Go Back   VFRworld > VFRworld Forums > VFR Interceptor Discussions > Third & Fourth Generation 1990-1997
Old 09-02-2008, 08:22 PM   #1 (permalink)
Last Online: 09-26-2008 10:19 PM
front wheel bearings
I went and had a new chain and sprockets put on (so nice not to hear that grinding sound), and while riding it out of the shop, the guy from the service desk noticed that there was some play in the front wheel. We popped it up on the center stand, and he looked it over and said I needed new bearings in the front.
Looking at the manual, this doesn't seem crazy hard, but I have some questions before I take off the front wheel. I don't have a car, so if the wheel's off, and I miss a part, I'm looking for a bus to ride.
1) how many bearings do I need? and there are two sides, right?
2) (6004UU) is the size given, are those standard bearings I could get at an AutoZone or Home Depot, or are they specific to Honda Motorcycles?
3) regular grease?
4) anything else, as usual, is appreciated.
Still learning lots about this bike, thanks for the help.
eadc is offline   Reply With Quote
Old 09-02-2008, 09:09 PM   #2 (permalink)
Vlad Impaler's Avatar
Last Online: Yesterday 08:33 PM
My Ride: 1995 VFR750
1) Bearing on each side of rim
2) They probably cost about $15 each for OEM. IMHO don't cheese on them, get Honda parts.
3) Sealed
4) You may need help or proper tools for pulling and setting. Again, IMHO, don't cheese. Get them done right and don't worry about them for the next 50K miles.
Everyone gets everything he wants. I wanted a mission, and for my sins, they gave me one.
Vlad Impaler is offline   Reply With Quote
Old 09-04-2008, 03:30 PM   #3 (permalink)
dale-j's Avatar
Last Online: 11-22-2008 07:46 PM
My Ride: 1989 FJ1200 (sold) 1993 VFR750
I used an AllBalls kit but if your Honda dealer is close I think (IIRC) that the AllBalls bearings were not Japanese or German - I can check but I think they came from the dreaded C#!n@ You can't go wrong with OEM Honda.
Getting them out can be tricky, I thought there was a secret and took the wheel to a shop, and all they did was get a big punch/screwdriver on the edge of the spacer where it meets the opposite bearing, and hammer around and around in a circle. That's *my* usual approach but I was worried it might wreck the spacer - apparently not and if it did they would have just cleaned it up with a die grinder.
If you have a socket the correct diameter for the outer race (DONT press on the inner race or the seal) you can install them easily. Bearings in the freezer overnight, pour a kettle of boiling water over the hub of the wheel, lightly grease the outer bearing shell and they will tap in with only an ounce or two of force. Make sure that the spacer is in first though, or you'll be buying another set of bearings......
Steve Dale-Johnson
Delta, BC
1981 XL80S (first bike, bought new in '81)
1990 GSXR750 (sold after the great ticket fiasco)
2003 CBR954 (wadded into a little ball)
1989 FJ1200 (sold)
1993 VFR750 (fighter conversion - now sold)
1979 Yamaha RD400 Daytona Special cafe racer
Honda! Where's my 7th Gen VFR????
dale-j is offline   Reply With Quote
Old 09-04-2008, 09:16 PM   #4 (permalink)
terry's Avatar
Last Online: 10-11-2008 07:28 AM
My Ride: 1993 Honda VFR750f
There was also something about not squeezing the brake lever while the calipers are off the front discs... so watch for that.
terry is offline   Reply With Quote
Old 09-12-2008, 10:24 AM   #5 (permalink)
Nitrousva's Avatar
Last Online: 11-20-2008 03:42 PM
My Ride: 1993 VFR 750 1975 CB750/1110cc 1974 CB500
I've done it a couple times, the All Balls bearings are like 16 dollars and come with the seals. To remove the bearings you can either hammer them out as stated above, or I prefer to use a seal remover. This tool removes the seals, but also will pull the bearings out, it's a slow process but it works well, just work your way around the bearing moving the tool 90 degrees each time you pull.
Like the above reply, put the bearing in the freezer over night, before putting them in, heat the wheel, I use an electric heat gun (kinda like a hair dryer) to heat the wheel. I use a socket that's the same diameter as the outer race on the bearing and drive it home w/a dead blow hammer.
It's not too hard, just a little time consuming.
Robert
Nitrousva is offline   Reply With Quote
Wheel conversions for 1986-1987 adam48060 First & Second Generation 1983-1989 41 05-31-2008 08:57 AM
bent front wheel...seeking advise DeannaLee Fifth Generation 1998-2001 16 05-03-2008 01:13 PM
1986 VFR700 Front wheel Impulse2k1 First & Second Generation 1983-1989 8 06-14-2007 08:32 PM
1988 or 1989 Honda VTR 250 Interceptor 16" Front Wheel - $35 LV2BWO Buying & Selling 0 11-12-2006 12:28 PM
Wrench report: replacing steering head bearings in a '94 VFR John Johnson VF/VFR Mailing List 7 09-30-2006 09:03 AM
