Old 10-05-2007, 09:06 AM   #1 (permalink)
Bob Bielak
RE: 1996 VFR 750 using synthetic Brake fluid
I used to use some Valvoline synthetic fluid that specifically stated (on
the bottle) that it was compatible with non-synthetic DOT 3 and DOT 4
fluids.
I would check the label on the bottle. If it's compatible, and if it says
"exceeds ... DOT 4", then no problem.
bob@xxxxxx
_____
Ed Ostack
Sent: Friday, October 05, 2007 10:19 AM
To: vfr@xxxxxx
Subject: 1996 VFR 750 using synthetic Brake fluid
I have just replaced the rear brakes.....not a straight forward task that I
anticipated. Anyway, my fluid ran empty on bleeding and the Master cylinder
reservoir cap says "use DOT 4 only". I have some synthetic valvoline brake
fluid that is unopened and it says exceeds DOT 3 and DOT 4.
Does anyone have any comments about problems using synthetic fluid in the
brake system?
Ed in Pgh
Looking for HB9402 Heli-Bars for my 1996 VFR Joshua Keller VF/VFR Mailing List 9 03-18-2008 06:58 AM
1997 VFR questions... Mike VF/VFR Mailing List 5 10-05-2007 08:52 PM
R/R For Blackbird Compatible with 1996 VFR VF/VFR Mailing List 0 03-20-2007 05:56 PM
Anyone need VFR brake pads? kurrremkarmerruk VF/VFR Mailing List 1 06-24-2006 11:30 PM
2002 VFR LED brake light addition / mod fh VF/VFR Mailing List 0 06-07-2006 07:43 PM
