Old 08-28-2007, 07:56 PM   #1 (permalink)
Problem - Dash Turn Signal Lights Always On (Slightly Dim)
Has anyone ever had an issue where your turn signal lights on the dash are
always on (slightly dim)? The turn signals up front and on the rear tail
work fine, though. When you use the turn signal, a strange thing happens,
the opposite light gets brighter and the one that is supposed to be blinking
gets dimmer. Before I tear the thing apart, I just wanted to see if anyone
knows how to fix the problem. A few days ago, it didn't have the problem at
all, and also, it stopped doing it this morning for about a minute.
-Dan
'99 VFR
Turn signal fuse keeps blowing. S.U.A.R Mechanics Garage 28 05-29-2008 11:19 PM
Problem - Dash Turn Signal Lights Always On (Slightly Dim) Bush, Christopher VF/VFR Mailing List 0 08-29-2007 04:43 PM
'87 turn signal problems ichi First & Second Generation 1983-1989 3 10-11-2006 06:42 PM
'87 vfr turn signal problems. ichi Mechanics Garage 1 10-06-2006 12:34 PM
00 VFR Turn Signal Issue Steve Rosenblatt VF/VFR Mailing List 2 10-02-2006 12:31 PM
