Old 12-31-1969, 05:00 PM   #1 (permalink)
bob prohaska's vfr list account
Re: 93 starter relay burnout
On Fri, 10 Feb 2006, Bradley E. Rogers wrote:
> The starter relay on my 93 fried the connections to the wiring harness
> and I need some of the collective knowledge of the list. I have checked
> the Reg/Rec and it looks okay but I may have them check at the dealers
Not sure this is applicable to a '93, but it's worked decently on a '98:
http://www.zefox.net/~bob/mc/vfr/vfrfix.gif
The change is rather subtle, drop me a note if you don't catch it.
bob prohaska
Vfr@xxxxxx
Old 02-10-2006, 09:35 PM   #2 (permalink)
Bradley E. Rogers
when I run over there (probably won't cost me anything). What else
should I check? What are my options on replacing the relay and
connector (besides getting another wiring harness)?
bradley rogers
Vfr@xxxxxx
Old 02-11-2006, 01:10 PM   #3 (permalink)
Christopher Stumpf
> Thanks,
> bradley rogers
Best bet is to go to a boneyard and find a bike with a suitable relay
and cut the connector off the harness to go with it. Then you can
splice it into your wire harness. Otherwise there is no other way to
obtain said connector without purchasing an entire wire harness. I've
got a relay off of a different Honda sitting on the shelf, I think it
was a cbr600. Don't remember the year. Anyway, I discovered that it
wouldn't work in my VFR750 because the positive and negative terminals
were reveresed and the terminals on the ends of the pos/neg wires on the
VFR are tabbed so as to only fit on one side. So I ended up buying a
new relay from honda so that the power leads would connect without
trouble. Then I discovered that the 4 wires in the connector that had
melted on mine were not in the same positions. So I had to swap them.
Make sure you check and correct the position of the wires if you do what
I did and buy a connector off a different bike.
Chris Stumpf
Vfr@xxxxxx
1987 VFR electrics/starting/fuses normalcyispasse Mechanics Garage 44 04-09-2008 09:39 AM
Starter relay connector tookhul VF/VFR Mailing List 8 11-03-2007 07:11 PM
starter relay? rpicheme Mechanics Garage 9 09-18-2007 09:48 PM
Re: electrical gremlin / Check Main Fuse and Starter Relay Area..... Mrydr VF/VFR Mailing List 0 09-06-2007 06:11 PM
RE: was : Testing a relay? Now FI light problem fixed! Doug Scott VF/VFR Mailing List 2 01-26-2006 06:55 PM
