License plate Light required?
Discussion in 'Mechanics Garage' started by Dean_Fuller, Oct 9, 2006.
  1. Dean_Fuller
    Dean_Fuller New Member
    Knoxville, Tn.
    Is the light above the plate REQUIRED by law? Or can it be removed and still be legal? I live in Tennessee.
  2. RVFR
    I took mine off during the trim up thy rear fender process. But I believe DOT regs say it's suppose to be there by how the law reads. If it's an issue which so far it has not been one from being stopped more than a couple times, the rear plate light never comes up. There are after maket plate bolts that have LED lights in em so thats a good back up plan, so till I get told it's a have to have, I'm leaving well enough alone for now.
  3. Action
    Action New Member
    Albuquerque
  4. KC-10 FE
    KC-10 FE New Member
    Communist Peoples Republic of NJ
    Yep, required by law in all 50 states.
    KC-10 FE out...
  5. Dean_Fuller
    Knoxville, Tn.
    I wonder when the kits to eliminate fender are applied that light goes bye bye....Am I to take it that it makes the bike illegal?
  6. Action
    Action New Member
    Albuquerque
    I'm sure it does, just like when you put on most, if not all, aftermarket pipes.
  7. KENJI
    KENJI New Member
    Phoenix, Az.
    I just installed a Comp Werkes kit, and the mtg plate has holes drilled in them to mount the stock lic plate light. Mines an '05 VFR. Kenji
  8. RVFR
    Those will work, same idea and they look good too.
  9. Rev
    Rev New Member
    Olympia,WA
    No plate light on my '94, been that way for nine years. Nobody ever notices.
  10. mello dude
    I did a fender clean-up and considered going lite-less. After considering the local authorities though I thought some lite would be wise. I used a low profile LED light that I found on line. Turned out pretty sharp. Check it out in my gallery under fenderectomy.
    MD
  11. hoytshooter
    hoytshooter New Member
    Light
    When I cut my fender I eliminated the license plate light. Being the paranoid type I am I cut the bottom out of the tail light lense then covered it with a clear plastic piece which allow light on to the plate. Works ok and is probably close to legal. The only draw back is that it gets brighter when the brake light is applied
  12. ZonaMan
    ZonaMan New Member
    Tucson
