Old 08-17-2008, 07:21 AM   #1 (permalink)
RR failure
Just replaced this on my '99. Tried working with ELECTREX, but they shipped one modified from an RC51 that had too short leads. Got the OEM part and it has been improved with much larger cooling fins and an AL mounting plate which acts as a heat sink. Decided to help it out a bit (running RKA softbags) with a Radio Shack PC micro cooling fan that got mounted with zip ties and velcro to the frame in front of the RR to force air thru the unit. Also added an LED voltmeter on the steering head over the keylock assembly to monitor everything.
Brad
CT.
battery failure james greer VF/VFR Mailing List 0 06-02-2008 01:51 PM
Voltmeter WAS: more intermittent battery failure Marc Brinker VF/VFR Mailing List 1 05-31-2008 11:51 AM
1998 VFR CATASTROPHIC Charging system failure!!! Bike burst into flames!!! *READ ME* nicoliusmc Fifth Generation 1998-2001 23 03-06-2008 07:30 AM
RE: R/R failure warning time / Onboard VOM....... Quint A Marcaletti VF/VFR Mailing List 0 11-15-2007 11:09 AM
Re: Failure modes/RR Quint A Marcaletti VF/VFR Mailing List 0 05-14-2007 12:55 PM
