Old 04-05-2008, 12:45 PM   #1 (permalink)
Patrick Shelston
Baseline carb setting for stock 94
Good day members,
Being the first nice day of year in Toronto. I decided to pull out the
vfr for the innaugural ride.
Well, she won't start. She putters to life put dies only seconds later.
Would anyone be able to tell me what the baseline settings should be
on the carbs? Like the idle speed screw, mixtures... How many turns
out? I know the PO messed with the carbs.
Many thanks on a beautiful saturday!
Patrick
1994 Honda VFR750F
On 4/4/08, lguttilla@xxxxxx wrote:
> btw Matt, I may be a little more reserved in my old age - but that don't
> mean my skillz is gone away.
> I can still low-side with the best of them!
> seriously, i know it's only 500 miles, but i been tearing that Beemer up.
> Lou
> SF, CA
> -------------- Original message --------------
> From: Matthew Roth
> Yep, Leah fits the bill there...no wonder he's going all soft...
> Can't really fault Lou here IMO--it's just fate...and definitely age...and
> the degradation of riding skills that come with it too...
> Matt Roth
> Greg Wrote:
> Greg Verderber"
> To:"vfrlist" , "Lou Guttilla" ,
> "Bill Ng"
> Date:Thu, 3 Apr 2008 20:01:25 -0700 (PDT)
> Subject:Re:
> I am disconsolate at the passing of yet another hero.
> What next, Hussey trades in his beemer for a cage (oh
> wait, he already did that).
> I'm going to go down to the garage lower my brake
> fluid to half mast.
> Must be a DAMN good woman behind all this!
> Cheers,
> Greg
> Matt
> You rock. That's why Blockbuster's offering you one month of Blockbuster
> Total Access, No Cost.
Old 04-05-2008, 01:44 PM   #2 (permalink)
Ron Perrillo
Re: Baseline carb setting for stock 94
Are you sure it's the carb settings? If you did not treat the gas before winter storage with a preservative like Stabil it's more likely gummed-up carbs from old/bad gas. If you're lucky it could be cleared up by filling the carbs with a carb cleaning product called Sea Foam. Allow it to sit in there for the recommended amount of time, overnight if it's bad,occasionally go slosh the stuff around by moving the bike back and forth/side to side, drain the Sea Foam out replace with fresh gas and try to start it again. I have heard that Yamaha makes a good product for this purpose as well but I can't remember what it's called.
Ron
Chicago
Patrick Shelston wrote:
Good day members,
Patrick
1994 Honda VFR750F
> Lou
> SF, CA
> From: Matthew Roth
> Matt Roth
> Greg Wrote:
> Greg Verderber"
> "Bill Ng"
> Subject:Re:
> fluid to half mast.
> Cheers,
> Greg
> Matt
Old 04-05-2008, 01:53 PM   #3 (permalink)
Ed Kokosa
RE: Baseline carb setting for stock 94
Patrick,
Did it run when you bought it?
When did you buy it? When was it last running?
When was the current gas put in?
Sitting for a few months in Toronto (or what I imagine to be Toronto) winter
temperatures may not necessarily cause gas-gumming problems.
Sitting for six months in the summer, yes you'll have gummed-up carbs.
Ed
1998 VFR800
_____
Ron
Chicago
Good day members,
Patrick
1994 Honda VFR750F
Old 04-05-2008, 03:47 PM   #4 (permalink)
Chris Merrill
Before going the Sea Foam route, you might just try draining the old
gas and replacing with fresh gas. I've had problems getting my 91
running after letting it sit for a while and simply putting in fresh
gas cleared up the problem. I think that one time I also added a
carb/FI cleaner additive, but I'm not sure it really helped.
Chris
BTW, the old gas burned fine in my Jeep. No sense letting it go to
waste :)
> Ron
> Chicago
> */Patrick Shelston /* wrote:
> Good day members,
> Patrick
> 1994 Honda VFR750F
> that don't
> Beemer up.
> > Lou
> > SF, CA
> > From: Matthew Roth
> age...and
> > Matt Roth
> > Greg Wrote:
> > Greg Verderber"
> > "Bill Ng"
> > Subject:Re:
> > fluid to half mast.
> > Cheers,
> > Greg
> > Matt
> Blockbuster
Chris Merrill
cmerrill@xxxxxx
Old 04-05-2008, 04:14 PM   #5 (permalink)
Patrick Shelston
Thanks for assistance so far.
Yes, it did run, when I bought it, but needed the PO to adjust the idle
adjuster open (just discovered that 1,500-1,600rpm is perfect to start her
up).
I bought it, gassed it up and drove it to storage in October. I put Stabil
in it, but I couldn't start it to flow it through the carbs.
Fast forward 2 hours... I got it to start with the idle speed about 2 turns
from closed, but now it idles at 1500-1600 rpm.
So, I've got some problems with some jets, I reckon. Fred suggested the
pilots...
The PO installed a Stage-1 Dynojet kit (no drilling done) and claims to have
cleaned & sync'd the carb, but I'm not convinced.
I wasn't really looking for more work, but I guess I don't have a choice.
Maybe I'll try running some SeaFoam through it. I'm sure you'll see lots
(useless) questions from me in the new few weeks :)
Cheers,
Patrick
On Sat, Apr 5, 2008 at 3:53 PM, Ed Kokosa wrote:
> Patrick,
> winter temperatures may not necessarily cause gas-gumming problems.
> Ed
> 1998 VFR800
> Ron
> Chicago
> *Patrick Shelston * wrote:
> Good day members,
> Patrick
> 1994 Honda VFR750F
Old 04-07-2008, 08:18 AM   #6 (permalink)
Walzer, Carl (.)
Sounds like you have a little bit of gumming. Put in a good carb/FI cleaner
and run a tank through and you should be good to go. Mine always takes a
bit to get running in the spring (usually don't do any storage type stuff in
the fall), but then runs fine once the old fuel in the bowls gets used up
and clean fuel gets in to dissolve the residue.
Don't go into the carbs unless you have to.
Draining the carbs of the old gas before trying to start can be a good
practice first thing in the spring, but I'm usually too lazy to pull body
panels and just deal with the long start process.
I did get to ride mine in this morning, so things are looking up :-)
Carl
_____
Patrick Shelston
Sent: Saturday, April 05, 2008 6:14 PM
To: vfr@xxxxxx
Subject: Re: Baseline carb setting for stock 94
up).
pilots...
Cheers,
Patrick
On Sat, Apr 5, 2008 at 3:53 PM, Ed Kokosa > wrote:
Patrick,
Ed
1998 VFR800
_____
Ron
Chicago
Patrick Shelston >
wrote:
Good day members,
Patrick
1994 Honda VFR750F
Old 04-07-2008, 09:28 AM   #7 (permalink)
DaCatDaddy
Carl,
What kind of carb cleaner do you run thru it? Seafoam or something else?
Dave Jordan
1997 VFR750F
Chicagoland
_____
Walzer, Carl (.)
Sent: Monday, April 07, 2008 9:19 AM
To: Patrick Shelston; vfr@xxxxxx
Subject: RE: Baseline carb setting for stock 94
Carl
_____
Patrick Shelston
To: vfr@xxxxxx
up).
pilots...
Cheers,
Patrick
Patrick,
Ed
1998 VFR800
_____
Ron
Chicago
Good day members,
Patrick
1994 Honda VFR750F
Old 04-07-2008, 09:41 AM   #8 (permalink)
Walzer, Carl (.)
I usually just pick up a good quality carb cleaner from the auto parts
store. Textron is what I've used lately, but others will work. The Seafoam
appears to be a similar product, and I have seen that at the auto parts
store occasionally too. I suggest getting a name brand, but that is just
me.
Carl
_____
Sent: Monday, April 07, 2008 11:28 AM
To: 'Walzer, Carl (.)'; 'Patrick Shelston'; vfr@xxxxxx
Carl,
Dave Jordan
1997 VFR750F
Chicagoland
_____
Walzer, Carl (.)
Carl
_____
Patrick Shelston
To: vfr@xxxxxx
up).
pilots...
Cheers,
Patrick
Patrick,
Ed
1998 VFR800
_____
Ron
Chicago
Patrick Shelston >
wrote:
Good day members,
Patrick
1994 Honda VFR750F
Fuel injector/carb cleaner (was: Baseline carb setting for stock 94) Ed Kokosa VF/VFR Mailing List 3 04-09-2008 11:18 AM
RE: Fuel injector/carb cleaner (was: Baseline carb setting forstock94) Brad Berson VF/VFR Mailing List 2 04-09-2008 11:04 AM
RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock94) Ed Kokosa VF/VFR Mailing List 5 04-09-2008 11:00 AM
Carb maintenance update ... Olivier Gerouville VF/VFR Mailing List 0 01-29-2008 12:10 AM
Carb maintenance help Olivier Gerouville VF/VFR Mailing List 8 01-04-2008 03:02 PM
