Old 01-20-2006, 12:42 PM   #1 (permalink)
John Harrison
RE: Front Fork Seals / ATF /FrictionEnhancers???
Since you brought it up, maybe it would be better if you cited the data
that confirms that there are friction enhancers in ATF...
John Harrison
Birmingham
From: vfr-bounces (AT) cs (DOT) wisc.edu [mailto:vfr-bounces (AT) cs (DOT) wisc.edu] On Behalf
Of Chris Burgess
Sent: Friday, January 20, 2006 12:06 PM
To: Matt Fitzsimmons; vfr (AT) cs (DOT) wisc.edu
Subject: RE: Front Fork Seals / ATF /FrictionEnhancers???
What piece of data tells you that there aren't friction enhancers in
ATF?
-Chris
_____
From: vfr-bounces (AT) cs (DOT) wisc.edu on behalf of Matt Fitzsimmons
Sent: Thu 1/19/2006 11:22 AM
To: vfr (AT) cs (DOT) wisc.edu
Subject: Re: Front Fork Seals / ATF /FrictionEnhancers???
ATF has friction enhancers added to them to help enhance friction.
Help me out here......
Why would friction enhancers be added to automatic transmission fluid?
Inquiring minds want to know?
Don't worry, there aren't any. ATF is hydraulic fliud, and it does have
addatives; anti corrosion, anti foam, as such, makes an excellent fork
oil. What you do need to careful of is the compatibility with the seals.
This is the same issue with using some ATFs in different transmissions.
Use Mercon 5 in your Ford, not "Rapid Lude all purpose" (wonder how I
know?)
They guys I know with dirt bikes always use ATF. The only real
difference is the viscocity label on fork oil, and the size of the
package. Dirt bikes sometimes need a lot of fork oil. Turns out, the
oil (or the seals for that matter) never seem to stay in the fork long
enough to find out if they're compatible.
Vfr (AT) cs (DOT) wisc.edu
Fork Seal Replacement masonv45 Suspension Articles 21 08-24-2009 05:02 PM
Please help, I wanna ride! xN8x Mechanics Garage 5 04-17-2007 12:35 PM
Front Fork Seals / bushings - what to order? vfr800fi VF/VFR Mailing List 6 01-20-2006 11:43 AM
RE: Front Fork Seals / bushings - what to order? /FrictionEnhancers??? Doug Scott VF/VFR Mailing List 2 01-20-2006 11:43 AM
Re: Front Fork Seals / bushings - what to order? / Yes / Loose Lips =Big Thread Mrydr VF/VFR Mailing List 0 01-18-2006 07:42 AM
