Opinion for new Battery and chain ?
Discussion in 'Mechanics Garage' started by VFR714, May 22, 2016.
  1. VFR714
    VFR714 New Member
    Hi all,
    I'm looking for new Battery and chain for 2007 but not sure which one. Can anyone give me some options please?
    Ps: grease and sprocket also.
    Thank you,
    Tony
  2. fabio222
    fabio222 New Member
    Motobatt for a battery. DID, RK, Regina are all quality chains. JT sprockets are very good although their own brand chains apparently aren't great...so I hear, could be wrong!
    Sent from my 2014811 using Tapatalk
  3. Terry Smith
    New Zealand
    ^^^ I agree with all of that. I've been running Motobatt batteries, no complaints from me, likewise the RK or DID chains.
  4. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    I'm in line with everyone else with chain and sprockets but I went with a shorai battery. My last regina chain and sprocket kit lasted 40k miles. For chain maintenance get an automatic oiler like pro- oiler and a rag to wipe the chain from time to time.
  5. RVFR
    For a battery, and by saying this lets hope Murphy ain't around, if and when, I'm going with one of those new lithium ones, small and light. On chains yep I'm a OEM guy when it comes to sprockets, yes DID or RK is cool.
  6. VFR714
    VFR714 New Member
    Thank you guys
  7. Expvet
    Expvet New Member
    Brooklyn, NY
    Motobatt, DID and OEM spockets, especially the front one. It has a rubber vibration dampner that aftermarkets do not.
  8. VFR714
    VFR714 New Member
    I end up got Motobatt and RK package. This is my first doing it, how hard is it? Does it require any special tools?
  9. Aimbot9000
    Mount Holly,nc
    Yes you'll need the spanner to loosen the chain slack. Should be with the tool kit that comes with the bike and a Chain Breaker & Riveting Tool. Its not hard just take your time and watch some how to videos. Oh and don't accidentally hit your clutch lever after you take the front sprocket cover off lol
  10. Expvet
    Expvet New Member
    Brooklyn, NY
    First you should go and Youtube a couple of how to's for chain replacement to give you an idea of the procedure, not very complicated. When I changed mine I rented this tool from the below link. It is the best chain tool you can get, the price covers ship to and back. You can use a grinder or dremel to grind off a pin head which then makes it easy to press out. You will need a torque wrench. You should also get a digital caliper tool to measure the pin head spread when you press on the master link, the specs should be in the RK package. Don't go for a clip on link, they are unreliable.
    http://www.ducatitoolrental.com/Tool_Kits.html#Chain_Kit_1
    If you do not have a service manual below is the link to download one from VFRD. Make an account if needed.
    http://www.vfrdiscussion.com/index....onda-vfr-service-manual-optimized-bookmarked/
  11. VFR714
    VFR714 New Member
    Thank you guys,
    Battery and chain are here except lubricant. Watch some videos and it's not bad at all.
    Have a great holiday weekend guys,
    Tony
  12. VFR714
    VFR714 New Member
    Front don't look the same and want to make sure it's correct. It's thinner than original. Part said fits vfr800 2007.
  13. Allyance
    OEM gear has rubber dampening on it, mechanically the are the same.
  14. VFR714
    VFR714 New Member
    Cool want to make sure.
  15. Sniper
    Sniper New Member
    I'm a day late and a dollar short, on this thread.
    Shorai Battery. Saved my ass once. I have 6 of them, various ages. I never had a problem with any of them. I replaced the 5 year old Shorai that was in the KTM Super DuKe. Super Dukes are notorious for destroying batteries. I gave that battery to a friend who put it in his Honda Rubicon, with a wench. It's still going strong.
    DID Gold chain. I got the Motion Pro tool. Changed out the rusty old stocker on the Interceptor. It was actually kind of fun. The new gold chain looks about 1000X better.
    Good luck, Tony. Tell us how it went.
  16. VFR714
    VFR714 New Member
    Replace battery, air filter as the same time. Need to put back together. Can anyone confirm front sprocket nut 55lb tight for torque please?
    Thank you everyone
    Tony
  17. V4toTour
    V4toTour New Member
    I've been running nothing but RK xring or wxring for a few years now. DID is fine too.
  18. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I normally run DID, but in less than a year, the price went up more than $65 ... WTF??
    I just ordered an EK 530MVXZ (Quadra-X Ring Chain). Hopefully, I haven't made a $65 mistake.
  19. Terry Smith
    New Zealand
    51 N-m or 38 ft-lb is specified in the service manual.
  20. VFR714
    VFR714 New Member
    Thank you Cadbury. Putting back and test drive soon.
