Old 08-25-2008, 01:59 PM   #1 (permalink)
Mac Christopher
Homemade Manometer
Pros and cons?
http://obairlann.net/reaper/motorcycle/manometer.html
Old 08-25-2008, 07:53 PM   #2 (permalink)
Marc Brinker
RE: Homemade Manometer
> -----Original Message-----
> From: Mac Christopher
> Pros and cons?
Pro: it's cheap and easy and perfectly accurate if you can read it
Con: the water levels will bounce all over the place, especially with
larger cylinder displacement motorcycles, making it hard for you to read
it. Probably a moderate problem with the VFR.
I have a friend who did this to balance the carbs on his BMW GS1000 PD.
He (a very accomplished mechanical engineer with an automotive
background) was pretty frustrated by the results. I stopped over when he
was doing it, and he had a very difficult time reading the levels. Part
of it was the lumpiness of the twin, plus the size of the pistons, I
think. That's why commercial units have restrictors/dampers to moderate
the air pulses. (He should have just taken me up on my offer to borrow
my Morgan Carbtune).
Possible solution: restrict the tube diameter with VERY small diameter
tubing upstream from the water. Might also be able to get fixed tubing
orifice of a proper size from McMaster/Carr or another industrial supply
house.
MJB
'94 VFR750
'89 NT 650 (hers)
Old 08-25-2008, 08:37 PM   #3 (permalink)
JohnMurin
Re: Homemade Manometer
The pro is that it's cheap, anyone can make one, and it increases the
resolution by 13.5x (20mm Hg = 270mm H2O).
But there is one con in particular you should be aware of: If one end of the
tubing slips off its connection, you're going to suck the water right out the
other end tube and into your throttle body. That's not a good thing.
So add an air chamber to each end of the tubing with enough volume inside to
catch all the water (something like a baby food jar with a couple barbed
fittings through the lid). It'll catch any water that makes it out the end of the
U-tube, and the added air volume will also help to even out the pressure
pulses so it's easier to read.
I've been using a home-brewed 4-channel version (made from tygon tubing & PVC
pipe) for several years. Works like a champ.
-John Murin
98vfr800
> Pros and cons?
