I recently purchased Powerlet heated jacket liner and gloves. One of the good features is the jacket has the option to pull 60W or 150W. I have been running it in the 60W mode, but would like to try the 150W to see the difference. Can anyone tell me if this is too much pull from the battery? From what I have found on the web our bikes have approximately 250W of extra power, but simple things like using your bright lights take up 100W of that extra. Any insight would be greatly appreciated. Thanks! Brad
I don't think it is matter if you only use while fying Your light and heated gears only consume about 190W so the OEM should be fine. You can always up grade to 350W stator if you want to be safe, remember more watts is not always better.
