Old 11-26-2007, 09:12 PM   #1 (permalink)
mpmartin
Coolant Flush Adventure
Managing to turn a 15 minute job into about a 5 "dayer". I have taken the
fairing of the bike. In doing so, I somehow managed to break off a tube
which flows from the bottom of the overflow tank up to the fairing. It's the
piece that connects into the fairing somewhere that is broken.I cannot see
where it connects? Any ideas ?
Thanks.
Mike
Old 11-26-2007, 10:01 PM   #2 (permalink)
John Johnson
Re: Coolant Flush Adventure
> taken the
> tube
> It's the
> cannot see
Does it connect to the radiator, right underneath the cap? There
should be an overflow/breather tube on your overflow tank, up near
the top, and a hose from the radiator fill neck to the overflow tank,
near the bottom.
later,
Johnj
Old 12-01-2007, 05:31 PM   #3 (permalink)
John Johnson
On Tuesday 27Nov, 2007, at 12:07 AM, mike wrote:
> ----- Original Message -----
> From: "John Johnson" Sent: Monday, November 26, 2007 9:01 PM
> Subject: Re: Coolant Flush Adventure
>>> taken the
>>> tube
>>> It's the
>>> cannot see
>> near the bottom.
>> later,
>> Johnj
> Hi John
> Yup, it does. I have a feeling that I rode like that all summer.
> Maybe a
> reason why the bike rode so hot in stop and go traffic. I guess I
> could get
> it saudered. I wonder if it might be time to swap out the rad for a
> new one?
> It is a 1996 with about 60,000 KM on it.
> Thanks.
> Mike
I don't think that a replacement of the radiator is necessary at this
point, unless the spigot on the radiator has broken off. If the
rubber hose simply came off its spigot, then splurge on a section of
new hose and re-attach it. I believe it uses one of those spring-
clamps to hold it on, but it's dark and I don't feel like going out
to the garage to check just at the moment.
If the spigot _has_ broken off, you might call up a radiator shop and
ask if a repair is feasible. A new radiator from Honda will be
_quite_ expensive, and a used unit will likely be difficult to find,
so repair strikes me as a good option in this case.
later,
Johnj
Old 12-04-2007, 10:56 AM   #4 (permalink)
John Alexander
Have left and right radiators for the 98-01 VFR.
Work fine but a few "imperfections". Cheap.
JohnA in LA
> >>> taken the
> >>> tube
> >>> It's the
> >>> cannot see
> >> near the bottom.
> >> later,
> >> Johnj
> > Hi John
> > Maybe a
> > could get
> > new one?
> > Thanks.
> > Mike
> later,
> Johnj
Long Life Coolant Test Results michael Oil & Coolant Reviews 2 02-13-2009 09:45 PM
Boiling Coolant woody77 Mechanics Garage 12 07-24-2007 12:14 PM
coolant flush Paul.Smith VF/VFR Mailing List 1 03-22-2007 03:03 PM
Back in the Saddle - some questions Dan Barufaldi VF/VFR Mailing List 9 06-14-2006 03:49 PM
Back in the Saddle - some questions Tom Heron VF/VFR Mailing List 0 06-14-2006 03:32 PM
