Re: 1997 VFR Electrical Problem - Won't Start / Main Fuse - StarterRelay....
In a message dated 9/4/2007 6:11:17 PM Eastern Standard Time,
chuck_davis@xxxxxx writes: I check the obvious, fuses and Run switch. Nothing there. I check the battery terminals. Everythings fine here too. Bike was towed home and now its time to start trouble shooting. How old is the battery? What are your i4C readings while you were riding? High 13s - 14.5VDC? In addtion to the grounds and connectors (R/R and stator wire quick connect), check around the 30A main fuse / starter relay. There may be some corrossion / heating / melting going on there. Good luck. Fred in CT w/ Ver. 96 and just suffered this maladay........ ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Thanks Mrydr, I didn't know the VFR '97 had a main fuse (my '97 Valkyrie
does behind the right panel under the seat) but I'll look for it. Thanks for everyone's messages. I've also been searching the web as well. The thing that confused me most is why did the dash lights come on when I hit the starter button. That's weird. Mrydr@xxxxxx wrote: > In a message dated 9/4/2007 6:11:17 PM Eastern Standard Time, > chuck_davis@xxxxxx writes: > > I check the obvious, fuses and Run switch. Nothing there. I check the > battery terminals. Everythings fine here too. > > Bike was towed home and now its time to start trouble shooting. > > > How old is the battery? > > What are your i4C readings while you were riding? High 13s - 14.5VDC? > > In addtion to the grounds and connectors (R/R and stator wire quick > connect), check around the 30A main fuse / starter relay. There may > be some corrossion / heating / melting going on there. > > Good luck. > > Fred in CT w/ Ver. 96 and just suffered this maladay........ > > > > ------------------------------------------------------------------------ > Get a sneak peek of the all-new AOL.com > _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| 30A main fuse melting | spragga b2 | Sixth Generation 2002-2009 | 4 | 06-21-2007 08:28 AM |
| 30A main fuse melting | spragga b2 | Mechanics Garage | 0 | 06-19-2007 12:44 PM |
| Where is main fuse | arbul2000 | Mechanics Garage | 1 | 03-29-2007 02:00 PM |
| RE: New VFR | Paul Kolbo | VF/VFR Mailing List | 18 | 09-04-2006 07:13 PM |
| RE: Vfr Digest, Vol 27, Issue 46 | Zenon | VF/VFR Mailing List | 0 | 06-27-2006 02:30 PM |
