RE: Fuel injector/carb cleaner (was: Baseline carb setting forstock94)
Yeah, but how does that compare to Lemon Pledge?
A little Google'ing and some interpolation tells this layman that Techron is a cousin to WD40. And that's NOT a troll... -----Original Message----- From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of Ed Kokosa Sent: Tuesday, April 08, 2008 10:56 PM To: vfr@xxxxxx Cc: 'Walzer, Carl (.)' Subject: RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock94) Carl, Not meaning to pick on your memory or spelling, but how about your info? I previously was not familiar with Seafoam, but looking at their website, umm, errr, well, me thinks that might be snake oil. I'm sure that plenty of people rave about it, but.... It supposedly: Stabilizes fuel Cleans carburetor Cleans carbon Removes moisture Assures fast starts Frees sticky rings Restores power Upper cylinder lube Smooths rough idle And you can pour it down the carb, pour it in your gas tank , or even pour it into your crankcase. Are you can't also use it as a desert topping? Per its MSDS, the components of (hazardous) interest are: Pale Oil, 40-60% by wt Naptha, 24-35% by wt IPA (Isopropyl alcohol) 10-20% by wt This is not comparable to Techron. It's MSDS (hazardous) components are: Distillates, hydrotreated light, < 55 %weight Stoddard solvent, < 35 %weight Solvent naphtha, light aromatic, 3 - 7 %weight Benzene, 1,2,4-trimethyl-, 1-5 %weight Xylene 0.1 - 0.5 %weight The proprietary item is polyether amine (PEA), which apparently does not require MSDS listing. Perhaps Seafoam also has some other active ingredients, I suspect (with no real knowledge, typically doesn't deter me) that it doesn't. Those three ingredients are it. The IPA removes moisture, the Naptha helps dissolve things. You could buy your own Naptha, mix it into some oil, good to go. I'll bring a bottle of Techron Concentrate Plus to COTU and we can do some shots in the parking lot. Your fuel injector preference may vary. Ed _____ From: Walzer, Carl (.) [mailto:CWALZER@xxxxxx] Sent: Tuesday, April 08, 2008 10:33 AM To: Ed Kokosa; vfr@xxxxxx Cc: 'DaCatDaddy'; 'Patrick Shelston' Subject: RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock 94) And if my memory or spelling ability worked, that would be the way I spell it. Seems to work real good. >From all the raving, the Seafoam stuff is about the same but marketed more to the ATV/PWC/motorcycle communities. Carl _____ The guys at SAABNET.com swear that the absolute best fuel injector cleaner uses Chevron Techron. I believe that there are only two products with it, same manufacturer (Chevron), and they are simply different concentrations. The stronger concentration seems to be the preferred. http://www.chevron.com/products/ourf...erv/additives/ Ed 1998 VFR800 2002 9-5 Aero SW _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Ed,
Good point and research. I will not be using anymore Seafoam. Thanks Dave Jordan 1997 VFR750F Chicagoland _____ From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of Ed Kokosa Sent: Tuesday, April 08, 2008 9:56 PM To: vfr@xxxxxx Cc: 'Walzer, Carl (.)' Subject: RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock94) Carl, Not meaning to pick on your memory or spelling, but how about your info? I previously was not familiar with Seafoam, but looking at their website, umm, errr, well, me thinks that might be snake oil. I'm sure that plenty of people rave about it, but.. It supposedly: Stabilizes fuel Cleans carburetor Cleans carbon Removes moisture Assures fast starts Frees sticky rings Restores power Upper cylinder lube Smooths rough idle And you can pour it down the carb, pour it in your gas tank , or even pour it into your crankcase. Are you can't also use it as a desert topping? Per its MSDS, the components of (hazardous) interest are: Pale Oil, 40-60% by wt Naptha, 24-35% by wt IPA (Isopropyl alcohol) 10-20% by wt This is not comparable to Techron. It's MSDS (hazardous) components are: Distillates, hydrotreated light, < 55 %weight Stoddard solvent, < 35 %weight Solvent naphtha, light aromatic, 3 - 7 %weight Benzene, 1,2,4-trimethyl-, 1-5 %weight Xylene 0.1 - 0.5 %weight The proprietary item is polyether amine (PEA), which apparently does not require MSDS listing. Perhaps Seafoam also has some other active ingredients, I suspect (with no real knowledge, typically doesn't deter me) that it doesn't. Those three ingredients are it. The IPA removes moisture, the Naptha helps dissolve things. You could buy your own Naptha, mix it into some oil, good to go. I'll bring a bottle of Techron Concentrate Plus to COTU and we can do some shots in the parking lot. Your fuel injector preference may vary. Ed _____ From: Walzer, Carl (.) [mailto:CWALZER@xxxxxx] Sent: Tuesday, April 08, 2008 10:33 AM To: Ed Kokosa; vfr@xxxxxx Cc: 'DaCatDaddy'; 'Patrick Shelston' Subject: RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock 94) And if my memory or spelling ability worked, that would be the way I spell it. Seems to work real good. >From all the raving, the Seafoam stuff is about the same but marketed more to the ATV/PWC/motorcycle communities. Carl _____ The guys at SAABNET.com swear that the absolute best fuel injector cleaner uses Chevron Techron. I believe that there are only two products with it, same manufacturer (Chevron), and they are simply different concentrations. The stronger concentration seems to be the preferred. http://www.chevron.com/products/ourf...erv/additives/ Ed 1998 VFR800 2002 9-5 Aero SW _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
I wish someone would market convenient motorcycle -size dosages of carb
cleaner. _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Fuel injector/carb cleaner (was: Baseline carb setting for stock 94) | Ed Kokosa | VF/VFR Mailing List | 3 | 04-09-2008 11:18 AM |
| RE: Fuel injector/carb cleaner (was: Baseline carb setting for stock94) | Ed Kokosa | VF/VFR Mailing List | 5 | 04-09-2008 11:00 AM |
| Baseline carb setting for stock 94 | Patrick Shelston | VF/VFR Mailing List | 7 | 04-07-2008 09:41 AM |
| Carb maintenance update ... | Olivier Gerouville | VF/VFR Mailing List | 0 | 01-29-2008 12:10 AM |
| Carb maintenance help | Olivier Gerouville | VF/VFR Mailing List | 8 | 01-04-2008 03:02 PM |
