Old 06-12-2008, 03:49 PM   #1 (permalink)
Andrew Bertsch
Subject: Re: Stator (?) question
Vic ~
Sorry, but a hot idle of 12.4-12.5 is not at all 'normal' in my experience.
My '99 never idles below the 13.7-13.9 range. That has been the case with
my OEM R/R as well as the upgraded Honda R/R. I recall a List thread
several years ago that discussed this issue and the fact that bikes of the
same year often produce different charging patterns. Mine (like a number of
others') has always produced a higher charge at idle than at
speed...generally 13.9-14.2 at idle and 13.6-13.8 at speed. My point here
is simply that it appears there is really no such thing as "normal" when it
comes to the VFR's charging system. Everyone seems to have a different
story.
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
Message: 2
Date: Wed, 11 Jun 2008 07:56:00 -0700 (PDT)
To: mmcham@xxxxxx-pc.org
Cc: vfr@xxxxxx
Message-ID: <829697.13617.qm@xxxxxx>
Content-Type: text/plain; charset="iso-8859-1"
What you describe is totally normal for the stock charging system. In fact,
your system is performing on the high end of normal. Normally a hot bike
will idle down around 12.4 to 12.5 (which is fine) and get its maximum
output (13.8-14.2) about 1700 rpm and then drop down as rpms rise often
stabilizing between 13.2 and 13.8 at > 5000 rpms. Just ride but carry a
spare RR. This weird charging pattern is totally RR related and they do fail
quite regularly. I changed my RR out for a R1 RR and all of the weirdness
went away. If you want more on the R1 RR swapout, search the archives.
While stators will occassionally fail, they are much more reliable than are
the Honda RRs. I am 99.9% sure your stator has nothing to do with the
charging pattern you describe. It has to do with the design of the RR and
its heat, not engine heat. Try to hold your hand on your RR once the bike is
warmed up.
Vic
_____
I am using the free version of SPAMfighter for private users.
It has removed 13987 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter for free now!
Old 06-12-2008, 04:26 PM   #2 (permalink)
vic5491
Re: Subject: Re: Stator (?) question
Andrew, my comment is based on 5 years of hearing multiple threads on this issue, my own experience and the experience of other VFR riders I know. I eliminated the "mutant anomolies" that have been mentioned, such as yours, when I spoke of normal. An idle output of 13.7 - 13.9 is, IMHO, very abnormal for a VFR with a Honda RR.
Vic
Andrew Bertsch wrote:
Vic ~
Sorry, but a hot idle of 12.4-12.5 is not at all 'normal' in my experience. My '99 never idles below the 13.7-13.9 range. That has been the case with my OEM R/R as well as the upgraded Honda R/R. I recall a List thread several years ago that discussed this issue and the fact that bikes of the same year often produce different charging patterns. Mine (like a number of others') has always produced a higher charge at idle than at speed...generally 13.9-14.2 at idle and 13.6-13.8 at speed. My point here is simply that it appears there is really no such thing as "normal" when it comes to the VFR's charging system. Everyone seems to have a different story.
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
Message: 2
Cc: vfr@xxxxxx
What you describe is totally normal for the stock charging system. In fact, your system is performing on the high end of normal. Normally a hot bike will idle down around 12.4 to 12.5 (which is fine) and get its maximum output (13.8-14.2) about 1700 rpm and then drop down as rpms rise often stabilizing between 13.2 and 13.8 at > 5000 rpms. Just ride but carry a spare RR. This weird charging pattern is totally RR related and they do fail quite regularly. I changed my RR out for a R1 RR and all of the weirdness went away. If you want more on the R1 RR swapout, search the archives.
While stators will occassionally fail, they are much more reliable than are the Honda RRs. I am 99.9% sure your stator has nothing to do with the charging pattern you describe. It has to do with the design of the RR and its heat, not engine heat. Try to hold your hand on your RR once the bike is warmed up.
Vic
Old 06-12-2008, 04:43 PM   #3 (permalink)
Andrew Bertsch
RE: Subject: Re: Stator (?) question
Vic ~
Check the archives. I've been a List member for 9 years, and while there
hasn't been any defining survey done, I recall a brief thread where several
Listers reported charge rates similar to mine for the 5th gen. Not
sure...it may be an exception to the rule, but I would suggest that my
experience is at least 5th-gen specific as each generation exhibits a
different charging pattern, and I've not heard of my experience other than
with a 98-2001 VFR.
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
Sent: Thursday, June 12, 2008 6:26 PM
To: Andrew Bertsch
Cc: VFR Mailing List
Subject: Re: Subject: Re: Stator (?) question
Vic
Vic ~
story.
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
Message: 2
Cc: vfr@xxxxxx
warmed up.
Vic
_____
_____
Old 06-12-2008, 05:50 PM   #4 (permalink)
vic5491
Andrew, it is just not worth the effort to debate this. Suffice to say, most Honda RRs create problems.
Vic
Vic ~
Check the archives. I've been a List member for 9 years, and while there hasn't been any defining survey done, I recall a brief thread where several Listers reported charge rates similar to mine for the 5th gen. Not sure...it may be an exception to the rule, but I would suggest that my experience is at least 5th-gen specific as each generation exhibits a different charging pattern, and I've not heard of my experience other than with a 98-2001 VFR.
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
To: Andrew Bertsch
Vic
Vic ~
Andrew Bertsch
'99VFR800FI/Sargent
Cogito Ergo Zoom
Sidney, Ohio
abertsch1@xxxxxx
Message: 2
Cc: vfr@xxxxxx
Vic
RE: vfr Digest, Vol 43, Issue 8 Andrew Bertsch VF/VFR Mailing List 1 10-04-2007 05:05 PM
RE: vfr Digest, Vol 30, Issue 7 Zenon VF/VFR Mailing List 0 09-05-2006 01:24 PM
No Subject Jeff VF/VFR Mailing List 0 08-09-2006 06:14 PM
2003 Clutch Levers Kyle Allen VF/VFR Mailing List 0 06-09-2006 10:29 AM
RE: Vfr Digest, Vol 25, Issue 25 tryit VF/VFR Mailing List 0 04-16-2006 11:45 AM
