2000 VFR R/R Question
Discussion in 'Mechanics Garage' started by zoom-zoom, Jul 14, 2012.
  1. zoom-zoom
    zoom-zoom Member
    BC, Canada
    I have checked through the forum to do a little research and tested out the R&R on my bike but I have a question about the voltage at idle. Here is a bit of background info on the tests I have already performed. The bike was up to normal temperature at time of testing as I had just come back from a short ride. The battery is new as of May 2012 and I think the R&R was changed by the previous owner. The previous owner has also attached a cooling fan to the existing R & R but since I can not find any markings on the R & R, I am not sure what model it is (ie. stock Honda unit or upgraded unit). None of the connections seem to badly discolored or scorched and are packed with a clearish type of grease (I would assume di-electric grease).
    Battery Condition - 12.69 V (not running)
    Battery Voltage at:
    • Idle - 12.46 V slowly increased to 12.76 V after about 30 seconds (idle approx 1100 RPM)
    • 3000 RPM - 14.21 V (Steady)
    • 5000 RPM - 14.22 V (Steady)
    Oddly enough if I picked the idle up to just 1600-1800 RPM the reading increased to 13.7 Volts
    Stator Check (bike not running) - disconnected the R & R and checked resistance on all three yellow wires on the stator side of the connection
    • Wire A to B - 0.01 Ohms
    • Wire B to C - 0.01 Ohms
    • Wire A to C - 0.01 Ohms
    • Wire A to Ground - No reading
    • Wire B to Ground - No reading
    • Wire C to Ground - No reading
    Stator Check (bike running) - R & R still disconnected and checked AC Voltage coming from stator at idle and 5000 RPM
    • Wire A to B at idle - 17.24 VAC
    • Wire B to C at idle - 17.24 VAC
    • Wire A to C at idle - 17.25 VAC
    • Wire A to B at 5000 rpm - 61.25 VAC
    • Wire B to C at 5000 rpm - 61.23 VAC
    • Wire A to C at 5000 rpm - 61.24 VAC
    After reading through various posts on the subject it seems that just about everyone suggests that at idle speed the battery connection should be reading a minimum of mid 13 VDC and remain steady.
    Since my reading at the battery is 12.46 VDC and over 30 seconds it slowly rises to a max of 12.76 VDC at idle should I be looking at replacing the R & R on my bike??? I am sure that ordering a replacement unit for the bike is certainly a good idea, but I am not sure if the R & R is actually faulty or not. Any help or comments would be greatly appreciated.
    I'm not sure if any one can identify the unit in the pictures but I would like to find out what kind of unit is already on the bike if anyone can tell..
  2. Rubo
    Rubo New Member
    You should do the R/R test with battery fully charged. Should be 13v or close to it.By starting undercharged battery everything else is skewed.
    I would just replace that piece of shit R/R even with fan.
    Read this thread.Must!
    http://vfrworld.com/forums/5th-gene...how-fix-common-regulator-stator-failures.html
    You have the original R/R stock which notoriously famous to fail.Could be at its last leg.Replace (Mosfet type) before it fries the stator.Read the link in the thread.Me and Mello Dude spend lot of effort putting together all the info you need.
  3. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Thanks for the reply Rubo. Though I did not charge the battery just prior to the test, I hooked the battery up to my battery charger just after to check it's status, and the charger showed the battery to be at 98%. The charger is set to trickle charge the battery over night and I will recheck the results in the morning. Thanks for the advice.
    I have checked out your thread and I think I may go ahead with the Compu-Fire unit. Doing electrical upgrades is not exactly one of my best talents but I think it will certainly prevent any failures in the future.
  4. Rubo
    Rubo New Member
    Mello Dude installed CF unit and the thread has lots of photos,pointers etc.Its not hard to install.If you got questions I am sure he can help.
  5. mello dude
    Iran, Islamic Republic of
    2 cents worth - IMHO ---- I think the R/R is aftermarket, but cant identify it. - There is a R/R check with a meter, it might be worth it to run thru that. - I'm kinda at your getting 14v + at 5k, with 13.7 v at 1600 rpm, so I wouldnt be freaking over the idle volts at the moment and I think your fine for now, just ride it, you got time. - You stators good, so you got time to plan your next move when that happens. A voltmeter up front would be at better thing to put some bucks on for now. (Whats the mileage on the bike?)
    On the compufire, I cant emphasize enough about a good installation. Overkill is the word. The part is for Harley so you are modifying it to work on a Honda. Again - warning, no warranty on a Honda. Installation wise you have to cut a strip wires, crimp and/or solder connectors, heat schink tubing, use high quality butt connectors. - You see what I'm getting at, there's no install directions. - if you are unsure about this, find a buddy who is handy with the electric stuff. (Or go with the Roadstercycle kit, its setup to go no hassle)
    --- -- On mine, I spent roughly $175 for the R/R, $25 for connectors, another $25 for end terminals and heat schrink, I didnt have a good professsional automotive crimp tool, (I suck at soldering) so roughtly $90 for that and throw in more $ for miscellanous. So you see, I went all in. I think that's what it takes or your wasting your bucks. ---Simple, neat, clean = reliability.
    --- On your battery - do the charge up and get it load tested....
    BTW - Thank for posting all the numbers for a debug! It helps alot to nail down what is going on.
  6. kennybobby
    kennybobby New Member
    That's a great set of data and very thorough approach.
    It looks like everything is okay with the stator and RR. Don't sweat the 1100 rpm idle voltage because the system is working properly and you don't ride around at idle. Unless you have a brand new battery you will never get 13.7 at 1100 rpm idle because the electrical loads are greater than the output of the alternator at that speed. Unplug your headlight if you want to see it go higher.
    What's the age of your battery? They are consumable items that wear over time and number of discharge cycles and don't last forever. As a battery ages it's voltage decays and you can't make an old battery perform like a new one even if you charge the hell out it. You might want to check the output voltage of that battery tenderizer, they are poor excuse low-cost voltage regulators that boil and cook batteries above 14.4 volts.
  7. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    An R/R can't provide the required voltage, if the input is too low. In your case, the output of the stator is only 17V at idle. You need closer to 20V. I would raise the idle a few 100 rpms, so that the R/R can provide 13V min. If you get stuck in heavy traffic, the draw from the fan can quickly eat up our small battery reserve.
  8. szkimn2001
    szkimn2001 New Member
    new york
    I was having some issues with mine as well in the same area and replaced my R/R with a Mosfet from Roadstercycle.com, the guy builds the kit to your make and model and has it out the next day..Great product for 130 dollars...I only had to shave off the stud do to its size but the bike is running better than it has in a while...my r/r was slowly dying.. New_Kit_CB_irf.jpg
  9. szkimn2001
    new york
    this was the kit i installed, he offer videos and even in person instruction if you are having issues...
  10. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Thanks szkimn2001Out of curiosity, is the kit you mentioned a plug and play item?? I had highly considered the Compu-Fire upgrade, but the thought of chopping in to the factory wiring harness bothers me a little. Electrical testing is one thing but major modifications are a little more daunting, not to mention I don't have all the required tools. My tool box has a fair number of tools but my electrical equipment is sadly lacking as far as anything more useful than the Wal-Mart brand wire strippers and butt connectors. The Wal-Mart stuff might be ok for fixing my 5 year olds R/C toys but not so much for the bikes wiring harness.
  11. szkimn2001
    new york
    All you need for this is a soldering iron.. no tapping into the harness..there could be an issue with the harness itself so this is a direct route bypassing it. This is simply soldering the connections and plugging in and he also offers a kit pre soldered for a few dollars more..You can actually call him with any other questions as well..The fact that it actually bypasses the harness was prime for me do to the age of the bike and the chance of a fried wire somewhere in the harness.
  12. szkimn2001
    new york
    Super_kit_2_irf.jpg this is the kit pre soldered and for 10 dollars more well worth it and again it is Roadstercycles.com
  13. mello dude
    ^^^ I helped install a Roadstercycle kit on a neighbors Suzuki and it went fine. Good product.
  14. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Thanks again for all the options and opinions, and thanks especially to both Rubo, Mello Dude, and szkimn2001 for your help. Special thanks to Rubo and Mello Dude for the previous post how-fix-common-regulator-stator-failure as I used this post to test the regulator and stator in the first place. It is unlikely I would have known how to perform the tests in the first place and would likely have wound up taking it to the dealer and spending a pile of money to get to where I am now. As it is, all I had to spend was $40 on the multi-meter and follow your (Rebo and Mello Dude) instructions.
    It would seem that with either the Roadster Cycle or the Compu-Fire option I will have to splice a connector to stator wire connection, and both installs bypass the factory connections to the harness and hook directly to the battery, is this correct?? If so, which route do you think would be the better way to go. Currently my bike has over 61,000 km's (35,000 miles) and I plan on keeping it for some time, so I would like to make sure I go with the longest lasting alternative and the one that puts the least demands (if that is the right word) on the electrical system.
    Mello Dude
    I read your vfrd article (all of it, and it was extremely well done) on the install of the Compu-Fire system and I was wondering how long ago you completed it, how many miles have you logged since, and does it seem to working ok. I have a friend who works as a mechanic for my local BMW dealership, and he is the GO TO guy at the dealership when it comes to a BMW with an electronic gremlin issue, so I'm certain I could enlist his help with the install. I certainly don't mind spending the extra dollars and time on the install so long as I don't have to worry about it again. It also seems from the article that the Compu-Fire install places a lower demand on the Stator thus making it last longer and since the bike is already higher in mileage (peanuts for a Honda) I was wondering if this would be the better choice.
  15. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Every now and then this site actually comes through with something useful, rather than a tutorial on how to sneak up on sheep.
  16. mello dude
    -- Lessee- On both CF and Roadstercyle you will change the connection to the stator. I guess you could use a stock connector on the R/R side, but why use the stocker any more if its history is to burn up? -- My preference is the MetriPack connector over a direct solder so at some point you can take it apart and do your stator tests. Also they are high quality automotive parts and water tight. If you go this way - go with the 630s. Ask your BMW buddy what crimper tool he has. (As I mentioned my solder skills suck and I have no luck with it so I did the pro crimper thing.)
    ---- I did a huge amount of research before I decided to go with the CF. Some Triumph and Aprilia guys did the install and then a few of the EE gurus on VFRD went that way, and with my technical background, I thought - OK this is the way to go. -- I did the install over last winter, and I probably only have 2000 miles on it. Not a lot of miles yet, but I have 2 bikes. I do have a meter up front and typically idle I get mid to high 13s sometimes 14v and at revs its been goin at 14.3 - 14.5 at the meter. (I think the signal is a little dirty and I may stick a capacitor in line with it to calm it down.)
    Some ideas and 2 cents -- As I commented before, I think your system is fine for now. My guess is the R/R was just replaced in the last season or two or three and has time left. -- You stator at 35k miles is good for now, but they go 40-50k before giving up. -- Maybe that is the time to plan for the CF upgrade if you gotta do it. -Then again if you are at, I gotta do the CF now type of thing, I would be tempted to do the stator replacement now with it too. Also for now as I mentioned, the best bucks spent now is to get a meter on it and watch what is going on.
    Back to the Roadstercycle part or Shindengen FH020AA --- This is a part that is OEM for quite a few bikes in production today so there is a large number out there on working motorcycles. Its a very good product as a MOSFET and a shunt design. I am not going to say dont go that way. Contrast to the CF, its been in production for 8 years and manufactured for Harley replacement. Only in the last few years have guys been adopting on other bikes. So there are not as many on non- Harleys to get a large reliability data point. Some guys arent comfortable with the lower number out there. I am a perpetual experiementer so as a geek foole I was fine with it.
    Which is better?
    Tough argument - My thoughts are any shunt type R/R the excess voltage is being dumped as heat and the stator is running full time. MOSFET does a very good job with it. (Kinda nice oil heater) - The series design switches on and off as voltage demand requires and the same demand on the stator. Stator runs intermittantly. (Somewhat cooler oil temps) -- The difference is something like having full throttle and controling volts with brakes (MOSFET shunt) or controlling volts direct with throttle (Series). From a technical view a series makes more sense.
    A caveat --- I cant claim to be a guru, you need an EE degree for that. But I am an ME geek foole, sometimes anal wrench turner - and with bike charging systems, I think the right term would be accidental journeyman.
  17. kennybobby
    Whoa the BS meter is pegging out!
    Timeout! Somebody has been blowing smoke up your ass. There is no series regulator available for a permanent magnet alternator (the type used in motorsickles) no matter what kind of BS gets slung by the harley doods.
    There is "shunt" regulation using either diodes, thyristors, SCRs,
    http://vfrworld.com/photos/data/1255/rectumfier_specs.jpg
    fig.2
    or transistors (FETs or MOSFETs) fig.3
    to switch the current to ground in order to regulate the voltage, or there is "open" regulation using SCRs to interrupt the alternator output before it reaches the rectifier stage. fig.4
    A "series" regulator is the type used in automobiles in which the magnetic field of the alternator is generated by an electric current in the rotor winding. This current can be turned on and off as needed to regulate the output voltage and is supplied thru a SLIP RING BRUSH SET.
    Unless your alternator has a set of brushes there is no way to use a "series" regulator--it makes no sense.
  18. mello dude
  19. Rubo
    Rubo New Member
    ZZ don't feel bad cutting stock plugs (stator to R/R) since this is poorly designed plugs often resulting in burning and melting.
    I have no experience with Compu-fire. I installed 2005 used Mosfet Yamaha R1 regulator with beefy wiring and fuse box.I installed Metri-pack 630 fuse box[​IMG]
    My cost came under $150. I did buy good soldering tool since I believe that is a must have.
    R/R Connectors
    great wiring straight to battery with a fuse holder plus 2 fuses 1extra $25 nice deal.
    Part A - the Battery Connection
    FH012/010 Connectors with Leads
    Part B Stator $15
    Don't need anything else.
    You can buy R1 new regulator new from Roadstercycle-Index for $100
    I prefer metri pack 630 connections which the link I provided.
    You can easily install this.Buy decent soldering gun and you are good to go.
  20. CRFan1
    CRFan1 New Member
    Northwest Indiana
    I just installed the Roadstercycle super mosfet kit (the one that is basically all soldered up minus the stator wires) and it was pretty simple. Taking my time and really doing it right took about 2.5 hours. Only mod was drilling a different hole for one of the RR mounting bolts (I rotated the left side up a bit) and grinding down a little on the left, top few fins so it fit under the plastic cowl. Super easy really. I also chose to just solder direct to the stator wires (had to solder in 3 wire extensions).. Used heat shrink tubing on all connections and electrical tape and wire loom tubing on everything to protect it. Getting 14.13 volts at 5K and with my idle at 1400 rpm's (I like it there :)) I get 14 volts give or take. Now I know I can ride worry free.
    Oh and the stock power connector that gets unplugged from the stock reg just gets taped up real well and ty-wrapped out of the way.
    Good luck!:cool:
