IGN - PUMP fuse keeps blowing??
Discussion in 'Mechanics Garage' started by PaWeSoMe, Sep 28, 2009.
  1. PaWeSoMe
    PaWeSoMe New Member
    2001 vfr800 interceptor
    The f1 light is slightly on... like it wants to be on but it's halfway not coming all the way on. Bike is running perfect but when you get on it while riding the IGN-pump fuse keeps blowing out. It is onlyat higher speeds but I did a 160 mph burnout and it didn't pop but when i took it to the interstate it popped before i got off the on ramp! I was runnin the bike and it cut off around 90 - 110ish. Any ideas?
  2. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Probably a short in the wiring harness somewhere if you keep bowing a fuse. I would start by tracing the wires that go to the pump and looking for a bad wire or signs of shorting.
  3. PaWeSoMe
    PaWeSoMe New Member
    I've done this for hours and I just can't seem to run across a bad wire / connection
  4. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Does the FI light go out when the fuse is not blown?
    If not, you need to short the system check connector and see what codes the PGM-FI system is throwing.
  5. nvoges
    nvoges New Member
    Columbus, OH
    I had this happen right before the R/R officially fried. I would check it to see if it's working correctly.
  6. PaWeSoMe
    PaWeSoMe New Member
    I'm new with this R/R thing, What is it and how do you check it? how do you jump the wires to check the codes, and can someone send mea link to all the codes?
  7. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
