Old 10-08-2007, 05:46 AM   #1 (permalink)
digger
Uhoh - grinding
Rolled my '94 VFR out only to hear a disconcerting
grinding from the front sprocket - I think. I don't
think its the chain - relatively new and there's
binding no matter where the links are. Interestingly,
the binding is most severe when the bike is on the
center stand - that's how I found the problem. When on
the stand the wheel can barely turn, with lots of
grinding. When off the center stand the rear wheel
rotates - course, the weight of the bike is helping.
I'm thinkin' bearing - how big a deal is that?
Anyone with any experience with this?
digger
__________
Life's been good to me, so far...
Old 10-08-2007, 05:58 AM   #2 (permalink)
Fred Wills
Re: Uhoh - grinding
>digger
>__________
>vfr mailing list
>vfr@xxxxxx
Chain rubbing on the rubber guide block on top of the swingarm?
-Fred W
'98 Honda VFR800Fi SPORTtourer
'05 Yammi FJR1300 sportTOURER
'00 Aprilia Pegaso AdventureTourer
Old 10-08-2007, 06:03 AM   #3 (permalink)
digger
Re: Uhoh - grinding
Boy, a rubbing chain would be great! Never thought I'd
say that.
I'll take a look this weekend - would the rubber
block bind up the chain so bad the wheel won't turn?
Would it be effected by the side stand?
Thanks!
digger
> the swingarm?
Old 10-08-2007, 07:48 AM   #4 (permalink)
Walzer, Carl (.)
RE: Uhoh - grinding
Make sure your chain isn't too tight. As Fred mentioned it could be rubbing
on the block, and this happens if it is too tight ... and it can be most
noticeable on the center stand.
Carl
say that.
Thanks!
digger
Re: Big bore questions round II - Crank Grinding? Greg Verderber VF/VFR Mailing List 14 11-01-2006 06:33 AM
