929 Shock Installation
Discussion in 'Mechanics Garage' started by jethro911, May 31, 2012.
  1. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    So I'm in my man cave the other night, contemplating what to do while I wait for the next batch of parts. Then I see the 929 shock that came with the bike sitting in a box and think, what the hell, I'll put it in. But I'm out of beer so for just a moment I hesitate. Then, with regained courage, I dive in with both feet. After taking all the stock stuff off including the remote preload adjuster, I lay the two shocks side by side on the bench and see that the 929 shock is almost an inch shorter. Well I have no interest in creating a low rider so after greasing the needle bearings on the shock linkage, I reinstalled the stock shock.
    I know that a number of members have installed the 929 shock on their VFRs so I ask them, what did you do to obtain a stock ride height with the 929 short shock? I thought abount installing a spacer but the upper attach fitting isn't long enough to accomodate a spacer that thick. Edificate me please oh wise ones!
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
  3. jethro911
    jethro911 Member
    Ahhh I see,
    He doesn't describe it but it appears that he machines the top of the shock to accept an extended section to achieve the appropriate center to center distance. Nice!
  4. tinkerinWstuff
    Look at my 5th gen thread linked in my signature and you will find a simple to machine spacer .
    I went higher than OEM ride height. Basically set the bike on center stand with 1/4"plywood under the rear wheel. Then measured length for spacer, machine to fit. Am very pleased with it.
  5. tinkerinWstuff
    Pics located
  6. jethro911
    jethro911 Member
    I like it!
    Simple and functional.
  7. tinkerinWstuff
    was putzing around in the garage today and found my mock-up top mount.
    I never rode with this mount, just used to get my geometry where I wanted it. Adding and subtracting washers to get the length. Then I took the mock-up and a caliper up to the bridgeport to get my measurements and make the aluminum one you saw above.
    I could send it to you if you like
  8. jethro911
    jethro911 Member
    Thanks but I decided that I really like the remote preload adjust and so I will give the stocker a try to see how it rides first.
  9. hollenbeck
    hollenbeck New Member
    easley,sc
    Hey tink I'll take it if you still have it,thanks josh
  10. DaHose
    DaHose New Member
    Napa, CA.
    Measure that up again and post it in this thread Tink. It could be helpful to us shop monkeys who might want to tinker on our own.
    Jose
  11. hollenbeck
    easley,sc
    Hey whats up da house,I got a link for you,I'm doing the same conversion on mine in the next couple of weeks, so here's the link VFR800rr: 929 rear shock conversion .You could tak it too a machine shop and get it done for $20 and used shocks for 40 so you save $400,good luck
  12. rainman6
    rainman6 New Member
    NZ
    Hey Hollenbeck, that looks even easy enough for me to do. I have book marked your guide for a faint day. Thanks
  13. hollenbeck
    easley,sc
    your welcome bro,I was gonna go through jamie @dauterymotorsports but i just dont have the $,but I would do the spring and valve setup through him with the shocks,thats what I plan on doing,I just wounder do I need to throw on the shocks or how can i adjust them for my weight and height/174lbs 6"
