Old 08-19-2008, 06:41 PM   #1 (permalink)
JohnMurin
RE: Throttle Body Sync..
Kev:
I've read many of your posts, and agree with you more often than not; but
I've got to take you to task on this one. Synching the starter valves on my 98
is literally a 15-minute job for even a novice mechanic, and that includes time
spent gathering the few necessary tools/gauges (nut driver, screwdriver,
wrench, tach, manometer). Checking the valves, on the other hand, is a certain 2+
hour PITA - and that's on a good day, assuming you've got the tools and
experience. Given that most of the wrenches on this list report finding their
valves well within spec at 16k, 32k, and even 48k miles, WTF would anyone in their
right mind do the valve check on a VFR any more often than the manual
suggests? If you're constantly beating the p*ss out of your VFR on the racetrack -
and also have alot of free time - what you suggest might make sense; but you'd
have to be a complete glutton for punishment otherwise to follow this advice.
John Murin
98vfr800
Worcester, MA
> From: "Kglick"
> Subject: RE: Throttle Body Sync...
> Do keep in mind that one should also check the valves when doing
> a throttle body synch. I recognize that the maintenance interval
> for the two is different but it's just plain good sense.
> Synching the bodies with valves that are out of spec will just
> contribute to the poor running condition.
> Kev
Re: Throttle Body Sync... Rudy Fierros VF/VFR Mailing List 0 08-11-2008 03:15 PM
Throttle body sync? tonydig11 Mechanics Garage 4 04-14-2008 02:15 PM
Gen 5 Throttle Body Removal Jake Harsha VF/VFR Mailing List 7 01-22-2007 06:29 AM
Starter Valve Sync vs Throttle Body Sync Stroh Mechanics Garage 0 09-26-2006 11:07 AM
RE: Vfr Digest, Vol 25, Issue 25 tryit VF/VFR Mailing List 0 04-16-2006 11:45 AM
