Clear Turn Signal Lenses/LED Tail Lights
Discussion in '5th Generation 1998-2001' started by Greyman, Oct 29, 2012.
  1. Greyman
    Greyman New Member
    Richmond Hill, Ontario, Canada
    I have been looking for clear turn signal lenses and tailights in LED. Has anyone changed their amber turn signals to clear? Does anyone have a recommended online store that is repuatable where i can purchase? Thanks for your suggestions.
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Thurn Motorsports has them. They are located in Germany and have quality stuff but its a bit pricey. Link below
    Blinker-Leuchten-rc46/1
    Rollin
  3. Greyman
    Greyman New Member
    I appreciate the contact information. Thanks.
  4. DaHose
    DaHose New Member
    Napa, CA.
  5. hollenbeck
    hollenbeck New Member
    easley,sc
    I just bought some off of ebay,from a seller called lightsforbikes and they are awesome,quick shipping and good comunication,now I'm trying to figure out how to put them on lol. go to this page
    vfr800 from lightsforbikes | eBay
  6. krsmetalhed
    krsmetalhed New Member
    Stafford Virginia
    I just installed the clear led taillight assembly listed above. Looks pretty sweet on the bike and illuminates well. Sorry no pictures yet.
  7. Keager
    Keager Member
    well get on it man! :worthless:
  8. krsmetalhed
    Stafford Virginia
    Keep in mind how dark it was during these pictures. The flash made the leds seem dim, but thats not the case at all. No extra tag light needed because the leds light the plate with white light.
  9. Floydy
    Floydy New Member
    Cambridgeshire
    Hi
    I am considering fitting these to my bike. How is the flash rate, do they flash too fast or require extra hardware to work correctly?
  10. Floydy
    Floydy New Member
    Cambridgeshire
    I purchased 'HONDA VFR800 FiW1 98-01 LED REAR LIGHT WITH INDICATORS' from ebay for £90
    I found it to be well made, easy to fit (had to check polarity of each connector and reverse if needed)
    In strong sunlight the indicators seem quite dim
    The flash rate of the indicators was normal and no other fittings or hardware was required. Everything that was needed for the item to work was supplied
    NO fitting instructions were included
    The number plate is also illuminated
    At night these are very bright as can be seen in my attached picture...
    Pros:
    Great looking
    Easy to fit
    Financial saving over OEM part
    Cons:
    No fitting info
    Indicator quite dim in strong sunlight
  11. Alfadiablo
    Alfadiablo New Member
    Gibraltar
    Gibraltar, Gibraltar
    I'm contemplating fitting these on my 98 too, but can't make my mind up between the clear or smoked versions. My bike is a funny mix of silver/gray. Opinions would be appreciated.
