Fuel filter???
Discussion in '1st & 2nd Generation 1983-1989' started by TRX250R, Sep 30, 2009.
  1. TRX250R
    TRX250R New Member
    R.I.
    I see everyone kinda bashing a fuel filter. I have a Factory Honda filter on my bike, and runs fine. Why shouldn't I be running one. I have had a couple of race ready 4-Wheeler and always ran a filter on them, and they kicked a$$. So what gives? :confused:
  2. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    What model year?
    If its a 1990 to present they ALL have fuel filters.
    BZ
  3. TRX250R
    TRX250R New Member
    R.I.
    Sorry 85 vf500f
  4. jporter12
    jporter12 New Member
    Johnstown, Ohio
    I think the problem is when a fuel pump is not used. Mine would run out of fuel in the carbs with the filter in there. I should put it back in place now that I have the pump hooked up again...
  5. TRX250R
    TRX250R New Member
    R.I.
    Thanks but all my dirt bikes were gravity fed.
  6. TRX250R
    TRX250R New Member
    R.I.
    Realy no one :confused: Not tryin to be a jerk, I just see everyone bashing a filter, but for what reason? I know their going to say they are to restrictived, but I bought the filter for the bike, it cost me like $30.
  7. jporter12
    Johnstown, Ohio
    I just know that when I had the pump out of the line on MY bike, the filter would not let enough fuel flow. It woul donly be a problem after the bike ran for some time, os it may just need to have more pressure to prevent vapor lock. Since I put the pump back in the line, I haven't put the filter back on. I should do so though....
  8. jporter12
    Johnstown, Ohio
    Now that I think about it, the problem if probably the length of the fuel line, and the routing of it. If you were to make sure it doesn't run back behind the side cover, then back to the engine, and make it more direct, I would think it would be much better.
