fuel filter ??
Discussion in '7th Generation 2010-Present' started by lshark, Aug 20, 2013.
  1. lshark
    lshark New Member
    NY
    the VFR1200 doesn't have a fuel filter does it ??
  2. CMG241
    CMG241 New Member
    Southern NH
    It must - and I would love to know where it is! Just got mine last week and have been looking for directions to remove tank. I assume it is in the tank or on the line between the fuel pump. Looked everywhere online and no one stock them.
  3. skimad4x4
    skimad4x4 "Official" VFRWorld Greeter
    France
    French Alps & London
    I am not so sure they do. IIRC Goldwings did not have a fuel filter when they left the factory - and I think many owners promptly decided to install aftermarket in-line filters just in case they ended up with some grotty fuel.
    I suspect this may be another Bean counter decision - x thousand motorbikes x 3? dollars per filter = bigger profit. If bad fuel actually causes issues - then its inherently the fuel suppliers fault - and it also means their dealers will get some additional paid for workshop hours sorting out any resulting problems.
    If you want to check - nothing shows up on the official schematics -
    http://www.bike-parts-honda.com/moto-honda-identification-VFR1200FA-13788.html
    Hey Ho...
    SkiMad
  4. CMG241
    CMG241 New Member
    Southern NH
    Thanks and wow that is maddening - no filter? Pulling tank Sunday, before I assume its a 3/8" line and grab an in-line filter I will peek and then run to parts store. Thanks again, Chris
  5. Terry Smith
    Won't there be a tea-bag strainer on the pump inlet? I thought all FI bikes had that.
  6. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Most modern FI systems don't use inline filters as others have mentioned. At most you'll have some type of strainer filter attached to the pump. Keep in mind anything you add after the pump would have to be able to handle the fuel system pressure. Personally I think Honda's engineers did their homework. I'd leave the system as is, but thats your call.
  7. CMG241
    CMG241 New Member
    Southern NH
    I have a sometimes bog in lower gears, not consistent so hoped it was just a filter issue. Thanks
  8. satariel666
    satariel666 New Member
