electrical problem - nothing works but the clock,and that ain't doing so well
I have a 2000 VFR with about 28K miles. About 2 months ago, I had 4 or 5 episodes where when I started the bike, it didn't immediately start, and the clock and the trip odometers were set back to 01:00 and 0, respectively.
I did some research in the archives and found that several people have experienced this problem. There were a number of theories on why this happens, including a bad cell in the battery or an R/R that was about to fail. I checked my battery and it had a good charge but not full power. I fully charged it and I had no problems for about 4 weeks, until about 2 weeks ago. On that day, when I went to restart the bike after a 20-mile ride and then sitting for 10 minutes, nothing happened when I pushed the starter button. The clock and odometers were reset and there was no noise from the starter at all. I was out of town for the last 2 weeks and while gone, I fully charged the battery even though the lights on the charger indicated that it didn't need a charge. When I then put the battery back in the bike and turned the key on, the indicator lights glowed dimly and then slowly faded. I heard a fading whining noise from the instrument cluster area, like something electrical was discharging. I heard one click from the mid-section of the bike (may have been the fuel pump?) and then everything was dead. At this point the clock is working, but when I turn the key to the 'On' position, the clock disappears after a couple of seconds. It comes back on when the key is turned off, but it has been reset to 01:00. Pressing the starter button does nothing. All fuses are OK. Any suggestions? Thanks in advance for any help. Don _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: electrical problem - nothing works but the clock,and that ain't doing so well
Put a voltmeter on the battery, then turn the key on. What is the voltage
before and after? doug -----Original Message----- From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of don.vt@xxxxxx Sent: August 12, 2008 12:01 PM To: vfr@xxxxxx Subject: electrical problem - nothing works but the clock, and that ain't doing so well I have a 2000 VFR with about 28K miles. About 2 months ago, I had 4 or 5 episodes where when I started the bike, it didn't immediately start, and the clock and the trip odometers were set back to 01:00 and 0, respectively. I did some research in the archives and found that several people have experienced this problem. There were a number of theories on why this happens, including a bad cell in the battery or an R/R that was about to fail. I checked my battery and it had a good charge but not full power. I fully charged it and I had no problems for about 4 weeks, until about 2 weeks ago. On that day, when I went to restart the bike after a 20-mile ride and then sitting for 10 minutes, nothing happened when I pushed the starter button. The clock and odometers were reset and there was no noise from the starter at all. I was out of town for the last 2 weeks and while gone, I fully charged the battery even though the lights on the charger indicated that it didn't need a charge. When I then put the battery back in the bike and turned the key on, the indicator lights glowed dimly and then slowly faded. I heard a fading whining noise from the instrument cluster area, like something electrical was discharging. I heard one click from the mid-section of the bike (may have been the fuel pump?) and then everything was dead. At this point the clock is working, but when I turn the key to the 'On' position, the clock disappears after a couple of seconds. It comes back on when the key is turned off, but it has been reset to 01:00. Pressing the starter button does nothing. All fuses are OK. Any suggestions? Thanks in advance for any help. Don _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: electrical problem - nothing works but the clock, and that ain'tdoing so well
Replace the battery. Even if it is not the root cause, it's clearly
contributing to the symptoms. It's a wear item and this one is worn out. don.vt@xxxxxx wrote: > I have a 2000 VFR with about 28K miles. About 2 months ago, I had 4 or 5 episodes where when I started the bike, it didn't immediately start, and the clock and the trip odometers were set back to 01:00 and 0, respectively. > > I did some research in the archives and found that several people have experienced this problem. There were a number of theories on why this happens, including a bad cell in the battery or an R/R that was about to fail. I checked my battery and it had a good charge but not full power. I fully charged it and I had no problems for about 4 weeks, until about 2 weeks ago. > > On that day, when I went to restart the bike after a 20-mile ride and then sitting for 10 minutes, nothing happened when I pushed the starter button. The clock and odometers were reset and there was no noise from the starter at all. > > I was out of town for the last 2 weeks and while gone, I fully charged the battery even though the lights on the charger indicated that it didn't need a charge. When I then put the battery back in the bike and turned the key on, the indicator lights glowed dimly and then slowly faded. I heard a fading whining noise from the instrument cluster area, like something electrical was discharging. I heard one click from the mid-section of the bike (may have been the fuel pump?) and then everything was dead. > > At this point the clock is working, but when I turn the key to the 'On' position, the clock disappears after a couple of seconds. It comes back on when the key is turned off, but it has been reset to 01:00. Pressing the starter button does nothing. All fuses are OK. > > Any suggestions? > > Thanks in advance for any help. > > Don _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: electrical problem - nothing works but the clock,and that ain't doing so well
My clock and trip odo does this about once every 2 months.* No battery issues at all, did it with the old battery and with my new one...
* My RR is original far as I know...and I get around 13.5-13.6V charging with the rr at some???reasonable rpm...max I ever see is 13.8 briefly. Matt _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| 84 750 interceptor electrical problem please help ive tried everything | razortongue1 | Mechanics Garage | 14 | 07-02-2008 03:16 PM |
| electrical problem (short?) | sradwxi | Mechanics Garage | 9 | 12-17-2007 07:05 PM |
| Electrical problem -headlights blown tripswitch & clock resets | Cavo | Mechanics Garage | 0 | 10-30-2006 10:10 PM |
| 1990 vfr750 electrical problem | keniger345 | Third & Fourth Generation 1990-1997 | 5 | 06-05-2006 01:29 PM |
| 93 VFR Electrical Problem Solved | Alan Lee | VF/VFR Mailing List | 2 | 05-28-2006 09:57 AM |
