Fork Oil vs. Synth ATF
Hmmmmm....you're probably right, Chris. Prior to the ATF, I was using 120 gear oil. I only noticed a slight improvement over the gear oil. Maybe I should go back to gear oil, since my front end is so "ill". Plus, I can put a hole in the fork, and run a tube to the chain. Then, whenever I hit a bump, I can lube the chain. Who needs vacuum pulses?
I guess, more than friction enhancers, what's important in terms of friction is the final friction coefficient of either fluid, not so much how that came to be. I don't know the friction coefficient of fork oil vs. synthetic ATF, or for that matter, a whole lot about it in general. I just know that it seems to work fine..... Dan B -----Original Message----- >From: Chris Burgess >Sent: Jan 19, 2006 11:57 AM >To: bob.harmon (AT) comcast (DOT) net, vfr (AT) cs (DOT) wisc.edu >Subject: RE: Front Fork Seals / bushings - what to order? > >The reason not to use ATF is that all ATF has friction enhancers added to >them to help enhance friction. This is a bad thing in forks as the last >thing you want is extra friction in your forks not coming from the >compression and rebound valving. > >Fork oil does not have these friction enhancers so your forks are going to >perform to the specs to how they are setup. > >I suspect the reason most of you don't notice a difference is that you have >such ill setup forks in the first place that 120w gear oil wouldn't be >noticed. > >-Chris > >________________________________ > >From: vfr-bounces (AT) cs (DOT) wisc.edu on behalf of bob.harmon (AT) comcast (DOT) net >Sent: Thu 1/19/2006 7:51 AM >To: vfr (AT) cs (DOT) wisc.edu >Subject: RE: Front Fork Seals / bushings - what to order? > > > >You can use ATF, my Hawk GT had it from the factory. I put one drop of brake >fluid in the fork on my KX125 and it stopped the leak. > >--94' VFR >Thanks, >Bob >_______________________________________________ >Vfr mailing list >Vfr (AT) cs (DOT) wisc.edu >For subscription and delivery options: >https://lists.cs.wisc.edu/mailman/listinfo/vfr > > _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: Fork Oil vs. Synth ATF
Geee....so fragile. :)
-Chris ________________________________ From: Dan Barufaldi [mailto:dbarufaldi (AT) earthlink (DOT) net] Sent: Thu 1/19/2006 9:42 AM To: Chris Burgess; bob.harmon (AT) comcast (DOT) net; vfr (AT) cs (DOT) wisc.edu Subject: Fork Oil vs. Synth ATF Hmmmmm....you're probably right, Chris. Prior to the ATF, I was using 120 gear oil. I only noticed a slight improvement over the gear oil. Maybe I should go back to gear oil, since my front end is so "ill". Plus, I can put a hole in the fork, and run a tube to the chain. Then, whenever I hit a bump, I can lube the chain. Who needs vacuum pulses? I guess, more than friction enhancers, what's important in terms of friction is the final friction coefficient of either fluid, not so much how that came to be. I don't know the friction coefficient of fork oil vs. synthetic ATF, or for that matter, a whole lot about it in general. I just know that it seems to work fine..... Dan B -----Original Message----- >From: Chris Burgess >Sent: Jan 19, 2006 11:57 AM >To: bob.harmon (AT) comcast (DOT) net, vfr (AT) cs (DOT) wisc.edu >Subject: RE: Front Fork Seals / bushings - what to order? > >The reason not to use ATF is that all ATF has friction enhancers added to >them to help enhance friction. This is a bad thing in forks as the last >thing you want is extra friction in your forks not coming from the >compression and rebound valving. > >Fork oil does not have these friction enhancers so your forks are going to >perform to the specs to how they are setup. > >I suspect the reason most of you don't notice a difference is that you have >such ill setup forks in the first place that 120w gear oil wouldn't be >noticed. > >-Chris > >________________________________ > >From: vfr-bounces (AT) cs (DOT) wisc.edu on behalf of bob.harmon (AT) comcast (DOT) net >Sent: Thu 1/19/2006 7:51 AM >To: vfr (AT) cs (DOT) wisc.edu >Subject: RE: Front Fork Seals / bushings - what to order? > > > >You can use ATF, my Hawk GT had it from the factory. I put one drop of brake >fluid in the fork on my KX125 and it stopped the leak. > >--94' VFR >Thanks, >Bob >_______________________________________________ >Vfr mailing list >Vfr (AT) cs (DOT) wisc.edu >For subscription and delivery options: >https://lists.cs.wisc.edu/mailman/listinfo/vfr > > _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Yo, I wish I had da ill setup forks, fo shizzle! My
homie had the Ohlins... they was da sickness, yo! http://www.urbandictionary.com/define.php?term=ill Warren --- Chris Burgess > Geee....so fragile. :) > > -Chris > > ________________________________ > > From: Dan Barufaldi > [mailto:dbarufaldi (AT) earthlink (DOT) net] > Sent: Thu 1/19/2006 9:42 AM > To: Chris Burgess; bob.harmon (AT) comcast (DOT) net; > vfr (AT) cs (DOT) wisc.edu > Subject: Fork Oil vs. Synth ATF > > > > > Hmmmmm....you're probably right, Chris. Prior to > the ATF, I was using 120 > gear oil. I only noticed a slight improvement over > the gear oil. Maybe I > should go back to gear oil, since my front end is so > "ill". Plus, I can put > a hole in the fork, and run a tube to the chain. > Then, whenever I hit a > bump, I can lube the chain. Who needs vacuum > pulses? > > I guess, more than friction enhancers, what's > important in terms of friction > is the final friction coefficient of either fluid, > not so much how that came > to be. I don't know the friction coefficient of > fork oil vs. synthetic ATF, > or for that matter, a whole lot about it in general. > I just know that it > seems to work fine..... > > Dan B > -----Original Message----- > >From: Chris Burgess > >Sent: Jan 19, 2006 11:57 AM > >To: bob.harmon (AT) comcast (DOT) net, vfr (AT) cs (DOT) wisc.edu > >Subject: RE: Front Fork Seals / bushings - what to > order? > > > >The reason not to use ATF is that all ATF has > friction enhancers added to > >them to help enhance friction. This is a bad thing > in forks as the last > >thing you want is extra friction in your forks not > coming from the > >compression and rebound valving. > > > >Fork oil does not have these friction enhancers so > your forks are going to > >perform to the specs to how they are setup. > > > >I suspect the reason most of you don't notice a > difference is that you have > >such ill setup forks in the first place that 120w > gear oil wouldn't be > >noticed. > > > >-Chris > > > >________________________________ > > > >From: vfr-bounces (AT) cs (DOT) wisc.edu on behalf of > bob.harmon (AT) comcast (DOT) net > >Sent: Thu 1/19/2006 7:51 AM > >To: vfr (AT) cs (DOT) wisc.edu > >Subject: RE: Front Fork Seals / bushings - what to > order? > > > > > > > >You can use ATF, my Hawk GT had it from the > factory. I put one drop of > brake > >fluid in the fork on my KX125 and it stopped the > leak. > > > >--94' VFR > >Thanks, > >Bob > >_______________________________________________ > >Vfr mailing list > >Vfr (AT) cs (DOT) wisc.edu > >For subscription and delivery options: > >https://lists.cs.wisc.edu/mailman/listinfo/vfr > > > > > > > > > _______________________________________________ > Vfr mailing list > Vfr (AT) cs (DOT) wisc.edu > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr Passion is the difference between living and existing _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
>From: Dan Barufaldi
>I guess, more than friction enhancers, what's important in terms of >friction is the final friction >coefficient of either fluid, not so much >how that came to be. I don't know the friction coefficient >of fork oil >vs. synthetic ATF, or for that matter, a whole lot about it in general. I >just know that it >seems to work fine..... I looked it up awhile ago and M-1 synthetic ATF has almost identical viscosity to 10wt Golden Spectro fork oil. I tried the M-1 synth ATF in my VFR's stock 41mm stock forks and it seemed no different than any other fork oil I've used in the past. Later...ROB '99 GL800RR-SP2 Spouse's- '90VTR250 Profile Page: http://profiles.yahoo.com/veefer800canuck Website: http://www.geocities.com/veefer800canuck/index.html _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: RE: Fork Oil vs. Synth ATF
Removed original fork oil...
Replaced with ATF... Feels great... No worries... Bob in Tucson Then: 90 VTR 250 98 VFR 800 03 CBR F4i Now: 01 VFR 800 04 Chevy Avalanche http://vifferman.tripod.com/vfr_album/ http://www.frappr.com/?a=myfrappr&id=72717 _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
For how often you replace fork oil, is buying a lubricant designed
for the job really that expensive? Yeah, ATF will work. But it still isn't as good as something designed for the application from the start. It is also available in different viscosities, unlike ATF, so you can set up your forks properly. Not every fork set-up calls for 7wt oil, which is about the viscosity of ATF. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: RE: Fork Oil vs. Synth ATF
Mobil 1 Synth ATF is negligibly less expensive than fork oil? Why would you
assume this was based on cost? You simply cannot assert that it isn't as good as something "designed" for the application. For some, it seems to work better. The viscosity appears to be fine for my use. If I needed a different viscosity, I would do what I did when I chose synth ATF. Research what works. And I think synth ATF be less temperature sensitive (viscosity) than conventional fork oil, at my environmental temps (yes, if you had it in your tranny, and overheated the car, it would be damaged....I'm talking about 80 degrees vs. 20 degrees, ambient temps that I encounter while riding). I know the front suspension gets less "brick-like" in the cold than it used to. Dan B -----Original Message----- From: vfr-bounces (AT) cs (DOT) wisc.edu [mailto:vfr-bounces (AT) cs (DOT) wisc.edu] On Behalf Of Michael T. Kasimirsky Sent: Sunday, January 22, 2006 10:56 AM To: vfr (AT) cs (DOT) wisc.edu Subject: Re: RE: Fork Oil vs. Synth ATF For how often you replace fork oil, is buying a lubricant designed for the job really that expensive? Yeah, ATF will work. But it still isn't as good as something designed for the application from the start. It is also available in different viscosities, unlike ATF, so you can set up your forks properly. Not every fork set-up calls for 7wt oil, which is about the viscosity of ATF. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
> Why would you > assume this was based on cost? You simply cannot assert that > it isn't as > good as something "designed" for the application. For some, > it seems to > work better. The viscosity appears to be fine for my use. > If I needed a > different viscosity, I would do what I did when I chose synth > ATF. Research what works. Actually, yes, I can assert that it isn't as good as something that was designed for that application. To do otherwise would be to ignore the whole industry that develops oil additives. I guarantee they don't use the same additive package in ATF that they use in fork oils. The applications are different and additves are expensive so they don't add them unless they serve some practical purpose. In the case of ATF, additives put in there for the health of the transmission clutch packs serve no purpose in a motorcycle fork. > And I think synth ATF be less temperature sensitive (viscosity) than > conventional fork oil, at my environmental temps (yes, if you > had it in your > tranny, and overheated the car, it would be damaged....I'm > talking about 80 > degrees vs. 20 degrees, ambient temps that I encounter while > riding). I > know the front suspension gets less "brick-like" in the cold > than it used to. Temps of 80 versus 20 make no difference to oils, period. And yes, I used to work in the oil industry so I can say that with 100% confidence. I could care less what you use, but this assertion that ATF is somehow better than a product engineered for that application is a stretch. It might have made sense when fork oil was hard to find, but that isn't the case today. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Fork Oil vs. Synth ATF
On Jan 22, 2006, at 09:28, Dan Barufaldi wrote:
> Mobil 1 Synth ATF is negligibly less expensive than fork oil? Why > would you > assume this was based on cost? You simply cannot assert that it > isn't as > good as something "designed" for the application. Certainly you can. ATF is optimized for use in automatic transmissions - hence the name. Motorcycle fork damping is a different operating environment entirely - heat, pressure, shear, etc. By definition, if something is optimized for one application it CAN'T be optimized for a totally different one. KeS _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
>with 100% confidence. > >I could care less what you use, but this assertion that ATF is >somehow better than a product engineered for that application >is a stretch. > This discussion has gotten out of hand. Someone recently remarked about how the number of posts has fallen dramatically on this board in the past couple of years? Perhaps discussions like this are part of the reason. Here we have Dan, a long-time, respected list member saying he has used Mobil 1 Synthetic ATF in his VFR forks and it works well. That's solid, if anecdotal, evidence that the item in question works. What he hasn't mentioned is that we've had this same discussion several times in the past decade, and that there are a pretty fair number of experienced VFR riders and list members who ALSO use this product, and who ALSO are getting very good results from it. That raises it from anecdotal evidence to proven results. Then on the other side are a small cadre of folks I've never heard from before who are claiming that the stuff can't be any good because we're using it in an "off-prescription" manner or "unauthorized" application. Significantly, NONE OF THEM CLAIM TO HAVE ACTUALLY TRIED IT THEMSELVES. They just say it shouldn't work. The list has shrunk over the past couple of years as more and more of the experienced, knowledgeable members have decided they'd had enough of putting up with newbies who know it all and can't be bothered to check out the archives to see if the their questions have already been answered. Veteran member Oil Guy got flamed unmercifully recently--and the result is that the list lost the experience and knowledge of a life-long professional petroleum engineer whom any other vehicle-related list would give their eye-teeth to have on board. Also recently another newbie, 'Chat-with-Johnny', performed a feat I've never seen happen on a big list before: his inanity just about destroyed what was left of the list, single-handedly. I'm just about ready to call it quits with this list, myself. I've been here for 8 years, and lately the signal-to-noise ratio has increased just about to the breaking point. Not that MY leaving would be a significant blow to the list--I never claimed to be a super-mechanic. But I do have a news flash: --the really knowledgeable guys...the ones that seem to be leaving in larger and larger numbers...they can go off by themselves and do just fine. They've got experience, knowledge, and common sense. They don't NEED the list ; it's the list that needs them. Gee, I haven't started a flame war in years. Maybe it would be best after all if this list just 'went Nova'. It's been painful to watch it just wither away for the last couple of years. Regards, BurmaWolf _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
>From: Fred Hunter
>Then on the other side are a small cadre of folks I've never heard from >before who are claiming that the stuff can't be any good because we're >using it in an "off-prescription" manner or "unauthorized" application. >Significantly, NONE OF THEM CLAIM TO HAVE ACTUALLY TRIED IT THEMSELVES. >They just say it shouldn't work. And don't ever modify your exhaust as it will "increase noise and decrease performance" according to Honda. And only use the exact brand and size tires specified in the owner's manual at only the recommended pressures, and for GOD'S SAKE MAN, DON'T USE ANYTHING OTHER THAN PRO HONDA 10W40 OIL IN YOUR VFR OR YOUR HARD DRIVE IN YOUR COMPUTER WILL EXPLODE. Hey, I've ran the M1 synth ATF in my forks for the last couple of years. Seals did not leak, the forks still forked, and it felt way better than the old dirty fluid. I ain't Rossi or Mladin, so I couldn't tell you anything other than that. It's equal to 10 Wt viscosity as per the data sheets from Mobil's website. Did I save money buying M-1 Synth ATF at Canadian Tire as opposed to going to the shitty little local Mom 'n Pop ATV/lawnmower/snowblower shop (only game in town, BTW) and getting Bel-Ray fork oil at 12.95/litre because that's all they carry? Yes, I most certainly did. Use whatever brand/type/weight fork fluid smells the best behind your ears and go ride. Later...ROB '99 GL800RR-SP2 Spouse's- '90VTR250 Profile Page: http://profiles.yahoo.com/veefer800canuck Website: http://www.geocities.com/veefer800canuck/index.html _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
> >with 100% confidence. > > > >I could care less what you use, but this assertion that ATF is > >somehow better than a product engineered for that application > >is a stretch. > > > > This discussion has gotten out of hand. Someone recently > remarked about > how the number of posts has fallen dramatically on this board in the > past couple of years? Perhaps discussions like this are part > of the reason. > > Here we have Dan, a long-time, respected list member saying > he has used > Mobil 1 Synthetic ATF in his VFR forks and it works well. "Worked" and "better" are two different things. Yes, it worked. I never said it didn't. But saying it is "better" is a SERIOUS stretch of the imagination. And frankly, I don't give a good dump about "long-time respected members" of the list. Nothing personal against Dan, but incorrect opinions, held for long periods of time, doesn't make them any more correct. > What he hasn't mentioned is that we've had this same > discussion several > times in the past decade, and that there are a pretty fair number of > experienced VFR riders and list members who ALSO use this > product, and > who ALSO are getting very good results from it. That raises it from > anecdotal evidence to proven results. See above. "Working" and "better" are two radically different things. In addition, comparing new ANYTHING to the old crap in your forks is also a completely bogus comparison. New ANYTHING is better than old oil. If you want a legitimate comparison, you need to compare new ATF to new fork oil, not old crap to new ATF. The whole arguement about the cost of fork oil is also a joke, in my opinion. You change fork oil so infreqently that the additional cost is immaterial. If you're that hard up for money that fork oil costs are significant, that VFR had better be your sole source of transportation because you can't afford a recreational vehicle. If you want to run ATF in your forks, knock yourself out. I'll put Race Tech fork oil in mine, thanks. Michael T. Kasimirsky mtk21 (AT) adelphia (DOT) net 1996 VFR750F _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Perhaps I did not read this thread right. I am pretty sure all that was
said was that ATF worked fine for whoever posted. Did not read anywhwere where anyone claimed it was "better", just that it worked fine for them. Opinions are neither correct or incorrect, they are opinions, that is why we have that specific word. doug -----Original Message----- From: vfr-bounces (AT) cs (DOT) wisc.edu [mailto:vfr-bounces (AT) cs (DOT) wisc.edu] On Behalf Of Michael T. Kasimirsky Sent: January 22, 2006 6:35 PM To: 'Fred Hunter' Cc: vfr (AT) cs (DOT) wisc.edu Subject: RE: Fork Oil vs. Synth ATF > >And yes, I used to work in the oil industry so I can say that with > >100% confidence. > > > >I could care less what you use, but this assertion that ATF is > >somehow better than a product engineered for that application is a > >stretch. > > > > This discussion has gotten out of hand. Someone recently remarked > about how the number of posts has fallen dramatically on this board in > the past couple of years? Perhaps discussions like this are part of > the reason. > > Here we have Dan, a long-time, respected list member saying he has > used Mobil 1 Synthetic ATF in his VFR forks and it works well. "Worked" and "better" are two different things. Yes, it worked. I never said it didn't. But saying it is "better" is a SERIOUS stretch of the imagination. And frankly, I don't give a good dump about "long-time respected members" of the list. Nothing personal against Dan, but incorrect opinions, held for long periods of time, doesn't make them any more correct. > What he hasn't mentioned is that we've had this same discussion > several times in the past decade, and that there are a pretty fair > number of experienced VFR riders and list members who ALSO use this > product, and who ALSO are getting very good results from it. That > raises it from anecdotal evidence to proven results. See above. "Working" and "better" are two radically different things. In addition, comparing new ANYTHING to the old crap in your forks is also a completely bogus comparison. New ANYTHING is better than old oil. If you want a legitimate comparison, you need to compare new ATF to new fork oil, not old crap to new ATF. The whole arguement about the cost of fork oil is also a joke, in my opinion. You change fork oil so infreqently that the additional cost is immaterial. If you're that hard up for money that fork oil costs are significant, that VFR had better be your sole source of transportation because you can't afford a recreational vehicle. If you want to run ATF in your forks, knock yourself out. I'll put Race Tech fork oil in mine, thanks. Michael T. Kasimirsky mtk21 (AT) adelphia (DOT) net 1996 VFR750F _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#14 (permalink) |
>From: "Michael T. Kasimirsky"
>If you want to run ATF in your forks, knock yourself out. I'll put Race >Tech fork oil in mine, thanks. And I repeat: "Use whatever brand/type/weight fork fluid smells the best behind your ears and go ride." Later...ROB '99 GL800RR-SP2 Spouse's- '90VTR250 Profile Page: http://profiles.yahoo.com/veefer800canuck Website: http://www.geocities.com/veefer800canuck/index.html _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Wow....so much wrong with what you're saying, it's not even worth arguing
about. Have a nice day -----Original Message----- From: Michael T. Kasimirsky [mailto:mtk21 (AT) adelphia (DOT) net] Sent: Sunday, January 22, 2006 1:36 PM To: dbarufaldi (AT) earthlink (DOT) net; vfr (AT) cs (DOT) wisc.edu Subject: RE: RE: Fork Oil vs. Synth ATF > Mobil 1 Synth ATF is negligibly less expensive than fork oil? > Why would you > assume this was based on cost? You simply cannot assert that > it isn't as > good as something "designed" for the application. For some, > it seems to > work better. The viscosity appears to be fine for my use. > If I needed a > different viscosity, I would do what I did when I chose synth > ATF. Research what works. Actually, yes, I can assert that it isn't as good as something that was designed for that application. To do otherwise would be to ignore the whole industry that develops oil additives. I guarantee they don't use the same additive package in ATF that they use in fork oils. The applications are different and additves are expensive so they don't add them unless they serve some practical purpose. In the case of ATF, additives put in there for the health of the transmission clutch packs serve no purpose in a motorcycle fork. > And I think synth ATF be less temperature sensitive (viscosity) than > conventional fork oil, at my environmental temps (yes, if you > had it in your > tranny, and overheated the car, it would be damaged....I'm > talking about 80 > degrees vs. 20 degrees, ambient temps that I encounter while > riding). I > know the front suspension gets less "brick-like" in the cold > than it used to. Temps of 80 versus 20 make no difference to oils, period. And yes, I used to work in the oil industry so I can say that with 100% confidence. I could care less what you use, but this assertion that ATF is somehow better than a product engineered for that application is a stretch. It might have made sense when fork oil was hard to find, but that isn't the case today. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#16 (permalink) |
I don't see the problem here, I only use Wesson(tm) oil in my forks, it works great and I can deep fry potato strips in my forks just by driving on the BQE from Astoria to the Brooklyn Bridge.
I just have to be careful not to let any of the Wesson(tm) oil drip onto my tire plugs, or I have to use lemon Pledge(tm) to fix the mess. -Brad -----Original Message----- From: vfr-bounces (AT) cs (DOT) wisc.edu [mailto:vfr-bounces (AT) cs (DOT) wisc.edu]On Behalf Of Dan Barufaldi Sent: Sunday, January 22, 2006 10:15 PM To: mtk21 (AT) adelphia (DOT) net; vfr (AT) cs (DOT) wisc.edu Subject: RE: RE: Fork Oil vs. Synth ATF Wow....so much wrong with what you're saying, it's not even worth arguing about. Have a nice day -----Original Message----- From: Michael T. Kasimirsky [mailto:mtk21 (AT) adelphia (DOT) net] Sent: Sunday, January 22, 2006 1:36 PM To: dbarufaldi (AT) earthlink (DOT) net; vfr (AT) cs (DOT) wisc.edu Subject: RE: RE: Fork Oil vs. Synth ATF > Mobil 1 Synth ATF is negligibly less expensive than fork oil? > Why would you > assume this was based on cost? You simply cannot assert that > it isn't as > good as something "designed" for the application. For some, > it seems to > work better. The viscosity appears to be fine for my use. > If I needed a > different viscosity, I would do what I did when I chose synth > ATF. Research what works. Actually, yes, I can assert that it isn't as good as something that was designed for that application. To do otherwise would be to ignore the whole industry that develops oil additives. I guarantee they don't use the same additive package in ATF that they use in fork oils. The applications are different and additves are expensive so they don't add them unless they serve some practical purpose. In the case of ATF, additives put in there for the health of the transmission clutch packs serve no purpose in a motorcycle fork. > And I think synth ATF be less temperature sensitive (viscosity) than > conventional fork oil, at my environmental temps (yes, if you > had it in your > tranny, and overheated the car, it would be damaged....I'm > talking about 80 > degrees vs. 20 degrees, ambient temps that I encounter while > riding). I > know the front suspension gets less "brick-like" in the cold > than it used to. Temps of 80 versus 20 make no difference to oils, period. And yes, I used to work in the oil industry so I can say that with 100% confidence. I could care less what you use, but this assertion that ATF is somehow better than a product engineered for that application is a stretch. It might have made sense when fork oil was hard to find, but that isn't the case today. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#17 (permalink) |
I didn't realize you sent this to the entire list.
To paraphrase your response, in other words you don't have anything to say other than to attempt to disparage the author, followed by some bullshit "have a nice day" comment. If you have a legitimate point, then make it. Otherwise, you can stuff the "have a nice day" comment as the context in which it was made was condescending. > Wow....so much wrong with what you're saying, it's not even > worth arguing > about. > > Have a nice day > _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#18 (permalink) |
Brad, you idiot !!!!
Don't you know that Honda recomendations clearly state that only extra extra virgin olive oil is to be used in forks ?? Blinker fluid replacement, on the other hand......... Brad Berson wrote: I don't see the problem here, I only use Wesson(tm) oil in my forks, it works great and I can deep fry potato strips in my forks just by driving on the BQE from Astoria to the Brooklyn Bridge. I just have to be careful not to let any of the Wesson(tm) oil drip onto my tire plugs, or I have to use lemon Pledge(tm) to fix the mess. -Brad --------------------------------- Yahoo! Photos – Showcase holiday pictures in hardcover Photo Books. You design it and we’ll bind it! _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#19 (permalink) |
I thought the problem would have been with the brake fuild!
94' VFR-- Thanks, Bob _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#20 (permalink) |
That's a lot of anger for a simple disagreement. My legitimate point has already been made. You don't have to agree, that's fine with me.
Have a nice day (I actually mean "Have a nice day") Dan B -----Original Message----- >From: "Michael T. Kasimirsky" >Sent: Jan 22, 2006 11:36 PM >To: vfr (AT) cs (DOT) wisc.edu >Subject: RE: RE: Fork Oil vs. Synth ATF > >I didn't realize you sent this to the entire list. > >To paraphrase your response, in other words you don't have anything >to say other than to attempt to disparage the author, followed by >some bullshit "have a nice day" comment. > >If you have a legitimate point, then make it. Otherwise, you can >stuff the "have a nice day" comment as the context in which it was >made was condescending. > >> Wow....so much wrong with what you're saying, it's not even >> worth arguing >> about. >> >> Have a nice day >> >_______________________________________________ >Vfr mailing list >Vfr (AT) cs (DOT) wisc.edu >For subscription and delivery options: >https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#21 (permalink) |
On 1/22/06, Fred Hunter
> > > This discussion has gotten out of hand. Someone recently remarked about > how the number of posts has fallen dramatically on this board in the > past couple of years? Perhaps discussions like this are part of the > reason. I'm with Fred here. The list has shrunk over the past couple of years as more and more of > the experienced, knowledgeable members have decided they'd had enough of > putting up with newbies who know it all and can't be bothered to check > out the archives to see if the their questions have already been > answered. I'm just about ready to call it quits with this list, myself. I've been > here for 8 years, and lately the signal-to-noise ratio has increased > just about to the breaking point. > > Not that MY leaving would be a significant blow to the list--I never > claimed to be a super-mechanic. But I do have a news flash: > --the really knowledgeable guys...the ones that seem to be leaving in > larger and larger numbers...they can go off by themselves and do just > fine. They've got experience, knowledge, and common sense. They don't > NEED the list ; it's the list that needs them. Thanks Fred. This petty BS really should stop. It's like a contest to see who can pee higher on the fence. Hopefully we are all over the age of 12 by now. ;-) It's not like someone told you that your first born child was ugly. Come on folks. BTW, I use Mobil 1 ATF in my forks which have RaceTech springs and full internals from the F3. Check the Archives for how to do it. -- John in Calif AMA #774570 01 RSVR 98 VFR800 FI 85 RZ350N YPVS 85 RZ500LC YPVS If you land on your head, you didn't use enough throttle when needed. If you land on your ass, you used too much throttle... _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#22 (permalink) |
Well said, Fred. I'm getting close to the same point. It's a shame,
really. When I got my first VFR, this list was a huge resource for me, and I learned a lot....a whole lot. I am not bailing yet, but I would like to offer this to the newbies, and those who should know better: Keep it simple, polite and brief. If you disagree, disagree with the facts - a person with a different opinion is something to embrace, not rebuff. Learn what you can, add what you can. I am guilty of not doing all those things - and I usually try to apologize when I've strayed too far. As a moderator of another list, these are things that appeared to me to be universal to a successful board. Dan B -----Original Message----- From: Fred Hunter [mailto:fhunter (AT) kcnet (DOT) com] Sent: Sunday, January 22, 2006 3:09 PM To: mtk21 (AT) adelphia (DOT) net Cc: dbarufaldi (AT) earthlink (DOT) net; vfr (AT) cs (DOT) wisc.edu Subject: Re: Fork Oil vs. Synth ATF >And yes, I used to work in the oil industry so I can say that >with 100% confidence. > >I could care less what you use, but this assertion that ATF is >somehow better than a product engineered for that application >is a stretch. > This discussion has gotten out of hand. Someone recently remarked about how the number of posts has fallen dramatically on this board in the past couple of years? Perhaps discussions like this are part of the reason. SNIP _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#23 (permalink) |
Can't for the life of me see why anyone would want to use anything but fork
oil. It has anti-foaming agents, anti-friction agents, anti-oxidizing agents, anti-shearing agents, and a set viscosity on the label that you can somewhat rely on. It is specifically designed for FORKS not transmissions. ATF is old school that kind of works OK but it can't be as good as the real McCoy --- boys. I would never fork around and use anything but the "stuff" that was made to work. OTOH I don't buy into the motorcycle oil only idea (but that is for another thread that has yet to be covered) so how could you ever rely on what I just wrote. Bob in Tenn. too close to Deals Gap to be trusted. _______________________________________________ Vfr mailing list Vfr (AT) cs (DOT) wisc.edu For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Fork Seal Replacement | masonv45 | Suspension Articles | 21 | 08-24-2009 05:02 PM |
| Please help, I wanna ride! | xN8x | Mechanics Garage | 5 | 04-17-2007 12:35 PM |
| Fork Chirp? | Thrash1 | Mechanics Garage | 0 | 04-24-2006 04:32 PM |
| Spinning fork tube allen bolt? Help..... | vfr800fi | VF/VFR Mailing List | 3 | 02-14-2006 11:18 PM |
| RE: Front Fork Seals / ATF /FrictionEnhancers??? | John Harrison | VF/VFR Mailing List | 0 | 01-20-2006 12:42 PM |
