Vibration
Discussion in 'Mechanics Garage' started by Anaconda, Sep 17, 2012.
  1. Anaconda
    Anaconda New Member
    Brampton, Ontario, Canada
    Does anyone have any idea what could be causing this. Whenever I go over 125 KM/hr, I get this pulsing vibration. It is not a constant vibration. The bike shakes about every 2 seconds. Could this be that the wheels are not balanced properly? When my new tires were put on about 8,000KM ago, they were not electronically balanced.
    I am running with 36 psi front and back (don't know how accurate my digital gauge is).
  2. kennybobby
    kennybobby New Member
    Can you tell where the vibration feels to originate? Are the handlebars shaking side to side, or is it thumping from under the seat, the front forks oscillating up and down, looseness in the frame, hammering in the motor, does it all the time, only on straights, only in curves, etc.
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    If it just started vibrating when the new tires were installed.........I think you have the cause. You say that was only 8 kilometers ago? You must live close to the dealer! You must mean 800 kms??
  4. Anaconda
    Anaconda New Member
    My correction. I meant 8,000 KM. I did not really notice the pulsing until recently.
  5. Bryan88
    South Africa
    Durban, South Africa
    I used to get a pulse (more of a sound than a feeling though) about 1 sec apart at exactly 4000 rpm, Perhaps yours is the same kind of thing? Check to see if it's speed or rpm related.
  6. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Check the chain as well.....
  7. risgett
    risgett New Member
    Florence, SC
    I would get over that speed, pull the clutch in and coast just to make sure it's not an engine vibration. If you haven't hit anything to bend a rim, I would suspect the tires. Everytime I've had a vibration, it's been the tires. Just my two cents...
  8. actungbaby
    actungbaby New Member
    yeah my 92 has that vibrartion at 4000 rpm too a roughness smooths out above and below
