Fuel Leak Nightmare
vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Fuel Leak Nightmare
Fwd: Fuel Leak Nightmare
On Monday 25Feb, 2008, at 12:57 PM, Vfrgrrrl wrote:
> I need help. > > My 1997 VFR has been a real trooper, 130-some thousand miles and > all. A while ago, I fired him up only to have fuel come pouring > out of an unknown place under the tank. I have taken the tank, air > cleaner, and carb cover/tops off, and pulled out the fuel hoses > that go to the carbs. No leaks. *&%! Now what?? I'm thinking I > could replace the hoses anyway, and the gaskets to the carb intakes > and hope for the best, but I'm sure I haven't found the problem. > I'm getting to where I may just bring the VFR, parts and all, to an > actual mechanic, but if there are any ideas, I'd be grateful to > hear them. Anyone that lives in the greater San Diego area that > wants to help or refer me to someone good is also much appreciated. > > I need to get him running. Thanks all! It sounds like you've got a sticky float that is allowing fuel to overflow the fuel bowl. All carburetors have overflow hoses, and if the bowl overfills, it goes out the overflow and all over the place. Since you've got the fuel tank off, I'd start by draining all the fuel from your carbs, and filling them with a carburetor cleaner (SeaFoam makes one, Yamaha's product is well-liked, Berryman's B-12 Chemtool comes up as a useful product as well). Let that sit for 20-30 minutes, then drain it all out. Replace the fuel tank and see if things work as they should. If they don't, you can either try it one more time, or just take apart each carburetor (one at a time, to avoid mixing parts!), and clean off the float-operated needle valve and seat (e.g. with a small, soft probe soaked in carb cleaner). You may want a magnifying glass available to look for small bits of varnish after you're finished. Any debris on the valve or seat will cause your carb to overflow. HTH! Oh yeah. fwiw, the carb hose routing info is on p. 6-14 of my manual (covers 90-96). Hose #3 (49-state) or #6/10(CA emissions) appear to be the likely candidates for dribbling fuel all over the place. _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: Fuel Leak Nightmare
| '86 VFR fuel pump relay question | Guest | First & Second Generation 1983-1989 | 8 | 11-23-2008 06:00 PM |
| 5th Gen fuel tank removal for shock install | Puma Cat | General VFR Discussions | 8 | 01-31-2008 01:18 AM |
| fuel leak | cdg700f | First & Second Generation 1983-1989 | 2 | 05-07-2007 04:36 PM |
| Need help with fuel leak... | savedrider | First & Second Generation 1983-1989 | 5 | 01-08-2007 10:28 AM |
| Stock VFR Fuel Injector Rating? | Joe Cargal | VF/VFR Mailing List | 1 | 09-11-2006 08:06 PM |
