, my problem is the oil cap seems to have been replaced by a previous owner with one without a dipstick attached.
    Could someone measure theirs from the flange where it seals to the case to the full level so I can confirm I've got the right level of oil in it after my oil change?
  2. TOE CUTTER
    Dip stick
    You may want to look at the bottom of cap and see if the dip stick broke off and is in the engine .
  3. serjohn
    serjohn New Member
    Just FYI there is a filler cap towards the front of that case and the dipstick is a screw in one towards the back of the case and a bit lower.
  4. Fred12
    Fred12 New Member
    Victoria BC
    heh, oops
    about 45 mins after posting the initial post I discovered what serjohn later replied, there's both a dipstick hole and a filler hole
    :redface:
