Best Reg/Rec Upgrade
Discussion in 'Mechanics Garage' started by vfrweiser, Mar 19, 2014.
  1. vfrweiser
    vfrweiser New Member
    Phoenix, AZ
    Ok, so it's quite clear that the OEM r/r and wiring harness are weak links in a pretty reliable chain. I've read a handful of posts on the subject and found a handful of upgrades that can be done.
    The question- What is the best R/R / Harness upgrade? (Considering cost, reliability, availability, minimal hackery,etc.) I know allot of you guys know what's up!
    2000 VFR800FI
    Sent from my SGH-S959G using Tapatalk 2
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
  3. ZEN biker
    ZEN biker New Member
    Assiniboia, SK
    Its like any other electrical system. Do the maintenance and you wont have the problem unless something goes very wrong. Cant predict rubbed wires nor melted wires, but you can keep the stock r/r going by doing the services needed. Stator should not fail unless over drawn so keep farkles to the minimum. The weakest point I can find is the bad decisions made in choosing connectors and calcing load to heat dissipation of the individual pins. Eg the r/r connector melts as it handles 35amps but the connector is only a single pin for all that and should have had 3.
    Be proactive not reactive. Replacing the r/r because you feel its weak based on forum posts is not proactive as it will fail eventually.
  4. safetypro10
    safetypro10 New Member
    Dallas, TX
    My vote id for the yamaha R1 unit. Wires up easy, huge heat sink, heavier duty. Than do the rest of the system and don't let battery get discharged so it needs heavy charging while riding.
    And add a voltmeter to monitor system condition.
    Actually I used a Hayabusa unit do it it being mounted on its own heat sink plate. A little doctoring required.
    Larry
  5. mello dude
    www.roadstercycle.com --- Its the Shindengen FH020a R/R. And, wire it direct to the battery. Fuse on the pos side.-- No VFRness needed. ---- Stator connector -- Metripack 480 (40amp) or 630 (46amp) - Crimp tool required.
    +1 for the voltmeter up front.
  6. Allyance
    Allyance Insider
    Germany
    East Bay, California
    I just bought and installed a Shindengen SH775 R/R, the series model (same size as FH020) because of my LED lights, will fit on OEM bracket with a small mod, bracket is required because it supports part of the fairing system. If you go this route, this is what you need to do:
    Small flat head to mount to frame, long flat head to mount R/R, enlarge holes to countersink.
  7. mello dude
    Not knocking the SH775 (Rated 30amps) or series R/Rs but one of our fellow brethren VFR riders had the 775 die after a high rev incident. I'm thinking the one to grab will be the 50amp unit, once Shindengen gets the unit fully validated and qualified for production.
    - I am running the Compufire and a big fan now of series R/Rs. The bike does run cooler, and it may be bs , but it seems to rev a tic quicker.
  8. vfrweiser
    Phoenix, AZ
    How do I get my hands on those connectors? Went to website, can't find prices or way to order any??
  9. Allyance
    Allyance Insider
    Germany
  10. vfrweiser
    Phoenix, AZ
    My r/r has the the yellow stator leads, two green ground, two red positive, and one black sensor lead. What happens to the black wire is I use the 775 kit?
  11. ZEN biker
    Assiniboia, SK
    The black is a ground wire, the two reds are different gages, the smaller id the sense wire. Run the black and two reds to the battery. The stator leads just hook them up in any order. it doesnt really matter much, since we dont have schematics for the stator nor r/r to make the system balance properly.
  12. vfrweiser
    Phoenix, AZ
    Ok, so what about the green, aren't those ground?
  13. ZEN biker
    Assiniboia, SK
    Im going to have to pull your schematic to make sure as the green wires should go to frame while the black goes to batt neg. We use the same r/r on the 6th gens just different connector and color codes.
    I am at work tonight, so ill respond by 1500pst tomorrow with the exact answer for you. If you have the 5th gen service manual, the schematic is in the back chapters on electrical.
  14. Allyance
    Allyance Insider
    Germany
    When I installed my SH775, it did not have the fifth lighter gauge black wire my stock R/R had.
    In looking at the wiring diagram in my manual, it shows it (actually White/Black on diagram) going to Engine Stop Switch to supply +12volts.
    I replaced two reds and two green 12v DC output wires with #10 wires directly to the battery. Since 5 pin connector was not being used, I jumpered the Black connector to the Red +12v connector to supply 12 volts to Engine stop switch (Red/White wires were still connected to battery).
    Wire on left of connector goes to Engine Stop Switch.
    Diagram also shows it going to bank angle sensor as well:
  15. vfrweiser
    Phoenix, AZ
    What needs to be done with the red/white wires? Do they just go straight to the battery, or do they supply power to something else as well?
  16. Allyance
    Allyance Insider
    Germany
    They are still hot, tape up end of connector to protect contacts, and tuck out of way.
  17. vfrweiser
    Phoenix, AZ
    Could I utilize the single red/white wire to connect the white/black to it after the fuse? Or would I be cutting off another circuit at that point? I'm trying to get my hands on an accurate wiring diagram at this time, that way I can figure it out myself rather than continuing to ask silly questions.:/
  18. Allyance
    Allyance Insider
    Germany
    That's what I did.
