4th Gen 1994 - 1997
Discussion in 'Specifications' started by WhiteKnight, Mar 31, 2007.
  1. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Dimensions:
    Length: 83.7 (2125mm)
    Width: 28.3 in. (720 mm)
    Height: 46.7 in. (1,185 mm)
    Wheelbase: 57.9 in. (1,470 mm)
    Seat height: 31.5 in. (800 mm)
    Footpeg height: in. ( mm)
    Ground Clearance: in. ( mm)
    Dry weight: 465lbs (211 kg)
    Curb weight: 523 lbs (237 kg)
    Maximum weight capacity: 417 lbs (189 kg)
    Engine and Transmission:
    Displacement: 45.64 ci (748 cc)
    Engine Type: Liquid-cooled V4
    Stroke: 4
    Compression Ratio: 11.0:1
    HP: 103.00 HP (75.2 kW) @ 10000 RPM
    Torque: 56.4 ft.lbs (76.49 Nm) @ 9000 RPM
    Valves per cylinder: 4
    Transmission: 6-speed
    Frame:
    Front suspension: Telescopic fork
    Front wheel travel: 5.5 in (140 mm)
    Rear suspension: Prolink
    Rear whell travel: 5.1 in (130 mm)
    Tire Size:
    Front: 120/70 VR17 - V250, 120/70 ZR17
    Rear: 170/60/ VR17 - V250, 170/60 ZR17
    Fuel Capacity: 5.55 US Gallons (21.0 litres)
    Fuel Reserve: 1.06 US Gallons (4.0 litres)
    Brakes:
    Front: Dual disc (full floating?)
    Rear: Single Disc
    Colors:
    1994: Pure Red
    1995: Pure Red
    1996: Pure Red (Silver in Canada)
    1997: Pure Red
    **Note: Some specs like the suspension travel were not listed in the info I found. I presume the travel is the same as the 3rd gen. Also not listed in the info I found were specs for ground clearance and footpeg height.**<!-- google_ad_section_end --><!-- / message --><!-- sig -->
  2. mello dude
    I had a 4th gen for a bunch of years and loved the thing. Just curious - whyfor on the specs?
    MD
  3. RVFR
    LOL I knew this
  4. WhiteKnight
    London, Ky
    Some asked why there were spec for the 3rd gen but not the 4th. Seeing as we also have spec of other generations, I felt it appropriate to add the 4th gen, too.
    It might also help those searching for a vfr to compare some of the differences between the different generations. :)
  5. reg71
    Atascadero, California, United States
    you could just throw them all together in a spreadsheet for everyone that always asks, what's the difference between 4th and 5th etc. Then you could put it in the VFR wiki.
  6. Marley Davidson
    Marley Davidson New Member
    Matosinhos, Oporto
    Well, I have one (97) and I thought it had less than 100hp...
    I love my bike!
  7. VT Viffer
    VT Viffer New Member
    South Carolina
    Aren't JDM 4G+ VFR's detuned? Maybe this is true for EU spec bikes, too?
  8. Gatekeeper
    Gatekeeper New Member
    To see all the changes from 3rd to 4th, get a 95 service manual. It lists everything and then the changes for 94 up. Along with drawings. There are A LOT of small changes. Some good, some so-so.
  9. racercosmo
    racercosmo New Member
    Northern California
    I have a collection of articles when the 3rd gen was new and they list it as 79 hp. Is one rear wheel, and the other engine? It seems like 20% loss is a lot.
  10. RVFR
    Had mine dynoed at 32K miles, thou I have a KN air filter and a Staintune, it pulled 97HP 55 torque. I too have the Factory manual where it has inserts showing whats different between the two versions, some are minor, some not so.
  11. Marley Davidson
    Matosinhos, Oporto
    To me 80 hp is enough:tongue:
  12. kd4ysi
    kd4ysi New Member
    Columbia, South Carolina, United States
    i might have mine dynoed sooner or later
