Gen 4 center stand removal
Discussion in '3rd & 4th Generation 1990-1997' started by cronos68, Apr 22, 2017.
  1. cronos68
    cronos68 New Member
    nyc
    97 Vfr
    Taking out exhaust to replace and make some repairs
    Center stand has 1 12mm bolt holding in shaft
    shaft gets pulled from left side pulling left?
    their is a washer on right side end of shaft
    How is the washer dealt with.
    shaft is seized up so currently soaking in blaster.
    Thanks in advance
  2. sunofwolf
    sunofwolf New Member
    Hack saw!
  3. Chewa
    Chewa New Member
    North Queensferry SCOTLAND
    Not sure I can add anything other than I replaced my exhaust system and collector box a few years ago and I did it with the centre stand on.
    It was a bit of a fiddle, but not impossible, so if you can't get the bolt out, that may be an option.
  4. cronos68
    cronos68 New Member
    nyc
    Book says you unbolt fastener from left, then pull out bolt from left.
    Then says to watch for washer at right side of center stand bolt.
    Did all the above but washer is holding in,
    Seems like a missing something logical there.
    I think I'll just cut it out but with parts getting rarer I'm trying to not damage pipe too much.
  5. cronos68
    cronos68 New Member
    nyc
    My unit has all been welded together awhile ago.
    It seems like it wants to come out but locks up on stand.
  6. cronos68
    cronos68 New Member
    nyc
    Cut right side header. Came right after that
