Results 1 to 23 of 23
  1. #1
    Join Date
    Aug 2015
    Country
    Posts
    Corbin Beetle Bag Hardware, 5TH Gen
    Call me a glutton for punishment, but won an auction for set of 5TH Gen Beetle Bags. After questioning the guy about hardware, he says that he will look but does have some bolts and stuff. Day of the auction, I don't reread and get the bags. He hasn't mailed them yet, and with him being so slow in mailing them, I could probably cancel the order.
    Here's the deal. How hard would it be to fabricate the mounting hardware? I've found pics of the installation instructions with somewhat blurry pictures of the hardware parts, bits and pieces, and the bags mounted highlighting some of the mount points.
    Again, is it worth the trouble?
    Anyone have good pictures of the mounting hardware or willing to take a few for me?
    I'd sure appreciate it! I'd PayPal you a beer or two
  2. #2
    Join Date
    Aug 2016
    Location
    Reseda / LA
    Country
    My Ride
    1998 Honda VFR800 - Back in Red! 2003 Aprilia Tuno 2007 Aprilia Tuono
    Posts
    119
    Do you have the tools, equipment, skills to DIY it?
  3. #3
    Join Date
    Aug 2015
    Country
    Posts
    In school, I worked in an iron shop/fabrication where I was the factory's drill press operator. There, I leaned how to art and structurally MIG weld. I was always building and making repairs. During that time to finish a paper and compete, I enrolled in auto mechanics and received my certificate (the teacher was a rider).
    The skills are there, and I know of a mature gentleman wanting me to turn some wrenches who has a couple of welders. I have not checked if he has a welding table, as most of his jobs were repairs to chassis and such. I haven't spied any of the tools for truing, but there are two Harbor Freights around. I have hopefully found a powdercoater in the area, maybe even two that take non-commercial customers.
    If I get better pictures along with the bags in my hands, I believe that I will be able to work some magic. With some of Honda's mounts for the trunk and luggage, I have seen the construction techniques. From the pics, it looks like some solid square stock, tubing, and sheet metal, all cut, bent, drilled, assembled and welded. I could not tell if nuts were welded onto the sheet metal or if tubing was welded and threaded.
    At the very least, skill...check.
    Tools, some.
    However, at the end of the day, if I could have some good pics, maybe with a ruler beside a piece or two, I could make some drawings and find any of some local shops to fab the pieces or maybe the bending...
    If you have some pics for me, that'd be great, or of someone willing to get me some good Kodaks.
    Thanks.
  4. #4
    Join Date
    Mar 2016
    Country
    Posts
    142
    Hey ridnout - good for you, your initiative is admirable. I just sold a Corbin Smuggler to Guoseph on vfrd. He sent me photos of the Smuggler nestled between a set of Beetlebags mounted to his 5th gen - it is a fantastic looking kit! If you decide not to take on the fabrication, you won't have a hard time finding someone to buy the Beetlebags [Call me!]
  5. #5
    Join Date
    Jul 2012
    Country
    Posts
    Were they the ones in Denver recently on eBay? I have been looking for the mounting hardware for 2 years. I did find the PDF of the Corbin instructions some time ago and it shows what the hardware looks like. When I can find the time, I think I can put something together, it doesn't look very complicated. Good luck!
  6. #6
    Join Date
    Jan 2015
    Country
    Posts
    I have the setup. I can take pics for you.
  7. #7
    Join Date
    Aug 2015
    Country
    Posts
    I found the pics on this forum or VFRD bnick3. After going back and looking a second, third, and forth time, yes, they don't look that bad to fabricate. However, I'd like for you to share with myself and the group what you have if not too much trouble. Are you offering to fab them?
    Thanks dvo. That'd be great, especially if you took them off along with a ruler beside each item or one or two so I can get the relative lengths.
    For the most part, looks like sheet metal, square tubing, threaded tubing and what not.
    Oh, and yes, these are the ones from Denver. It was a beast getting communications established with the guy.
    Just got them in Friday. As of writing this post, the screws or whatever that was sent have nothing to do with the mounts--just some run-of-the-mill bolts and some washers. The insides are clean-ish, nothing torn--smell of garage fumes though. I will need locks and will be contacting Corbin. The hinge on the left is spot on. The right side bag hinge axle is a bit loose inside the barrel thus having a bit of lateral play when closing. It does not stay locked as the lefty, just a pull and open. Upon closer inspection, the plunger/lip (?) is worn. The left side's lip looks to have little wear. Maybe the right one was forced closed; however, I see no other indication by looking at the tongue (?).
    On a side note, I wasn't going to expect a great paint job considering the pics and the sellers willingness to take those pictures on their sides on the concrete. Since he did not mention any of these details, I will be trying to make contact to see if we can come up with a relatively small partial refund. I didn't expect the locking mechanism and hinge to be a bit wobbly. He looks to be a new seller and didn't include much detail; however, those maladies look to be curable.
    Now, as far as utility, they definitely will not compare to the 6TH Gen's factory setup or anything else for that matter; however, the 6TH is the commuter, the everyday. I was able to get my Lenovo Twist in there but am not going to anymore. A Ventura rack or something custom would be better, maybe even a mount for the 6TH's trunk--won't be riding both at the same time. Oh, but hopefully, my girlfriend & I will be touring on both at some point.
    It is enough to stuff in some rain gear, extra gloves/gauntlets, basically those things that may go left behind or stuffed in pockets. The Ventura rack would probably complement bags nicely by adding some useful utility like strapping down a backpack or such.
    Thanks for replying and much appreciative for the offers and encouragement.
    P.S. Hitting "Post Quick Reply" doesn't jive with these long-ish posts of mine : )
  8. #8
    Senior Member RDMCD's Avatar
    Join Date
    Sep 2011
    Location
    London Ontaorio
    Country
    My Ride
    2000 vfr red
    Posts
    144
    Still need pictures? I have my bike tore down and could pull the mounts off if needed.
  9. #9
    Join Date
    Aug 2016
    Location
    Reseda / LA
    Country
    My Ride
    Posts
    119
    Quote Originally Posted by RDMCD View Post
    Oh, I'll bet he does. Wink wink snap snap grin grin, say no more!
    Give a man a fire and he's warm for a day, set fire to him and he's warm for the rest of his life.
  10. #10
    Join Date
    Aug 2015
    Country
    Posts
    Yes, please.
    LOL Lee. My middle name is Lee.
  11. #11
    Join Date
    Sep 2011
    Location
    London Ontaorio
    Country
    My Ride
    2000 vfr red
    Posts
    144
  12. The Following User Says Thank You to RDMCD For This Useful Post:
    ridnout (04-09-2017)
  13. #12
    Join Date
    Jul 2012
    Country
    Posts
    Sorry ridnout my post wasn't clear. What I meant to say was that the pieces don't look that difficult to put something together that will work and hopefully I can get around to fixing mine this year. Not lookin on taking on any more projects, lol.
    RDMCD you are the man with the pics!
  14. #13
    Join Date
    Aug 2015
    Country
    Posts
    Totally awesome, quadrille paper with 1/4" squares. That puts me in a pretty good ballpark. Thanks a bunch.
    Oh yes, do you have that seat release tab extension bracket installed as well?
    Oh, what are the sizes of the bolts for your regulator? The stock ones don't work with the eBay replacement, a bit too short.
  15. #14
    Join Date
    Sep 2011
    Location
    London Ontaorio
    Country
    My Ride
    2000 vfr red
    Posts
    144
    I bought mine used and they were missing the right side bracket if I remember correctly. Had it made from the crappy pictures on the corbin site. I didn't know there was a seat release extension... you don't need it. All the bolts are 3/8x1 except for the nut welded on the bottom bracket. It's metric and uses the stock muffler bolt.
    My regulator and bolts are stock for a 2000-01, but may be different than a 98-99.
    If you need any exact measurements let me know, it'll be going back together in the next day or two.
  16. #15
    Big_Jim59's Avatar
    Join Date
    Dec 2009
    Location
    Dallas, TX
    Country
    My Ride
    2000 VFR800 1972 Suzuki TS125 1985 Honda XL185 1970 Honda Z50 VTR1000 Superhawk 1970 Honda Z50
    Posts
    1,818
    I saw those bags on ebay but I had to pass. There were just too many hoops to jump through for me.
    In the land of the blind the one eyed man is king.
  17. #16
    Join Date
    Aug 2015
    Country
    Posts
    RMCD (& others):
    Finally found the thread right here in the forums that have what I believe to be the same exact pics of installation that I once upon a time downloaded from Corbin's site --> http://vfrworld.com/forums/showthrea...n-Instructions
    I will save your pics, print them to scale, make some templates and go from there, not at the top of the heap, but definitely not at the bottom.
    Thanks again.
  18. #17
    Join Date
    Aug 2015
    Country
    Posts
    Wow, I believe I have enough now!
    I had previously contacted Guoseph on VFRDiscussion who made this YouTube video: https://www.youtube.com/watch?v=-GN2J1pB1XU
    He also sent additional pictures that are available at https://www.flickr.com/photos/674335.../shares/3ZfBM1
    The added detail shows me for some of the mounts of the offset pieces. I wasn't for sure at first. Now with the earlier pics plus this video/picture combo, I believe I'm well on my way. Kudos to Guoseph and others for taking their time out to help me out. Wow. First Class. Now where's the tears emoticon? Just kidding. Now I'm about to PM Guoseph and reference this thread.
  19. #18
    Junior Member Guoseph's Avatar
    Join Date
    Oct 2016
    Country
    Posts
    If you have any other questions feel free to ask.
    Btw the bags scratch real easy so make sure you have something soft under them when putting them on the ground.
  20. #19
    Join Date
    Oct 2016
    Country
    Posts
    Oh and there's a bit of a quirky catch 22 when you are mounting the bags for the first time.
    The middle hanging brackets that go under the rear cowl and attach to the passenger peg mounting bolts are hard to line up, so you kind of have to leave them loose when trying to get all the bolts to line up. But if you tighten the cases before reinstalling the cowl they will interfere with the frankenbolts, so you have to tighten the bracket with the cases mounted, then loosen the cases enough (or take them off) to get the rear cowl back on, then tighten the cases again.
    And I don't recommend using a rear top cowl like I did in my profile pic unless you remember to pull your tool kit and put it in one of the side cases, cuz there ain't no way of getting to what's under the seat without major surgery.
  21. #20
    Join Date
    Aug 2015
    Country
    Posts
    Wow, so many caveats almost outweigh the benefits of the bags...
    Would a Sargent World Sport two-piece seat and/or quick release pins (Frankenbolts) remedy the cowl situation for quicker removal to the under seat area?
    With the World Sport Seat and rear seat cowl attached, I believe you cannot mount the pillion saddle. If that is the case, eventually going to get that seat, would quick removal be possible by using removing the Frankenbolts/quick release bolts and using the key.
    Do the bags interfere with the Frankenbolts; forgive, but a bit lost.
    Thanks again.
  22. #21
    Join Date
    Aug 2015
    Country
    Posts
    Like to add that it seems there are still Corbin Bags available from Corbin.de. They are in the basement's basement and "on sale". Here's the link (I used google translate) --> http://corbin.de/sonderangebote/sonderangebote.html
    Other Honda Models are present too. Cheers.
  23. #22
    Join Date
    Oct 2016
    Country
    Posts
    I don't recall off the top of my head but I believe the bags do not come into contact w/ the Frankenbolts but there's very little room to get an allen wrench on the bolt to install or remove it with the bags attached. You can use an allen wrench with a ball tip that allows you to angle the tool and turn the bolt, but a regular allen wrench I don't think fits.
    There may be some confusion as to me describing what the "rear cowl" is, I'm talking about the piece that covers the passenger seat, not the piece that wraps around the tail. If you don't have a cowl piece covering the rear seat then you can remove any seat using the regular seat latch, assuming you install the little bracket that attaches the seat release lever to the helmet lock.
  24. #23
    Join Date
    Aug 2015
    Country
    Posts
    Thanks. There wasn't any ambiguity. Seat cowl, passenger cowl, pillion set cover, or rear top cowl, I understood.
    Forgive me, I got a sixth gen shortly after the fifth gen in a hopes of learning on it while refreshing (like mods, paint, and maintenance) the fifth. In a nutshell, I am just freaking lost as to why this becomes an issue. I WILL take your word for it, especially as you have purchased a Corbin Smuggler. My fifth is at home home while I'm away at school, new home.
    Quite sure you words and future experience will have me swearing; but big thanks for the tip!
  1. Please share your solution to leaking Corbin Beetle hard bags
    By CElias-VFR in forum 6th Generation 2002-2013
    Last Post: 11-17-2015, 09:44 AM
  2. Corbin Beetle Bags Installation Instructions
    By blackjack_mike in forum Mechanics Garage
    Last Post: 12-23-2013, 06:55 PM
  3. Corbin Beetle Bags
    By Flip998 in forum 5th Generation 1998-2001
    Last Post: 03-16-2009, 08:22 PM
  4. For Sale: Corbin Beetle Bags, yellow $400.00 + shipping
    By mikeym in forum 5th Generation 1998-2001
    Last Post: 05-21-2008, 05:32 PM
  5. Want to chop the rear fender, but have Corbin Beetle bags...
    Last Post: 02-27-2008, 08:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
