Identify Progressive Suspension Springs?
Discussion in '3rd & 4th Generation 1990-1997' started by Hingley, Apr 26, 2017.
  1. Hingley
    Hingley New Member
    I have decided to try and put the 91 VFR750 On the road for a couple of months while I finish the 90 VFR. So far I found the steering head bearings need to be adjusted or replaced, and while I was doing this I found the front fork seals are shot. Since I have to remove the forks I would like to check the fork springs, when I bought the bike I was told it had a newer set of Progressive Suspension fork springs. Does anyone know if there is a way to tell if they really are Progressive springs? In addition does anyone know the proper spacer length and amount of fork oil ( best weight oil ? ) for this spring set? I went to the Progressive Suspension Webb site but it's Tech phone number does not like Canada, I guess
  2. Devo83
    Devo83 New Member
    Ontario
    Try sending them detailed pics of the springs. Maybe look for some kind of makers mark or stamping, send them measurements. That's your best bet.
    If not maybe quiz the Previous owner up?
  3. Badbilly
