ChatBox (New messages since your last visit: 2)
Old 08-30-2008, 06:49 AM   #1 (permalink)
elsie daSilva
akkrisni
Spam detection software, running on the system "mgmt-01.angryhosting.com", has
identified this incoming email as possible spam. The original message
has been attached to this so you can view it (if it isn't spam) or label
similar future email. If you have any questions, see
The administrator of that system for details.
Content preview: Do you sleep more than 10 hours a day? It leads to obesity.
Stop dreaming about being slim! Look the way you want to! Do you sleep more
than 10 hours a day? It leads to obesity. Stop dreaming about being slim!
Look the way you want to! [...]
Content analysis details: (23.5 points, 5.0 required)
pts rule name description
1.5 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP)
2.9 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr
1)
0.5 RCVD_IN_PBL RBL: Received via a relay in Spamhaus PBL
[190.99.146.79 listed in zen.spamhaus.org]
0.0 HTML_MESSAGE BODY: HTML included in message
1.5 RAZOR2_CF_RANGE_E8_51_100 Razor2 gives engine 8 confidence level
above 50%
[cf: 100]
0.5 RAZOR2_CHECK Listed in Razor2 (http://razor.sf.net/)
0.5 RAZOR2_CF_RANGE_51_100 Razor2 gives confidence level above 50%
[cf: 100]
1.6 URIBL_AB_SURBL Contains an URL listed in the AB SURBL blocklist
[URIs: sizestraight.com]
2.1 URIBL_WS_SURBL Contains an URL listed in the WS SURBL blocklist
2.9 URIBL_JP_SURBL Contains an URL listed in the JP SURBL blocklist
2.1 URIBL_OB_SURBL Contains an URL listed in the OB SURBL blocklist
2.5 URIBL_SC_SURBL Contains an URL listed in the SC SURBL blocklist
2.0 URIBL_BLACK Contains an URL listed in the URIBL blacklist
0.1 RDNS_NONE Delivered to trusted network by a host with no rDNS
2.8 DOS_OE_TO_MX Delivered direct to MX with OE headers
The original message was not completely plain text, and may be unsafe to
open with some email clients; in particular, it may contain a virus,
or confirm that your address can receive spam. If you wish to view
it, it may be safer to save it to a file and open it with an editor.
