Go Back   VFRworld > Motorcycle Articles > Product Reviews > Tire Reviews
Old 01-14-2006, 06:11 PM   #1 (permalink)
Administrator
michael's Avatar
Last Online: Yesterday 05:55 PM
My Ride: 1994 Honda VFR
Tyres - Full Report
The tyres in the MCN test were tested in the order reported below. Marc weighs 14st. 7lbs (203lb, 92kg), Keith weighs 15st. (210lb., 95.3kg).
Pirelli Dragon GTS (MTR23/24) Overall rating 94% Pressure (p.s.i.) F34, R39
Marc (fastest lap 2:11.90) [Sprint St 2:13.60] These are ultra-stable at all times and the gfrip is fine for firing out of corners. They suit the bike well and offer plenty of grip, too. They are surprisingly compliant and work with the soft suspension but, as we've come to expect from the rounded profile of most Pirellis, slow to turn. Excellent
Keith (fastest lap 2:11.90) [Sprint ST 2:13.12] They turn easily but slowly and they're exceptionally stable both upright and cranked over. This applies going into and coming out of bends as well as in mid-corner. The front did slip a touch on one bumpy corner, but there's generally plenty of grip for the power of the bike. It's an ideal VFR tyre.
Metzeler MEZ4 (Overall rating 87%) Pressure (p.s.i.) F34, R39
Marc (fastest lap 2:11.40) [Sprint ST 2:11.21] These feel OK putting the power down but I don't know how I stand for grip mid-corner. They move around more than the Pirellis, especially under braking. They're slow to turn in but stable during entry and exit, and in a straight line. The front's feedback is particularly vague.
Keith (fastest lap 2:11.60) [Sprint ST 2:12.05] These have the same basic carcass construction as the Pirellis but they feel very different. They're more grippy, but it's not all that usable - feedback lets them down. They slid into and out of corners, which is bearable but not what you'd want from a sports tourer on the road. I didn't feel 100% confident.
Dunlop D207 (Overall rating 90%) Pressure (p.s.i.) F36, R42
Marc (fastest lap 2:12.10) [Sprint ST 2:12.00] There was slight instability exiting bends but in general things weren't bad. The stability under braking was excellent however - you can pin the front tyre to the ground. These also brought the suspension to life a bit even though the bike remained a touch wallowy.
Keith (fastest lap 2:11.10) [Sprint ST 2:11.24] These worked reasonably well on the VFR. The levels of grip available were fed back well and the suspension definitely livened up. But they aren't the most stable. If it's an exciting ride you'd like - go ahead and buy.
Avon Azaro II (AV35/36) (Overall rating 98%) Pressure (p.s.i.) F36, R42
Marc (fastest lap 2:10.60) [Sprint ST 2:09.30] These suit the bike in every aspect. There's a tiny bit of mvement out of corners, but it's fun, not scary. Npo complaints at all about grip, feedback, stability, turn in time or corner speed. Brilliant.
Keith (fastest lap 2:09.31) [Sprint ST 2:10.54] The tyres' profiles are just flat enough for utter stability and predictability going into bends and sharp enough for speedy steering. They're excellent and show Avon's extensive redesigning of this tyre over the past 12 months has paid off. I can't fault them.
Michelin Macadam (Overall rating 93%) Pressure (p.s.i.) F36, R42
Marc (fastest lap 2:10.50) [Sprint ST 2:10.24] There's a fair amount of grip but they don't offer enough feedback. Definitely more touring than sports, at least they are likely to last a long time. But I wouldn't ride at the ragged edge on them. They are firmly constructed and comfortable and offer excellent straight line stability.
Keith (fastest lap 2:10.30) [Sprint ST 2:11.19] The grip and feedback were reasonably good but there's room for improvement. They didn't offer a completely convincing ride, even though they were ultra stable and comfortable. They score well for coping with bumps while cranked over.
Bridgestone BT020 (Overalll rating 99%) Pressure (p.s.i.) F36, R36
Marc (fastest lap 2:08.40 = best of day) [Sprint ST 2:10.47] The VFR loves these. In fact these are the best tyres in our test for the Honda. I could attack corners hard and got stacks of feedback and grip at all times. And the bike loved overbanding and slammed home what is clearly the fastest lap of all during our massive test.
Keith (fastest lap 2:09.00 = his best of day) [Sprint ST 2:10.67] These are totally neck and neck with the Avon Azaros for top slot. Marvellous.
Continental Contiforce (Overall rating 90%) Pressure (p.s.i.) F36, R42
Marc (fastest lap 2:09.03) [Sprint ST 2:09.97] These performed surprisingly well, lapping very quickly. But they weren't totally stable and squirmed around on overbanding. Bumps never upset them, though, and there was a gratifying amount of grip.
Keith (fastest lap 2:10.45) [Sprint ST 2:11.08] These were the biggesat surprise of the test. I hadn't ridden on Continentals for years and expected them to behave in much the same way as they used to - poorly. But they suited the VFR perfectly and managed a fair lap time too. Grip was good, stability was excellent and feedback reasonable. Not so good on overbanding, though.
So two clear winners in the Avons and the Bridgestones on this test and by the sound of it either would be a good buy for the VFR.
In the UK there is quite a price difference in favour of the Avons (prices for a pair):
Pirelli GBP193.50 (USD300 @ 1.55)
Metzeler GBP208.50 (USD323 @ 1.55)
Dunlop GBP208.55 (USD323 @ 1.55)
Avon GBP162.05 (USD251 @ 1.55)
Michelin GBP192.25 (USD298 @ 1.55)
Bridgestone GBP194.00 (USD301 @ 1.55)
Continental GBP139.60 (USD216 @ 1.55)
The tests took place in the dry.
If I was buying today I think I'd go for the Avons on the basis of the report above, the price variance compared with the Bridgestones and the striking tread pattern.
Interesting that in most cases the VFR fastest lap was quicker than that of the Sprint ST with it's larger engine.
Hope you found it interesting as it took a while to retype it.
Brian Ross-Meering rossm@attglobal.net
michael is offline   Reply With Quote
Old 12-11-2007, 01:18 PM   #2 (permalink)
Last Online: Yesterday 02:44 PM
My Ride: 2005 VFR 800 ABS RED
It is a great report and wish more reports comparing the tires where availble. I'm sure most tyres are excilent so to see the compared is good.
Would benice to see how they wear...as many VFR riders also tour, then attack the twisties so unlike a track bike we care about off track abilities a little more. Did the wear funny? did they wear fast? would they cup?
Molsan is offline   Reply With Quote
Old 01-01-2008, 05:49 PM   #3 (permalink)
arm1151's Avatar
Last Online: 09-29-2008 12:30 AM
My Ride: '06 pearl white VFR '06 red/black Hayabusa '94 Magna
I just put a pair of Bridgestone BT021 on my 06 VFR. Man can I tell a difference. The bike begs to be in the corners handles great. I am waiting to see what kind of mileage I can get out of them.
arm1151 is offline   Reply With Quote
Old 01-07-2008, 06:11 PM   #4 (permalink)
crynsie's Avatar
Last Online: 11-28-2008 01:31 PM
My Ride: 97 750 VFR (RIP)
BT021's
I just put 021's on my 95 VFR as well.
So far, I have to say I am well impressed. Previouslt had a pair of BT014's when I bought it. The 021's feel a lot safer in the corners etc.
They do seem a little loud (road noise), but I presume that will reduce as the tread wears a bit.
All in all, a thumbs up for the BT021's.
crynsie is offline   Reply With Quote
Old 01-08-2008, 03:15 PM   #5 (permalink)
Last Online: 09-03-2008 12:25 PM
Bridgstone BT-021
Hi, has anybody tried these tires yet? XUSAX
XUSAX is offline   Reply With Quote
Anyone have pics of 1st gen VF700/750s with full fairings? Outlawz24 First & Second Generation 1983-1989 12 04-13-2008 10:37 AM
Laguna Set Up Report from Yamaha JA VF/VFR Mailing List 0 07-18-2007 12:05 PM
COTU ride report (Long) Sherman, Larry, GCM VF/VFR Mailing List 8 06-01-2007 08:25 AM
Fear and Greed in Upstate NY - WDGAH Ride Report - Long J Richard Ronay VF/VFR Mailing List 0 09-16-2006 12:32 AM
FW: Avon Tire deal...through September Mathew Roth VF/VFR Mailing List 0 09-07-2006 09:15 AM
