Results 1 to 12 of 12
  1. #1
    Join Date
    Jun 2016
    Country
    Posts
    11
    Oil leak from Water Pump week hole 84 VFR750
    Hey Everyone. Help please. So I'm still new to this. Only my second yr but loving every second.
    I have a 84 VFR750 with a small oil drip out of the water pump weep hole. I have pulled the water pump out and the O ring looks ok but not great. I am going to replace it. I know its a hard question to answer but what are the chances this will fix the problem? Should I be going a different route? Should I just cave and buy a new pump?
  2. #2
    Senior Member RllwJoe's Avatar
    Join Date
    Feb 2017
    Location
    Western Lower Peninsula, Michigan
    Country
    My Ride
    1998 VFR800 FI - Red of course , 1987 CBR 600 Hurricane - Pearl White - purchased brand new - sold, 1984 VF 700S Sabre - purchased brand new - sold
    Posts
    115
    I'd like to be of some help, but I have not yet had to do any repair in the water pump area.
    The weep hole is designed to let you know when the pump seals have failed.
    I'm ignorant as to why you would have oil coming from it.
    One thought, ... could it be a gasket leak where the pump is attached?
  3. #3
    Join Date
    Jun 2016
    Country
    Posts
    11
    From some limited research It might be the O ring but it could also be the oil seal. 1 is easy to replace the other not so much
  4. #4
    Allyance's Avatar
    Join Date
    Nov 2013
    Location
    Country
    My Ride
    2014 VFR800 Deluxe 1983 VF750F
    Posts
    2,722
    Just went out and looked at mine, and I couldn't see "telltale" (weephole). Must be on back side, below the shaft, outside of coolant chamber. If that is the location, then O-Ring is your problem. With a bike of this age, I would replace both o-rings.
    14 Red VFR Deluxe - OEM Panniers and Quick Shifter - Knight Design Pegs - MotoPumps Handle bar risers
    83 VF750F (Owned since new) - Corbin Seat - Vance & Hines Pipes/Kerker Slip ons - FOX Shock - Lockart Oil Cooler - K&N Air Filter!
  5. #5
    Join Date
    Jun 2016
    Country
    Posts
    11
    That's the plan for the morning. Hoping for the easy fix.
    Join Date
    Jun 2016
    Country
    Posts
    11
    Changed both O rings and the problem continues although not as severe. Did a complete oil change just hoping the small drip is from a bit of spilled oil but suspect I may be after a new water pump. Hoping not as they seem very hard to find.
  7. #7
    Allyance's Avatar
    Join Date
    Nov 2013
    Location
    Country
    My Ride
    Posts
    2,722
    I will check to see if have a spare it would have low milage, but would need new o-rings because of their age.
  8. #8
    Join Date
    Jun 2016
    Country
    Posts
    11
    That would be amazing!
    Join Date
    Jun 2016
    Country
    Posts
    11
    May seem like a dumb question but can anyone answer the following question for me?
    Will a water pump from a 84 Megna 750 fit my bike?
  10. #10
    Allyance's Avatar
    Join Date
    Nov 2013
    Location
    Country
    My Ride
    Posts
    2,722
    Don't know about Magna Pump, but here is a photo of mine, removed in 1985, low milage, should be fine.
    If interested, send me PM.
  11. #11
    Uber Guru ridervfr's Avatar
    Join Date
    Dec 2009
    Location
    Country
    My Ride
    91 VFR 750, 04 EX 500, 89 YSR 50 Calamaried out. 93 VFR 750, 04 EX 500 (parts bike.)
    Posts
    3,483
    The mechanical seal is behind the impeller. Can you buy replacement parts for this? I could go on one of the many parts sites and find out (feeling lazy right now) I Replaced the mechanical seal/carbon washer and oil seal on my Kawasaki EX500. The water pump came apart in two halves that had carbon gaskets. My cost on the parts was 30 dollars - I have a new in the box water pump I bought from Honda for future use - its for the 3rd generation bikes.
    Its possible to have an oil leak where the weap hole is btw. The problem is behind that impeller. 20170329_135904.jpg20170329_135911.jpg
  12. #12
    Join Date
    Jun 2016
    Country
    Posts
    11
    Good day.
    Sent you a PM regarding this
  1. Coolant leak under water pump on 2002 vfr
    By thephatboi in forum Mechanics Garage
    Last Post: 12-21-2016, 02:01 PM
  2. Water Pump Oil Leak and Gear Shifter Adjustment
    By SamCro in forum 5th Generation 1998-2001
    Last Post: 05-06-2013, 07:08 AM
  3. looking for a gen 4 water pump.
    By vandler in forum 3rd & 4th Generation 1990-1997
    Last Post: 06-17-2012, 10:50 AM
  4. Water Pump
    By Oakley_burn in forum 1st & 2nd Generation 1983-1989
    Last Post: 10-04-2006, 09:06 PM
  5. Water Pump
    By Oakley_burn in forum Mechanics Garage
    Last Post: 09-22-2006, 04:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
