I just send my ECU to Don Guhl... Here is what I'm thinking should be done: 1. Remove the 1st and 2nd gear power restriction 2. Revise fuel map 3. Increase the RPM limit setting by 500 RPM 4. Disable the alarm code for the servo motore(because I have another exhaust installed and motor completely removed) 5. Install a Dynojet fuel map directly into ECU if possible 6. Eliminate the top speed limiter for 5th and 6th gears if possible 7. I would like to leave the fan and thermostat (temperature) as is so it doesn't stay on most of the time. Am I missing something? Thank you
