Old 08-31-2008, 09:51 AM   #1 (permalink)
chris lye/ estelle
VFR750FJ; fitting a later engine.
Hi,
I've got a '88 UK spec VFR750FJ on a '89 Plate that I've owned for six years.Â* These motors are quite noisy (by VFR standards) and I run a Motad stainless system.Â* I'm not to concerned about the noise but nothing lasts forever.Â* I'm curious if a later (90-94ish) lump would go in (I reckon it would fit ok)? I would like to know if I would need to fit an entire loom and assosiated electronic components (Regulator/Rectifier etc) or will the motor would run fine on the early electrics?Â* I expect to have to replace the carbs with the later type, but then perhaps not?
Any help would be apreciated.
Regards Chris.
Old 08-31-2008, 01:52 PM   #2 (permalink)
jzh3
Re: VFR750FJ; fitting a later engine.
The '90-'97 engines are nearly identical, but I have never heard that
the earlier engines were very similar in the sense of
interchangeability. (RC30 cases are apparently related to RC24 cases,
FYI.) Could still fit in an earlier chassis, but things like
exhausts, air boxes and fuel tanks could scupper your plans at any
point. The only sensible way to do an engine swap is to use the
wiring loom and bits from the donor bike...but you could be an
extraordinarily lucky person, so don't let me stop you!
Ciao,
JZH
London, UK
www.vsource.org
On 8/31/08, chris lye/ estelle wrote:
> Hi,
> years. These motors are quite noisy (by VFR standards) and I run a Motad
> stainless system. I'm not to concerned about the noise but nothing lasts
> forever. I'm curious if a later (90-94ish) lump would go in (I reckon it
> motor would run fine on the early electrics? I expect to have to replace
> Regards Chris.
Aprilia V4 engine cat0020 Anything Goes 2 10-12-2007 07:34 PM
Anyone need an engine or engine parts? Travis Gintz VF/VFR Mailing List 3 08-14-2007 01:08 PM
Engine parts Travis Gintz VF/VFR Mailing List 0 08-14-2007 12:54 PM
Engine dies in mid corner! Mick McHam VF/VFR Mailing List 10 05-07-2007 10:09 AM
THEORY connector bounce problem due to engine vibration Bob Chappuis VF/VFR Mailing List 5 05-19-2006 11:02 PM
