Old 08-21-2008, 01:20 AM   #1 (permalink)
turgut kalfaoglu
VFR Mirror loosening
After my left mirror replacement, whenever someone (pedestrian) bumps
into the mirror -- happens often if I park on a busy street,
my mirror loosens. That is, when I push it back to its real place, it
won't stay there and with the wind, it creeps closed.
I take out my hex set and fix it, but it's annoying. I was wondering if
I didn't put the washers in the correct place or something.. what could
be the cause of this loosening?
Thanks! -turgut
Old 08-21-2008, 04:37 AM   #2 (permalink)
SpeedProp32Cleaver'sGMail
Re: VFR Mirror loosening
Use some blue Loctite on the threads. Don't use red Loctite. Blue is
"service replaceable." Red makes it very hard to get an item loose once
used.....been there, done that, not fun on disassembly.
Mark
93 VFR
90 GS500
02 Shadow - sold
> Thanks! -turgut
Old 08-21-2008, 05:52 AM   #3 (permalink)
Joe Foe from Buffalo
Ya use BLUE Lock tight but I also put a nylon washer between the mirror and base to help. Go to any hardware store and look in the pluming department for the proper size.
Joe Foe from Buffalo :-)
Re: vfr Digest, Vol 52, Issue 13 Steve VF/VFR Mailing List 0 07-18-2008 04:17 PM
Ninja 650 vs VFR VFR4464 General VFR Discussions 42 12-10-2006 08:15 AM
VFR Discontinued/Replacement? CycleWorld story David Thompson VF/VFR Mailing List 7 11-23-2006 10:04 AM
RE: vfr Digest, Vol 30, Issue 55 Andrew Bertsch VF/VFR Mailing List 5 09-26-2006 05:38 PM
RE: New VFR Paul Kolbo VF/VFR Mailing List 18 09-04-2006 07:13 PM
