Old 08-25-2008, 11:57 AM   #1 (permalink)
vic5491
Need to replace valve cover gasket at 35K?
I have a 99 VFR800 and am about to do my second valve check at 35K. I checked them at 18K and all were in spec. When I put the bike back together I applied a thin layer of Permatex Ultra Blue Sensor Safe Silicone Gasket Maker on the valve cover gasket and reused the original gasket. At 18K the gasket looked like new and was still soft and pliable. I am about to do my second check at 35K and wonder if I will likely be able to continue to use the original valve cover gasket. New ones are $60 bucks and I would like to save that money unless the WOTL suggests this would be a mistake. How many of you have had good luck reusing these gaskets several times? Has anyone had a problem reusing them?
Vic
Old 08-25-2008, 12:57 PM   #2 (permalink)
Rich Ronay
Re: Need to replace valve cover gasket at 35K?
Vic,
Just did mine at 60,000.* Original gaskets.*Eighteen years old.* Still soft. *No Leaks.
Richard
--- On Mon, 8/25/08, vic5491@xxxxxx wrote:
Subject: Need to replace valve cover gasket at 35K?
To: vfr@xxxxxx
Date: Monday, August 25, 2008, 5:57 PM
I have a 99 VFR800 and*am about to do my second*valve*check*at 35K.* I checked them at 18K and all were in spec.* When I put the bike back together I applied a thin layer of Permatex Ultra Blue Sensor Safe Silicone Gasket Maker on the valve cover gasket and reused the original gasket.**At 18K the gasket looked*like new and was still soft and*pliable.* I am about to do my second check at 35K and wonder if I will likely be able to continue to*use the original*valve cover gasket.* New ones are $60 bucks and I would like to save that money unless the WOTL suggests this would be a mistake.* How many of you have had good luck reusing these gaskets several times?* Has anyone had a problem reusing them?
Vic
Old 08-25-2008, 01:43 PM   #3 (permalink)
Paul Monti
RE: Need to replace valve cover gasket at 35K?
Generation 4. 120,000 km (72,000 miles). Valve covers removed 4-5 times.
Never changed them. Never added any sealant. No leaks.
_____
vic5491@xxxxxx
Sent: August 25, 2008 2:58 PM
To: vfr@xxxxxx
Vic
Old 08-25-2008, 07:42 PM   #4 (permalink)
Marc Brinker
Same here - gen 4 (1994). Last valve check at 73,000 miles, same
gaskets, no sealant needed, no leaks. (At ~90k miles, now overdue for
valve check, I expect the same results).
MJB
Subject: RE: Need to replace valve cover gasket at 35K?
times. Never changed them. Never added any sealant. No leaks.
Old 08-25-2008, 08:00 PM   #5 (permalink)
vic5491
Sounds like unless something really unusual happens, the original gaskets are good for a long long time! I'm glad to know that to say the least. The two gaskets plus the 4 that go around the plug holes are almost $80!
Thanks all!
Vic
Marc Brinker wrote:
v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } st1\:* { BEHAVIOR: url(#default#ieooui) } @font-face { font-family: Tahoma; } @page Section1 {size: 612.0pt 792.0pt; margin: 72.0pt 90.0pt 72.0pt 90.0pt; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } P { FONT-SIZE: 12pt; MARGIN-LEFT: 0cm; MARGIN-RIGHT: 0cm; FONT-FAMILY: "Times New Roman"; mso-margin-top-alt:
auto; mso-margin-bottom-alt: auto } SPAN.EmailStyle18 { COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal-reply } DIV.Section1 { page: Section1 } Same here - gen 4 (1994). Last valve check at 73,000 miles, same gaskets, no sealant needed, no leaks. (At ~90k miles, now overdue for valve check, I expect the same results).
MJB
Generation 4. 120,000 km (72,000 miles). Valve covers removed 4-5 times. Never changed them. Never added any sealant. No leaks.
VFR 750FV Shim Check with Pictures. Sye Maintenance 6 03-13-2009 02:14 AM
Valve Cover gasket for '86 VF500F droopydawg First & Second Generation 1983-1989 17 03-11-2008 04:25 PM
sealant on clutch cover gasket?? love4vfr Third & Fourth Generation 1990-1997 4 02-23-2008 05:14 PM
clutch Jeremy Boron VF/VFR Mailing List 6 09-21-2006 10:26 PM
